MyLesPaul.com
Go Back   MyLesPaul.com > MLP Community > The Backstage
Thread Tools Display Modes
Old 10-06-2013, 04:30 PM   #1
The Refugee
The Refugee's Avatar
Hooking up a turntable to speakers?
Hey everyone. I know I haven't been around a lot lately because of going away to college and what not but I was hoping for some advice, and the guys and gals on this board are some of the most knowledgable folks I know.
I recently got a turntable and decided to go for an affordable model (Crosley Cruiser Turntable - Assorted Colors : Target). I listened to a little bit of Fleetwood Mac on it (all I have are my mom's old records to listen to, none of my own yet) and while the sound was okay, the max volume on the unit did not go very high. I tried hooking up some speakers into Red/White output jacks on the back of the turntable, but no sound came out of them.
I tried doing some googling but wasn't able to find any compatible speakers or find any information on how to hook up speakers to get sound of a turntable.
Does anybody would know how to get sound to come out of a Red/White outputjack on a turntable directly to a speaker? I'm going to be buying a new pair of speakers if I can find some that I'm able to hook up to my turntable, so if someone has any speakers to recommend that would work for this (nothing too fancy, $50 or less would be great if possible) that would be sweet.
Also if there's anyone here knowledgeable on this model as well, would they be able to recommend it over the one I already purchased?
Amazon.com: Jensen JTA-460 3-Speed Stereo Turntable with MP3 Encoding System and AM/FM Stereo Radio (Black): Electronics Amazon.com: Jensen JTA-460 3-Speed Stereo Turntable with MP3 Encoding System and AM/FM Stereo Radio (Black): Electronics
Thanks
The Refugee is offline   Reply With Quote
Old 10-06-2013, 04:48 PM   #2
Electroman67
Electroman67's Avatar
Re: Hooking up a turntable to speakers?
The red and white cables are RCA cables, they are NOT made to go to a speaker, they are made to go to an amplifier or tuner source. The speakers are hooked to the amp or tuner and the turntable produces sound thru the amp or tuner, that's how my turntable works, as well as my cd player and tape player.
The pic of the turntable hooked to an ipad or iphone, if you have that cable, you can adapt that 1/8" to a 1/4" and then plug into an input on your guitar amp, that's one way to do it.
.58 cents at Radio Shack
http://www.radioshack.com/product/in...ductId=2062468
Electroman67 is offline   Reply With Quote
Old 10-06-2013, 04:52 PM   #3
Nicky
On The Road Less Traveled
Nicky's Avatar
You need to run the turntable through a turntable amp. You hook up the two output wires and the ground wire from the turntable to the amp. Then you hook up the speakers to the amp's outputs.
edit: Electro beat me to it!
Little turntable amps are inexpensive, too.
Originally Posted by X–Ray View Post
Common sense is not authorized on this forum.
Nicky is offline   Reply With Quote
Old 10-06-2013, 04:53 PM   #4
Bobby Mahogany
Bobby Mahogany's Avatar
There are two types of turntable output.
Have a look here for more info.
General Turntable Questions
In short:
Some turntables output need to be pre-amplified before going into a receiver or pre-amp + amplifier. If the output is "phono" and the receiver's input is phono = no problem If not, the signal needs to be pre-amplified. That would explain your lack of volume (as in phono to line in, the line-in input usually receives a pre-amplified signal).
Les Paul Standard 1992
Les Paul Custom 1978
Les Paul Special DC P-90's 1994 and a few others
Fender Super Reverb (45 watts) 1974? (converted to AB 763 circuitry)
Fender Princeton Reverb (12 watts) 196? or 197?
Main pedals: Boss SD-1, RAT, JD CryBaby 335
What I need: Electricity, Lozenges (if I have to sing), Dunlop 205-206 Jazz picks
(I don't play Jazz I only play Jazz picks)
____________________________________________
Hey! I know what you mean, I'm just f*cking around!
Bobby Mahogany is offline   Reply With Quote
Old 10-06-2013, 04:58 PM   #5
HenryHill
HenryHill's Avatar
Stereo receiver amplifier?
