MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Gibson Les Pauls
Thread Tools Display Modes
Old 01-08-2009, 09:23 PM   #1
Vintage_Burster
Vintage_Burster's Avatar
Replacing Tuners
Gibson Guitars Online Store Catalog: Replacement Guitar Parts and Tuners, Machine Heads In Nickel Modern Finish
Will these fit in out of the box, in place of The Standard Perloid ones seen on 07 Standards?
Gibson® Modern Grover Nickel Machine Heads (Set of 6) - PMMH-015
Or am I better off with these Locking Grovers, do they fit out of the box?
Thanks in advance!
"Bursting with a Vintage 07 Standard!"
Vintage_Burster is offline   Reply With Quote
Old 01-08-2009, 09:41 PM   #2
ehamady6
ehamady6's Avatar
Re: Replacing Tuners
I installed chrome locking Grovers from Stew-Mac in my new Custom and they fit without any modication.
ehamady6 is offline   Reply With Quote
Old 01-08-2009, 09:48 PM   #3
Vintage_Burster
So you can go between originals and locking tuners without ever drilling or anything? Great! So how do the locking tuners work and how well do they keep in tune? So instead of holding the string while winding (which I suck at, Im hopeless at string change..I know right.) it locks it in place so you dont have to hold the string. How does it lock the string..alittle button?
Old 01-08-2009, 10:30 PM   #4
ehamady6
ehamady6's Avatar
You won't have to do any drilling as long as it's a Gibson. The locking gears are inside the Grovers, where they are on the outside of most other brands. That keeps Grovers' lockers the same size as non-lockers so the holes line up the same. You can't even tell the difference cosmetically. There's a hole in each tuner's post that you feed the string thru then turn the peg until the gears lock onto the string. The post won't start rotating until the string is locked. No need for buttons or anything else and it usually takes only a single wrap.
The Grovers I installed have tall posts which decreases the angle of the strings between the nut and the tuners. This has resulted in much more sustain and lets the nut do its job without the strings binding in the groves. Of course lockers make string changes fast and they stay in tune better because fewer wraps around the posts decreases the chance of slipage, but I installed them for their sustain and that's exactly what I got. Everything else is icing on the cake. In conjunction with my TonePros locking tailpiece and locking bridge, the locking Grovers were one of the best mods I made on my new black LP Custom. I'm a metal player and hit the strings hard and the lockers perform beautifully and stay in tune, and because they're Grovers I can count on them and concentrate on just playing.
Old 01-08-2009, 10:51 PM   #5
Rudager
Rudager's Avatar
Yeah I just upgraded to locking rotomatic grovers (the ones without the thumb screw on the back) and I think they are great....string changes are much faster and I think I hear a difference...but not sure because I did put new strings on, after all
Ah I got this here to help remove the tuners...they aren't screwed on very tight but this thing helped me not damage any part of the tuner or the guitar during removal or installation....and the good thing is you can get the tuners here too....uh...heh heh...you might have heard of this place:
http://www.stewmac.com/shop/Tools/Sp...utdrivers.html
Rudager is offline   Reply With Quote
Old 01-08-2009, 10:51 PM   #6
Vintage_Burster
If you check my original post, its the second link that are the ones I want. I dont like the kidney bean styled ones, one keystone. Are they the same as your ones, the "tall posts"?
Thanks again
Old 01-08-2009, 10:56 PM   #7
Vintage_Burster
Oh and, are they easy to install?
Im guessing all you have to do is slip them in and screw them in and there good to go?
Old 01-08-2009, 11:24 PM   #8
155
155's Avatar
dont think those will be a direct fit your going to need to ream the hole out for them the 07 std has the smaller holes.
155 is offline   Reply With Quote
Old 01-08-2009, 11:56 PM   #9
Vintage_Burster
Really? Everyone else seems to think there fine..
Also, can you get the screw that hold the pickup rings in place at hardware stores? Mine are rusting alittle bit, I have really acidic sweat I think..yuck.
Old 01-09-2009, 12:05 AM   #10
lp_junkie
lp_junkie's Avatar
rusty screws are part of the mojo of a guitar that is well loved.
Shane
Just a guitar bum...........
lp_junkie is offline   Reply With Quote
Old 01-09-2009, 12:08 AM   #11
155
155's Avatar
pretty sure youll have to ream they went on ehamdy6's custom because it came with grovers,I may be wrong but....
Old 01-09-2009, 12:10 AM   #12
Dan C
As far as I know the '07 Standards, at least mine, come with the Kluson style tuners with the smaller size press in bushings and two mounting screws. The Grovers you are looking at will most definitely not be a direct swap if you now have the keystone Klusons.
