MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > The Custom Shop
Thread Tools Display Modes
Old 01-23-2014, 03:41 PM   #1
cristi tanasescu
cristi tanasescu's Avatar
is soldering dangerous?
yes or no? i have been soldering for the last couple of hours, is this bad?
2012 les paul standard - Blue Mist :treble bleed, dunlop straplocks
2013 Fender 72 reissue strat - Vintage White
that's all, folks!
cristi tanasescu is offline   Reply With Quote
Old 01-23-2014, 03:46 PM   #2
tzd
Re: is soldering dangerous?
It is bad if you inhale.
tzd is online now   Reply With Quote
Old 01-23-2014, 03:47 PM   #3
chasenblues
chasenblues's Avatar
Depends on what you mean by dangerous, to your health i would think no.
(unless you're doing it in your underwear, then you're on you're own)
chasenblues is offline   Reply With Quote
Old 01-23-2014, 03:49 PM   #4
GitFiddle
GitFiddle's Avatar
Depends on if you consider snorting lead oxide bad.
Safe Soldering Checklist - For Dummies
http://www-bdnew.fnal.gov/esh/newsletter/lead.html
GitFiddle is offline   Reply With Quote
Old 01-23-2014, 03:52 PM   #5
Shawn Lutz
Shawn Lutz's Avatar
no but stupidity is
http://shawnlutz.com
Shawn Lutz is offline   Reply With Quote
Old 01-23-2014, 03:52 PM   #6
MooCheng
MooCheng's Avatar
only if its still pluged an switched on
MooCheng is offline   Reply With Quote
Old 01-23-2014, 03:55 PM   #7
chasenblues
Not saying its the most healthiest thing to do, But couple hrs of noodling/practicing vs people who do it for 8-10 hrs as day job?
Old 01-23-2014, 03:58 PM   #8
chasenblues
Never Mind.
Old 01-23-2014, 07:30 PM   #9
Custom53
Custom53's Avatar
If you have to ask this question, than I would say yes.. For you..!
'15 PRS Custom 24
'10 Gibson Les Paul Axcess
'08 Gibson Les Paul R9
'04 Gibson Les Paul Standard
'04 Burns Brian May
'02 Ernie Ball Axis
'01 Burns Brian May
'01 Fender '52 RI Telecaster
'95 Rickenbacker 350
'94 Hamer 3 Hole Duotone
'94 Ibanez IC300
'91 Ernie Ball EVH
'81 Hamer Special
'75 Ovation Breadwinner
Marshall JMP 2203
Marshall JCM 2000 DSL
Marshall JCM 2000 TSL
Soldano HR50+
Peavey Classic 100 Watt
Kustom 3-15" Prototype
2 -Acoustic 370/301 Bass Rigs
Custom53 is offline   Reply With Quote
Old 01-23-2014, 07:37 PM   #10
KenG
Solder melting temperatures will not turn metal into a gas that can be inhaled.
Touching the solder however will get lead on your hands so you should wash up afterwards. The smoke from soldering is the flux burning off, flux is a cleaning agent that prevent oxidization of the surfaces to be soldered. If these surfaces are allowed to oxidize, the solder will not bond properly or flow nicely. Most electronic solders have a rosin core flux embedded inside the solder itself. Generally speaking there are 3 types of flux for electronics with tin/lead solder; Rosin Core (R), Rosin Mildly Active (RMA) and Rosin Active (RA). These really aren't toxic to my recollection. For good soldering you should use eutectic solder (63/37) over the cheaper 60/40 solder. Never use RA flux, it stays active after heating and if not properly cleaned can eat away at the metals you soldered over time.
KenG is offline   Reply With Quote
Old 01-23-2014, 08:59 PM   #11
Ronsonic
Not dangerous. There will be the occasional burn. Some people are allergic to some fluxes. That's about it.
Ronsonic is offline   Reply With Quote
Old 01-23-2014, 09:18 PM   #12
Comanche
Comanche's Avatar
Yes, I burned my tongue once.
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-xpa1/v/t1.0-9/10441310_10202120144872371_3657727741838977044_n.j  pg?oh=d8165b730f0a190b15c113817fb8d85f&oe=54B9961A  &__gda__=1421302540_915f93b7e91e46e3a2ed4c3c12673c  7c
Off the farm.
Comanche is offline   Reply With Quote
Old 01-24-2014, 12:23 AM   #13
cristi tanasescu
I meant about inhaling that ****.
that's all, folks!
Old 01-24-2014, 12:36 AM   #14
TheZeppelinKid1991
TheZeppelinKid1991's Avatar
inhaling is bad, in the case of solder that is dropping hot ass molten solder on yourself is very bad M'KAY. on a more serious note though, i suggest you wear a doctors mask, at least that's what i do
BURSTBUCKER and misc FOR SALE(take a look please)
http://www.mylespaul.com/forums/memb...r-goodies.html
2011 Gibson Les Paul Studio Wine Red
Jackson Kelly White SOLD
1964 Silvertone Bobkat(under restoration)
Eleca DAG-5-N Acoustic
Blackstar HT5RH Half StackSOLD
Marshall MG15
TheZeppelinKid1991 is offline   Reply With Quote
Old 01-24-2014, 12:38 AM   #15
cristi tanasescu
Thanks gor the answers
that's all, folks!
Old 01-24-2014, 12:49 AM   #16
cristi tanasescu
I was soldering for like 2 hours, but most of the time I was just sitting trying to do the wiring and so. I inhaled the fumes lets say about 6 times i guess it's not too bad, but I touched my mouth afterwards as a contemplating position
that's all, folks!
