MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Other Single-Cuts
Thread Tools Display Modes
Old 11-29-2008, 05:29 AM   #1
Knarbens
Knarbens's Avatar
Arrow Pots of my Orville
Yesterday I took a screwdriver and removed the backplate of my Orville to take a look inside. I don't know anything about guitarelectronics, so you guys have to tell me what you see - a mess right? Well, I removed the knobs, as I wanted to straighten the pointers (They were very crooked - see it on the pic ...). I just grabed the knob with my fingers and pulled it a little - it came of really easy . I think about replacing the stupid speed knobs (not a fan of those) with golden Gibson USA bell knobs. Woun't be a problem, right?
Here's my Orville after I put all knobs back on! Just reversed the TRC on this pic - thought it could be interessting ... The first is my Orville, the others guitars are out of photoshop, because I was bored!
... turned from a Les Paul enthusiast into a guitar building addict.
Knarbens is offline   Reply With Quote
Old 11-29-2008, 06:21 AM   #2
b-squared
Re: Pots of my Orville
The electronics look fine--If it was mine I'd probably upgrade the caps to some good paper-in-oil, or as a minimum some Orange Drops.
MLP member Jonsey is the guy to PM regarding caps--they will make a difference.
If the pots don't taper like you want, save up a little $ and give RS Guitarworks a call...they make a great pot called the Superpot for volume; the combination of that and new caps made a dramatic difference in how my R9 sounded.
Nice guitar! Reversing the TRC was an interesting idea.
BB
b-squared is offline   Reply With Quote
Old 11-29-2008, 06:45 AM   #3
Knarbens
Knarbens's Avatar
I wrote RS Guitarworks a few days back and I got e-mail response. Here's the whole message I got back:
Hello Frank,
For an Orville I would suggest changing out the whole electronics harness to RS Guitarworks Online Store
You will have much better function and tone if you remove all the Japanese parts that came from the factory. This kit has parts that are much better than what is found on any new Gibson guitar.
Thanks
Roy
I heard a lot about these orange drops. Do I have to get these anyhow if I buy the RS guitarworks electronic kid or is there no need to do this?
Old 11-29-2008, 07:03 AM   #4
b-squared
RS will send you everything you need. No need for the Orange Drops, they ship PIO caps with their kits.
It'll look something like this when you get done:
This MLP member Brettk7's Epiphone after we installed an RS kit. It sounds great--I'd put it up against any stock USA Standard in my local GC.
BB
Old 11-29-2008, 07:09 AM   #5
Knarbens
Knarbens's Avatar
Well, that's great! Thanx for your help b-squared
Old 11-29-2008, 10:58 AM   #6
doublecut
You can change the pots and caps if you want but the pots in your Terada made K Orville are exactly the same high quality Japanese made pots that the most expensive (close to 3000 US dollars) G serial Orville by Gibsons had. A lot of the serial numbered Orvilles (not K Orvilles) made by Fujigen had smaller pots that were probably made in Korea and these might be good to replace.
doublecut is offline   Reply With Quote
Old 11-29-2008, 07:49 PM   #7
nathanmanansala
nathanmanansala's Avatar
the shafts on those asian pots might be too small for gibson knobs. if you're not changing the pots, you should buy metric knobs
something you could try before plunking some cash on parts is converting to 50s style wiring.
nathanmanansala is offline   Reply With Quote
Old 11-30-2008, 04:42 AM   #8
Knarbens
Knarbens's Avatar
I was told (I red), that Gibson USA knobs will fit these K-serial Orville pots not perfect, but they will! They're nearly about the same size? Someone know exactly?
Old 12-01-2008, 05:59 PM   #9
nathanmanansala
my bad. "orville by gibson" guitars are supposed to have US made pickups and electronics. "orville" guitars have MIJ pickups and electronics. the pots look like they're labeled "japan". i could be wrong though.
Old 12-02-2008, 05:43 AM   #10
doublecut
The Orville by Gibsons have Gibson pickups and the pots are Japanese made. The early Terada made Orvilles which are the K Orvilles from 1989-1993 have the same Japanese made pots as the Orville by Gibsons. The early Fujigen made serial numbered Orvilles which start from 1993 and end in 1998 also have Japanese made pots but around 1994 Fujigen started using small pots which are probably Korean.
There is nothing wrong with the Japanese made pots. They are high quality pots, full stop, and replacing them is not worthwhile unless they are the smaller pots from the later 1994-1998 serial numbered Orvilles which often had small pots and even the small pots are ok. The Japanese make pots as well as everything else they make.
Old 12-02-2008, 01:26 PM   #11
Knarbens
Knarbens's Avatar
Yeah, thank you doublecut!
The head of the bridge/tone poti is damaged (kind of crooked) and I can't get the knob on it again! So I think I have to replace at least that one!
Old 12-02-2008, 01:38 PM   #12
b-squared
Do yourself a favor and get the RS Superpots. Believe me.
BB
Old 12-02-2008, 01:54 PM   #13
Knarbens
Knarbens's Avatar
Well, I really thinking about the RS thing! ... Propably a whole new kit or just the pots? I'll see ...
Old 12-02-2008, 02:06 PM   #14
joebonsai
joebonsai's Avatar
Hi Knarben
I agree with b-squared 1000%!!!! That RS stuff is excellent, maybe you need some new knobs and make the wholes a bit bigger, but that's no probelm. I've got a RS Vintage Upgrade kit in combination with Seymour Antiquities.....and that's it !!!!
joebonsai is offline   Reply With Quote
Old 12-02-2008, 02:21 PM   #15
b-squared
If you're going to get anything from them, get the kit and replace everything.
