MyLesPaul.com
Go Back   MyLesPaul.com > Music Gear > Tonefreaks > Pickups
Thread Tools Display Modes
Old 02-11-2014, 07:56 PM   #1
martin6string
How To Measure Pickup DC Resistance
Here's a quick and easy pictorial of how to measure pickup DC resistance using your multi-meter.
For illustration purposes, I'm using my test rig that I use to test wiring harnesses after they are built, so there are ALOT of wires that you don't need to concern yourself with for this exercise. The bridge pickup we'll test is 4 conductor, and I've marked all the appropriate leads in the picture.
** If you want to test single conductor braided pickups, all you need to do is put on lead of your meter on the inner hot wire, and the other lead on the outer braid which acts as the ground. Make sure that none of the outer braid comes in contact with the hot or you won't get a reading. **
The testing rig:
Note we have (4) leads - Hot, Series Links (combined into 1), Ground (Covered), and Bare Ground Wire.
If you don't have an auto-sensing meter like this one, set the range to 20K.
As depicted, I took the HOT from the pickup and connected to one lead on the meter. I then took the Bare AND Covered Ground wires and connected those to the other lead on the meter.
Now if you wanted to test just the coil split (1/2 the pickup), substitute the hot lead from the pickup with the series link wires (Ex. Seymour Duncan uses Red+White as the series links, so you'd test those wires - Mine is already presoldered into one "series link" lead for simplicity purposes).
Notice the output is roughly 1/2 of the full pickup output of 8.05K. Everything works fine!
Lastly, if your wanting to test DC resistance of pickups that are already installed in your guitar, its as easy as plugging a guitar cable into the input jack of the guitar, and connecting a multi-meter to the other side of the cable as follows:
You may get a *slightly* different value using the above testing method because of the caps and pots being connected to the circuit. It should not deviate by much.
Here's another way too, assuming the pickup is already wired up:
One leg of the meter gets clipped to the volume pot lug where the pickup is connect, the other leg clipped to the outer braid of the pickup. Make sure your volume is all the way up
Hope this helps!
martin6string is offline   Reply With Quote
The Following 20 Users Say Thank You to martin6string For This Useful Post:
Old 02-11-2014, 09:58 PM   #2
jamman
jamman's Avatar
Re: How To Measure Pickup DC Resistance
Good stuff Matt . Should be a Sticky . Those who need this should have it available easily .
jamman is offline   Reply With Quote
Old 02-11-2014, 11:31 PM   #3
martin6string
Thanks, Jeff!
Old 02-12-2014, 02:22 AM   #4
tazzboy
tazzboy's Avatar
OK how about on braided shield wiring?
tazzboy
tazzboy is offline   Reply With Quote
Old 02-12-2014, 02:26 AM   #5
AstroCat
★AstroBling★
AstroCat's Avatar
the braided shiled itself the ground, the wire coming out of the shielded cloth is the hot wire
AstroCat is offline   Reply With Quote
Old 02-12-2014, 02:49 AM   #6
captcoolaid
captcoolaid's Avatar
what if my pickup reads 22k but my meter is only at 20k smart guy????? LOL
DC DOES NOT EQUAL OUTPUT. Dc is a resistance value and that is all. It WILL NOT tell you what it will sound like, it WILL NOT make you sound like another player.
captcoolaid is offline   Reply With Quote
Old 02-12-2014, 08:50 AM   #7
martin6string
This.
Old 02-12-2014, 08:50 AM   #8
martin6string
Idiot!!!
Old 02-12-2014, 10:03 AM   #9
AXE
Six String Soldier
AXE's Avatar
Will a shorter output cable for the installed pickup method give a more accurate reading?
I usually use a solid offset pedal jack just because...
Visual aid.
lol
AXE is offline   Reply With Quote
Old 02-12-2014, 03:15 PM   #10
AstroCat
★AstroBling★
AstroCat's Avatar
^i think you should plug into your amp like that. better tone. less signal path so you get more tone to your amp.
play live like that too axe.
Old 02-12-2014, 03:50 PM   #11
AXE
Six String Soldier
AXE's Avatar
okay.
lol
Old 02-12-2014, 04:17 PM   #12
martin6string
Visual aid.
Maybe, maybe not, Rick. If there is a deviation, I would think it could be slight. The pickup winding folks could probably shed more light on that.
Old 02-12-2014, 08:19 PM   #13
AXE
Six String Soldier
AXE's Avatar
Thanks Matt.
That's a badass V huh?
lol
Old 02-14-2014, 09:04 AM   #14
7gtop
7gtop's Avatar
"over-under-sideways-down,
sooo much more than square 'n round"
7gtop is offline   Reply With Quote
Old 02-14-2014, 06:24 PM   #15
martin6string
Old 02-21-2014, 04:59 AM   #16
Bigans
Thank you guy, great post!
Anyone may help me doing the same test with the PCB of my Gibson LP Studio?
https://www.google.com/search?q=Gibs...et%3B816%3B612
Bigans is offline   Reply With Quote
Old 02-22-2014, 09:02 AM   #17
ghost driver
ghost driver's Avatar
Thanks for this great post Matt. This is very helpful. Even to members who have done this its great to see how you would do it. I also think it would be a good sticky (I see it already is).
ghost driver is offline   Reply With Quote
Old 03-29-2015, 07:11 AM   #18
blues_n_cues
blues_n_cues's Avatar
here's a question, I did mine using the cable end/multimeter method on a Les Paul w/ 57's in it & 50's wiring.-
Bridge-13.25
Neck-8.85
but when in the middle position it reads 5.08
I'm not sure if that's normal but when playing it sounds like full output.