Turntable> receiver/amp>speakers
RCA out put from turntable to amp, plain duo speaker wire to speakers.
That's how they were hooked up in the olden days, or at least the vast majority.
HenryHill is offline   Reply With Quote
Old 10-06-2013, 05:13 PM   #6
7gtop
7gtop's Avatar
a Sansui AU 101 ....
locally do-able and frugally priced
** the phono inputs and ground connection are what you need .
"over-under-sideways-down,
sooo much more than square 'n round"
7gtop is offline   Reply With Quote
Old 10-06-2013, 05:22 PM   #7
geochem1st
geochem1st's Avatar
If I remember correctly (it's been a while) the output from a turntable isn't line level, that's why it's labeled 'phono', it's much lower...than line out, so when inputting to an amp for best results you need to match to a 'phono input'
Disregard if the phono just has a 'line out' jack.
"Why is it that wanting clean drinking water makes you an activist, and why proposing to destroy water with chemical warfare doesn't make a corporation a terrorist."
geochem1st is offline   Reply With Quote
Old 10-06-2013, 05:26 PM   #8
stinkfoot
¯\_(ツ)_/¯
stinkfoot's Avatar
now if you want to do it right, hook the turntable into one of these puppies..
that one is stereo, now if you really wanted to sniff cork, you need two amps, one for each channel.
stinkfoot is offline   Reply With Quote
Old 10-06-2013, 05:55 PM   #9
76 ibanez 2619
76 ibanez 2619's Avatar
just my 2 cents but phonos like a bunch of folks here have said need a pre-amp. Back in the olden days that's why stereos had phono inputs.
Decades ago I got me one of them there Bang & Olifsens. The tone arm is about an 1/8inch in diameter at most and the headshell is the same. Low mass = less impact on the vinyl. Remember to not play them more than once a day, that stuff needs to "relax", otherwise you will wear it out.
Linear arms were over rated FWIW.
"All that is not given is lost"
"War, the last obstacle to peace"
sorry for no credits on these quotes.
76 ibanez 2619 is offline   Reply With Quote
Old 10-06-2013, 06:50 PM   #10
12watt
12watt's Avatar
I expect the output on that is line level, so plugging into a free or AUX input in a hi-fi amp / system should do. However, if it is very quiet and very trebly then it is an uncorrected direct out from the phono cartridge and will need a dedicated PHONO input or a phono preamp.
12watt is offline   Reply With Quote
Old 10-06-2013, 07:02 PM   #11
kevinpaul
kevinpaul's Avatar
That is very fancy.
kevinpaul is online now   Reply With Quote
Old 10-06-2013, 11:56 PM   #12
Tone deaf
Tone deaf's Avatar
Judging from your OP, I think you'd be better off with one of the turntables that has a USB connector for your computer (maybe $100 at Costo, etc). Rip the albums, put them back in the sleeves and return that thing to Target.
You won't be getting great quality but, you can harvest all of those albums. I'd look at how many songs you want to harvest if it's 100 you are about breakeven on the cost of the turntable and the cost of the music on itunes.
I like my vinyl (I like my LPs, too) but, getting high fidelity out of an LP (record album) takes an investment for a good (not crazy set up). If you really want to listen to vinyl, I'd suggest buying used gear, a decent turntable (like a Rega), a tube integrate amp (has both the pre and the power amps in one unit) and some very sensitive speakers. Be careful, you might get hooked! Some turntables (like Horo) can run north of $30K...
Bite-me
"I have always been baffled by the depravity of some and the stupidity of those who follow them." Tone Deaf
"If opinions are like a**holes, you should be able to smell me from a mile away." Tone Deaf
"There are two sides to every story. I am only interested in the one that makes me feel better." Tone Deaf
"I've got nothing but love for my fellow man, until he gives me a reason to have something else for him." Tone Deaf
Tone deaf is offline   Reply With Quote
Old 10-07-2013, 12:00 AM   #13
pinefd
pinefd's Avatar
Wow, is that Sansui a blast from the past! That's the exact unit I got to power my stereo probably 30+ years ago! In fact, it may still be hanging around somewhere in my basement...I'll have to look tomorrow.