Old 01-24-2014, 02:33 AM   #17
ATM47
ATM47's Avatar
Let's see now...
Heat.
Molten lead.
Toxic fumes.
What could possibly go wrong?
The only thing I can think of is if you are soldering something
that you tried to stick together with crazy glue first.
The crazy glue will vaporize and if you get the vapors in your
eyes and blink you will not be able to open your eyes back up.
Other than that.................
ATM47 is offline   Reply With Quote
Old 01-24-2014, 03:16 AM   #18
cristi tanasescu
But dude can anything go wrong? Can i get a disease or something? The fumes got into me a couple of times and i touched the led then touched my lip..can i get something?
that's all, folks!
Old 01-24-2014, 05:47 AM   #19
ARandall's Avatar
Its solder, not nerve gas you know. Unless you're the Canary.
ARandall is offline   Reply With Quote
Old 01-24-2014, 05:50 AM   #20
dudu
dudu's Avatar
You need to wash away those fumes with a gallon of vodka. You'll be fine afterwards.
Hop on my SoundCloud
dudu is offline   Reply With Quote
Old 01-24-2014, 09:25 AM   #21
cristi tanasescu
Meh if i m not dead yet im fine=) i m doing a les paul il l post pics when it s done
that's all, folks!
Old 01-24-2014, 07:12 PM   #22
Ronsonic
I solder all day long. I'm a tech, people bring me broke amps and stuff and I solder in good parts. Every day. Yeah, flux fumes are sucky and stinky, especially some of the ones from the fifties and the old Japanese stereos of the seventies, they had stinky flux. Don't breath it a lot and you'll be fine. Like I said, some people are allergic. You'd know by now if you were.
The lead is not vaporized at those temperatures you won't be inhaling it. Just don't use your soldering iron as an immersion heater to keep your coffee warm or light cigarettes with it and you'll be fine.
I've been working with lead solder for years and my brain is still mybrains itll ambarihn isitill juat like aa smaty as ever.
Old 01-24-2014, 07:20 PM   #23
parabola801
parabola801's Avatar
This. Then repeat.
parabola801 is offline   Reply With Quote
Old 01-24-2014, 07:34 PM   #24
Ole'Lefty
Ole'Lefty's Avatar
"Hell, if it can't kill you, it ain't a sport" ( retired sprint car driver)
Really, soldering is not a high risk activity-just don't eat the solder. I stubbornly refuse solder without lead in its alloy. You know, being born in the 1940's is pretty good. So many of us have survived in spite of all the risks we took. Then I doubled down and I can more or less walk OK with a more apparent limp than I thought and it goes on. I am glad my daughter takes no chances with my grandson-safety seats, etc., and he still laughs most all day every day.
Years ago I went to the Mississippi Crossroads to make the infamous trade. Lucifer refused to deal-he said that after just a few years as a lawyer I did not have a soul to barter.
Ole'Lefty is offline   Reply With Quote
Old 01-25-2014, 10:13 PM   #25
NCStratDude
NCStratDude's Avatar
If your hands are full please don't use your mouth as a "solder holder"
NCStratDude is offline   Reply With Quote
Old 01-26-2014, 01:31 PM   #26
spitfire
spitfire's Avatar
All the key points have already been made, but I'll reinforce them. Lead doesn't vaporize at those temps, so you won't inhale the lead. You'll get lead in you by ingesting it. Never put solder in your mouth, don't eat and drink at the workbench. Wash your hands regularly.
In other words, pretend the solder is dog doo doo or something similar you don't want to eat.
Based on the fact that I'm not dead yet, and have been soldering for 35 years, exposure to some vaporized and burned flux fumes is not going to hurt you for the occasional exposure.
I try to avoid having the smoke get in my face. A fan can be handy to blow the smoke away. A gentle breeze is all you need, you don't want the fan cooling the work.
Also, lots of smoke means you are burning the flux. Burned flux means your iron is too hot. Though sometimes when soldering a large thing like a ground wire to a pot body, you need the iron to start out too hot, as it will cool quickly on touching the larger body.
Temperature controlled irons are better in this regard.
Insert inane social/political commentary here.
Gratuitous list of music gear here.
spitfire is offline   Reply With Quote
Old 01-26-2014, 05:54 PM   #27
Metal Snake
Metal Snake's Avatar
Location: Crappy Red Barn-House, Madison County, Georgia
I've actually lit cigarettes off of mine before... not tried the coffee thing though, might be bad for the iron.
Oh look, I can have a sig now!
Metal Snake is offline   Reply With Quote
Old 01-27-2014, 10:12 AM   #28
JoDo
JoDo's Avatar
You need to wash away those fumes with a gallon of bourbon. You'll be fine afterwards.
Changed to suit my taste.
JoDo is offline   Reply With Quote
Old 01-29-2014, 02:09 PM   #29
cristi tanasescu
wow, i got many responses on this thread, much more than i expected, so thanks everybody! I'm fine, btw =)
that's all, folks!
Old 01-29-2014, 07:15 PM   #30
USAPatriot
USAPatriot's Avatar
Just remember that even low wattage irons are not like pens and pencils.
1) Don't thoughtfully tap your teeth or lips while pondering what to do next.
2) Don't try and park it behind your ear.
3) Don't show off and shove two up your nose...the face you make at your little brother will be something way beyond what two pencils will do.
4) A hot iron probably will not do your pencil sharpener any good.
2014 Gibson Les Paul Standard Heritage Cherry Quilt Top
Marshall DSL40C
Jet City JCA22H + 2 JCA12S Cabs
USAPatriot is offline   Reply With Quote
Forum Jump