Dan C is offline   Reply With Quote
Old 01-09-2009, 12:13 AM   #13
Vintage_Burster
Hmm, Im not even sure if those links I post are Locking tuners. You can only get locking tuners in those kidney bean styled heads it seems..that sucks..
Old 01-09-2009, 09:33 AM   #14
155
155's Avatar
you can get gotoh locking tuners that are a direct fit and are exactly like the stockers, someone here said that gotoh makes the stock tuners . I ve been contemplating getting them
Old 01-09-2009, 11:04 AM   #15
Hedcrash
Hedcrash's Avatar
I installed them on my Studio and they work great. I originally wanted to install Sperzels, but I didn't want to drill new screw holes or ream out the peghead holes. The Gotohs will fit the factory screw holes without modification.
One thing to keep in mind though... All of my research into the subject indicated that I couldn't use the Sperzels or Grovers without reaming out the peghead holes. Supposedly the stock tuners used 9mm holes and most aftermarket tuners are 10mm. WRONG. I got my Gotoh tuners and proceeded to remove the stock Gibson Deluxe greenkeys only to discover that the peghead hole *was* 10mm. So I ended up having to order press-in conversion bushings from Stew-Mac. Turns out that the Gotoh units are a direct retrofit for the old style Klusons with press in bushings, like on a R8-R9. The newer Gibson Deluxe tuners don't use press-in bushings, they use a threaded sleeves that go through the peghead and screw into the body of the tuner.
Once installed I actually thought that the factory Gibson Deluze greenkeys were better mad to tighter tolerances - there is no wiggle in the shafts compared to the Gotohs. In use though the Gotohs are fine and work as advertised.
Hedcrash is offline   Reply With Quote
Old 01-09-2009, 11:06 AM   #16
gmacdonnell
gmacdonnell's Avatar
Location: Somewhere on the East Coast, far from home...
You'll definitely have to ream the holes for the Rotomatics.
I'd personally stick with a set of Kluson-style. Tone Pros, and Gotoh make locking tuners that WILL fit perfectly.
Keep in mind, the more mass in the tuner, the less resonance, dynamics and openness the guitar will have. It will gain in sustain, however, but to many people, the trade off isn't worth it.
Grovers were the only replacement for many years, which is why many Les Pauls have them, but if your guitar didn't come with the installed, I'd stay away from them. They work great on Customs, but you don't want to put a drill to your Standard only to find out you don't like the new tone.
"In our culture we have such respect for musical instruments, they are like part of God."
- Ravi Shankar
“Sounds like the blues are composed of feeling, finesse, and fear.”
-Billy Gibbons
gmacdonnell is offline   Reply With Quote
Old 01-09-2009, 02:50 PM   #17
Dan C
These are what you want, and at the best price I've seen them. Direct fit replacement for Standards equipped with the Kluson type tuners. I have them on my '07 Standard GOTW #34, and my '08 Standard Faded. They appear to be identical in every way to the factory Gibson including the small 'Japan' stamping on the back, which suggests that the original Gibsons are indeed made by Gotoh. However, the included bushings do need to be installed. They are pretty easy to swap out.
Vintage Kluson Style Locking Tuners Nickel
Old 01-09-2009, 04:28 PM   #18
gmacdonnell
Exactly! Nice...
- Ravi Shankar
-Billy Gibbons
Old 01-09-2009, 08:12 PM   #19
Vintage_Burster
Can you get locking tuners that fit in the kluson style but metal keystone, like seen on the 08 Standards?
Old 01-05-2011, 08:23 PM   #20
The Absorbant
Hey everyone!
I'm in love with the Les Paul. I own an Epi LP Standard and just ordered an Epi LP Prophecy EX!
The thing I'm not satisfied with on the Standard are the tuners. I bought this back in 1998, when the Epis still came with the crappy Kluson style tuners. What I'm wondering is, will the Gibson PMMH-0015 Grover tuners fit without modification or will I need to make adjustments? I want chrome tulip head ones to go with the rest of the hardware.
Here's the guitar in question. The first thing I did was rip out the Epi original crappy pickups and put in Gibson 500T and 496R that someone took out of their brand new Explorer. Go figure.
The Absorbant is offline   Reply With Quote
Old 09-06-2011, 06:33 PM   #21
The Absorbant
If anyone cares, I did end up getting those tuners and having a friends who's a guitar tech replace them for me.
Aren't they gorgeous:
Forum Jump
