MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > The Custom Shop
Thread Tools Display Modes
Old 12-28-2008, 08:07 PM   #1
rdplyr
Long or Short shaft pots?
OK. I am a real newby when it comes to electronics. I am ordering some 500k pots for my 1992 Classic Les Paul. I tried to measure the pots, but I don't know how to get the metal plate out that they are stuck to.
Does anyone have a (specifically) 1992 Gibson Les Paul Classic and know if I need long or short shaft pots?
Thanks
rdplyr is offline   Reply With Quote
Old 12-28-2008, 08:12 PM   #2
WildeStarr
WildeStarr's Avatar
Re: Long or Short shaft pots?
Pretty sure they are long shaft, and you can always back off the long shaft pots if you need to for the perfect fit. Can't make short shaft pots longer!
WildeStarr is offline   Reply With Quote
Old 12-28-2008, 08:35 PM   #3
SKATTERBRANE
All Les Pauls since about 1976 are long shaft EXCEPT Historics. Your Classic is long shaft. It has nothing to do with the mounting plate, it is how the control cavity is routed.
SKATTERBRANE is offline   Reply With Quote
Old 12-28-2008, 08:44 PM   #4
DrunkenMonkey
Check here Welcome to RS Guitarworks | Winchester, KY - RS Electronic Upgrade Kit Selection Chart they have almost everything listed
DrunkenMonkey is offline   Reply With Quote
Old 12-28-2008, 10:01 PM   #5
rdplyr
Thanks for the info. As you can probably tell..I don't know what I am talking about. I am no electrical guy, but I would like to be . Thanks again.
Old 12-28-2008, 10:05 PM   #6
WildeStarr
WildeStarr's Avatar
Smile Re: Long or Short shaft pots?
Old 01-01-2009, 12:56 PM   #7
Kølabrennern
Kølabrennern's Avatar
My 1990 Classic's cavity was routed so that you could use two short and two long pots, and came without the mounting plate. Strange.
Myrkgrav - Norwegian folk metal
Obligatory list:
- ExNihilo LP
- Nick Morgan LP
- '07 Edwards E-LP98LTS
- '07 MIJ Epiphone Les Paul Junior lacquer series
Kølabrennern is offline   Reply With Quote
Old 01-01-2009, 01:14 PM   #8
SKATTERBRANE
Yes there were a few early Classics and a few early 90s Reissues without the plate, but the plate was the norm. Probably the long shaft ones were the inboard (neck vol/tone) pair?
Old 01-01-2009, 01:48 PM   #9
jonesy
GLOBAL WIRING GURU
jonesy's Avatar
Wink Re: Long or Short shaft pots?
From my past experience with wiring orders it is best to pull them out and check to make sure. If you guess you will probably be wrong. LP Customs, Supremes and many 70's Standards take the long shaft Pots. Other Standards, many classics(not sure about yours), SG's 335's will use the shorter shaft pots. Short shaft pots have threads that are 3/8" long to fit through the wood as the long shaft will have 3/4" long threads. I have contacted Gibson about this and it varies from guitar to guitar, year to year. Some take 2 long 2 short, best to check to save any hassle.
Old 01-01-2009, 09:02 PM   #10
rdplyr
GOTTA LOVE THAT GIBSON QUALITY CONTROL!!! I called them once on a serial number...The answer was "Well it could be a 1988 or 1998. Sometimes we have reused serial numbers." I love my Les Paul, but it yeesh!!!
It is almost like their assembly line is "Well let's see what is in the drawer when the guitar rolls by!
Old 01-01-2009, 09:12 PM   #11
SKATTERBRANE
I have owned MANY Standards and Classics from the 80s and 90s and they ALL had long shaft pots. In fact, as far as I know ONLY Les Pauls (non SGs) use long shaft pots, all other Gibson use short shaft, as do the vintage Les Pauls (through about 1974-75) and the Historics. But, as in anything Gibson, NO statement is 100%
Old 01-01-2009, 09:17 PM   #12
The_Sentry
The_Sentry's Avatar
I'll second that remark with a Slash....
The Reverb Nation Page!
The_Sentry is offline   Reply With Quote
Old 01-01-2009, 11:06 PM   #13
dtube
dtube's Avatar
Location: North of Pittsburgh, East of Youngstown, close to nowhere...
If you want some minor overkill, Ted Weber carries long-shaft 250 and 500k pots that have 1" bushings (LP's use a .75"). He includes two sets of nuts and washers so that you can adjust the depth to taste. His pots are foreign made; but to his specs, including a 20% taper on the long-shafts. I've used quite a few of his pots in my amps and have been impressed, especially on price. They are better built and feel smoother than the Alpha's IMO.
-Darren
Weber Pots
Strange women, lieing in ponds, distributing swords, is no basis for a system of goverment. Supreme, executive power derives from a mandate from the masses; not from some farsical, aquatic ceremony...
dtube is offline   Reply With Quote
Old 01-07-2009, 02:45 PM   #14
5F6-A
5F6-A's Avatar
"I now consider atheism to be brutal because it offers neither consolation nor liberty of any kind" Benjamin Constant in 1804
5F6-A is offline   Reply With Quote
Forum Jump