Frank
Check out some of my personal gear at: Historic Les Paul Database
http://histrungguitars.com/
pinefd is offline   Reply With Quote
Old 10-07-2013, 12:21 AM   #14
GitFiddle
GitFiddle's Avatar
Wow, I never felt old until I got to this thread.
A college kid asking how to hook up a turntable.
I remember when that was around 7th grade. Stereo hookup 101.
Although around 5th or 6th grade, I remember learning a lot about stereo hookup with my Dad's system while he was at work. I managed to make a guitar amp out of it by setting the reel-to-reel to record/pause and plugging my guitar into the mic input.
One day he came home early and caught me jamming through his stereo. I thought he would kill me. He was actually impressed that I figured out how to do it.
GitFiddle is offline   Reply With Quote
Old 10-07-2013, 12:47 AM   #15
MineGoesTo11
MineGoesTo11's Avatar
Where it's at:
My YouTube Channel
MineGoesTo11 is offline   Reply With Quote
Old 10-07-2013, 01:19 AM   #16
nauc
nauc's Avatar
id stick to a receiver and an iPod or something similar
without a nice tube amp ($$$$), Project turntable (or better, $ wise) and $$$ speakers, it probably wont be worth it
note, to my ears, AAC audio files at 256kbps sound like cds. i probably couldnt pick which is which to save my life. mp3s sound dirtier
fwit...
my HT setup... Onkyo 7.1, Onkyo speakers and sub
car setup... Alpine 9887, Oz Elite 6.5" comps, RE SE sub (sealed), Cadence amps
Gibson Les Paul Studio (R.I.P.)
Peavey Classic 30 (R.I.P.)
nauc is offline   Reply With Quote
Old 10-07-2013, 01:45 AM   #17
parts
parts's Avatar
Old soldiers do die..sometimes not all at once..
....sing the solid body electric..
..Trying to remember how to play again..
The Parts left of me..
http://www.soundclick.com/bands/defa...&content=music
parts is online now   Reply With Quote
Old 10-07-2013, 11:34 AM   #18
Tone deaf
Tone deaf's Avatar
The signal from a 'standard' turntable is different from the "line level" of a CD or ipod. I would doubt that a turntable from Target (no disrespect to Target, I shop there, occasionally) would require a pre-amp (whether stand alone component or integrated into a receiver or an integrated amp) that has a phone stage (the electronics needed to equalize the signal from the turntable to make it more useable by boosting and attenuating certain frequencies). "Phono" inputs used to be the norm on amplification devices however, they fell by the wayside, some time ago due to the demise of vinyl and the added expense of the electronics. Now, if your pre doesn't have phono inputs, you'll need a "phono stage" (little black box with the 'antiquated' electronics in it). Cheap phono stages run a couple hundred bucks. Tube phono stages can run you several thousand. If you were really interested, find some used gear from the 70's and 80's, they will have phono stages built in.
I agree with Nauc, enjoying vinyl is best done (in our opinions) with tubes. If you just want to hear 90% of the original performance, free of hiss, pops and other imperfections, you are far better off with an ipod and some good cans.
With vinyl, the signal is always analog (i.e. is never digitized) and therefore the elements of the signal can be quite nuanced and very similar to the condition they were in when they reached the performer's mic or the mixing board. I like to think of the edges of the signal being rounded or soft. However, digitized signals have 'square' edges (it's a "1" or a "0" and nothing in between). Think about the TV picture when it gets a weak digital signal and it looks like Monet was painting perfectly square boxes. Conversely, DACs (digital to analog converters) convert digital signals into a form that the amplifiers can amplify. Good DACs aren't cheap, either (it takes some expense and engineering to put that digital signal back to its original condition (as it entered the mic or mixing board). I think vinyl is often a truer representation however, it is an inferior technology.
Plus, the warmth of the vinyl signal combined with the 'punch' of tube amplification is a little slice of heaven.
Bite-me
Forum Jump