I like the 50's wiring setup, myself, and they include a wiring diagram that's easy to follow. If you have any questions, just call them and ask for Billy--he's the man. In fact, their website has a pic of him working on my R9:
He's a great dude--very knowledgeable, and a heck of a slide player.
BB
Old 12-02-2008, 06:02 PM   #16
nathanmanansala
my RS kit got here middle of last week.
stupid me forgot to order the knobs too. i guess the stock pots and caps are staying on the edwards e-lp-98lts til i order the knobs from RS. i haven't really tried though. maybe the stock knobs fit the RS pot shafts.
i switched to CTS pots on the burny RR and the pot shafts wouldnt fit into the knobs without a bit of a pinch. even then they wont go all the way in.
so that'll be 2 sets of knobs for my next shipment.
Old 12-02-2008, 06:13 PM   #17
b-squared
Standard Gibby knobs will fit on the RS pots...a few bucks at your local music store.
BB
Old 12-02-2008, 11:20 PM   #18
doublecut
Pots pots pots. Change them if you want to. They won't give you a great new sound. I have CTS pots on my early 70s Gibson SG and the current pots Gibson are using on my Gibson 2006 LP Jnr and they do the same thing as the Japanese pots in my Orville which I'm not changing.
I have a 2005 Chinese Squier and those pots needed changing because they were a bit scratchy and weren't made that great but the large (not small) Orville pots are just fine and a much higher quality that's about the same as the CTS pots and my Orville pots are still going great after nearly 20 years and the same goes for my 1979 Greco Japanese made pots which are just fine and are still going great after nearly 30 years.
Old 12-06-2008, 10:17 AM   #19
markophonic
markophonic's Avatar
I have an Orville Goldtop that I'm replacing the electronics. I'm waiting on an RS kit to arrive that is going in a 2008 LP standard faded and I'm taking the guts from it (which really aren't bad) and installing them in the Orville along with some Russian PIO caps.
markophonic is offline   Reply With Quote
Old 12-07-2008, 06:17 AM   #20
Knarbens
Knarbens's Avatar
Is this a K-serial Orville, markophonic? Looks like you have historic spec rings installed! Have you?
Old 12-11-2008, 10:19 AM   #21
markophonic
Yes it is a K model.
Yes on the rings too. I didn't install them though... the previous owner did.
Fabulous Guitar!
Old 12-14-2008, 06:33 PM   #22
Knarbens
Knarbens's Avatar
Fabulous Guitar!
Do you know the brand of them? Are these Gibson Historic Spec rings or Angel, Fatboy, ... From what I can tell by looking at the picture, the colour looks pretty nice to me!
Old 07-20-2009, 07:55 AM   #23
Knarbens
Knarbens's Avatar
After a long time I'll do what I once sad ... changing parts of the electronic. I'd like to order from the UK so fake58 is the site for me Electrics
can you tell me what's good stuff? The main things I'd like to replace are the 3-way switch (the long switchcraft one right?) the pots (as mine are kinda crooked) and the caps ... What pots are the right ones? CTS 500k long shaft right? What about these "Upgrade wiring kits" for Gibson? I don't understand a lot of electronics ... I know, that the RS stuff is probably better, but all I wanna do is make my Orville completly functional again and improve the sound a little!
Old 07-20-2009, 08:20 AM   #24
jonesy
GLOBAL WIRING GURU
jonesy's Avatar
I left you a message on your profile about wiring/cap upgrades bro
Old 07-21-2009, 05:20 AM   #25
Knarbens
Knarbens's Avatar
Once I red here in the forum, that the K-serial Orvilles like mine have lang shaft pots!? Mmh ... I have Gibson knobs installed! And what about the toggle switch? I want the nut to look like in the first picture (deep threaded nut): The second is my switch - a really short one. Actually I wanted to go with a straight switchcraft switch! Is that possible?
Old 07-21-2009, 05:33 AM   #26
Knarbens
Knarbens's Avatar
So I guess this one will fit?
Switchcraft troggle switch, for Humbucker, Made in USA. bei eBay.de: Für Gitarren (endet 19.08.09 22:05:21 MESZ)
And this one seems to be too short to reach thru the top!?
Old 07-21-2009, 05:33 AM   #27
Knarbens
Knarbens's Avatar
The right second link!
Switchcraft troggle switch, for Humbucker, Made in USA. bei eBay.de: Für Gitarren (endet 08.08.09 19:04:27 MESZ)
Old 07-21-2009, 07:33 AM   #28
jonesy
GLOBAL WIRING GURU
jonesy's Avatar
From where I am sitting looks like the switch is short and from what I can see in the control cavity your pots are short also, you may not need the long shaft pots for your Orvile?
Old 07-21-2009, 08:24 AM   #29
UITA
UITA's Avatar
Can't say I've come across long pots in any of my Orvilles.
[12:15] Stupid people always think they are right. Wise people listen to advice.
UITA is offline   Reply With Quote
Old 07-21-2009, 09:49 AM   #30
Knarbens
Knarbens's Avatar
Okay, so let's show you the pots.
These are short ones right?
Question ones again:
This switch might be the right one, right?
mine:
and the one I'm willing to buy:
Forum Jump