I do know there is an open ground or cold solder joint somewhere @ the moment but I haven't found it yet.
2007 epi lp custom antique ivory finish
Austin gold top w/ P90's
Yamaha HSS strat
(loads of other junk)
vox 847 wah>>alesis midiverb2(delay)>midiverb 3(chorus on occassion)>Marshall JMP-1(midi rack pre)>Alesis RA-100 pwr amp> B-52 4x12 cab loaded w/ Altec 417 8-h's.
blues_n_cues is offline   Reply With Quote
Old 03-29-2015, 07:30 AM   #19
freefrog
Bridge-13.25
Neck-8.85
It's totally normal: two pickups in parallel measure the sum of their DCR's divided by 4. And you have 4 pots in the circuit instead of two, whose DCR drags down the whole DCR too.
freefrog is offline   Reply With Quote
Old 07-06-2015, 11:02 PM   #20
Lefty Bob
Don't forget about the temperature of the coil.
When ever possible measure DC resistance at 68*F (20*C) .
I use an IR temp gun to read the temp of the coil when I measure DC resistance
For every 5 degrees under or over 68*F add or subtract 1%
Ex: 7.57k ohms measured at 73*F = 7.494k ohms.
Lefty Bob is offline   Reply With Quote
Old 07-12-2015, 05:53 AM   #21
C_Becker
Dat Gibson smell
C_Becker's Avatar
Compared to the 8 or more kOhm of the pickup, the resistance of the wire is very, very small. The wire is probably below 1 Ohm resistance, so you can ignore that.
The collection:
Electric:
2013 Gibson LP Studio AW
2013 Gibson LP Traditional HCS
2014 Gibson MM Flying V (EMG ALX)
Squier CVC Tele (Texas Specials; Allparts Fat Neck)
Epi Gothic '58 Explorer (EMG JH)
Epi Robb Flynn Baritone Flying V (EMG JH)
Jackson JS32-7Q (SD Nazgul/Sentient)
J&D LS500 (SD SH2/SH4)
Bass:
LTD F-5E
Epi Viola
Acoustic:
Gibson Advanced Jumbo Red Spruce
Ibanez V50
Amps:
Marshall JCM 800 Kerry King
Marshall MG10 Kerry King
Blackstar HT-1RH Metal
C_Becker is offline   Reply With Quote
Old 07-19-2015, 01:30 PM   #22
oildrops
I just installed new pots and pickups. The neck sounds full output, but the SD SH-5 in the bridge sounds like it's not getting the full output. I measure 13.5k for the SH-5 (duncan states Bridge: 14.1 k). Could there be a short somewhere, or does this seem normal? Could there be a grounding issue somewhere and still get the correct resistance reading?
oildrops is offline   Reply With Quote
Old 07-19-2015, 02:04 PM   #23
martin6string
Could be an issue with the switch, but if possible, post a pic of the electronics cavity so we can see if anything looks suspect.
Also, the difference from 13.5K to 14.1K could be the temperature at the time of metering. That doesn't raise any flags with me at all.
Old 07-19-2015, 03:37 PM   #24
oildrops
I posted a pic in this thread http://www.mylespaul.com/forums/luth...me-advice.html, but posted in the luthier forum by accident. I just checked through all the wiring and tugged on every wire to check to cold joints. I unhooked the tone pot from the bridge pickup, which made no difference. I checked the lugs on the switch, and made sure they weren't touching. I re-soldered the pickup hot and ground, and the bent lugs on the pots. The only thing I can think of that I didn't check is where I grounded all the shielding together for the switch. I can't access it unless I de-solder everything because I didn't leave myself enough slack, so I was leaving that as a last resort.
Old 07-19-2015, 05:02 PM   #25
freefrog
14.1k in parallel with two 500k pots (volume and tone) is supposed to become 13.347k.
Here is a useful tool to check it if necessary: PARALLEL RESISTOR CALCULATOR
So, if the SH5 has a problem of output, it's apparently not a question of grounding.
Old 08-08-2015, 01:36 PM   #26
martin6string
I've updated the tutorial to make it a bit easier to understand. Content can be found in my technical blog:
Measuring Pickup DC Resistance
Old 04-19-2016, 01:44 PM   #27
Wraptail
MLP Vendor
Wraptail's Avatar
Great point that isn't mentioned often.
www.TysonTone.com
Wraptail is offline   Reply With Quote
Old 09-21-2016, 07:18 AM   #28
peanutavalon
I just did my cc les paul bridge only using the already wired method..it read 7.77.
Then I did my benchmark ro using the same method...it read 4.04. I realize the benchmark runs have the lower output E buckers but that is a substantial difference to me. The funny thing is the E buckers are just as loud and more articulate.....Any input on this one guys? thanks
edit...never mind..someone suggested putting my cable in the guitar input...solved the problem and the pickups read 7.34.
peanutavalon is offline   Reply With Quote
Forum Jump
