MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Gibson Les Pauls
Thread Tools Display Modes
Old 10-23-2012, 03:45 PM   #1
bada222
Sound when volume knob is at 0
Hey folks,
My Les Paul Custom's Bridge Pickup's volume knob seems to be acting weird...
Even with the volume knob rolled down to 0, there's sound when I play.
Its not the same with the neck pup where it will mute correctly when the volume is at 0.
I'm guessing its the pot thats bad, and does anyone think/know that this issue is actually effecting my tone at the same time as well?
Thanks.
bada222 is offline   Reply With Quote
Old 10-23-2012, 03:49 PM   #2
deadringer
deadringer's Avatar
Re: Sound when volume knob is at 0
Sounds like the far right lug is not grounded to the back of the pot correctly. If you can solder, just heat it up and re-ground it. Otherwise take it to a tech. If that doesn't fix the problem, then replace the pot.
deadringer is offline   Reply With Quote
Old 10-23-2012, 03:53 PM   #3
upl8tr
upl8tr's Avatar
Don't jump to conclusions about faulty pots, it may simply be that the knob is misaligned.
Remove the knob (use a shoe lace or rag if it's stiff) and turn the barrel down to zero then check to see if there's still sound, if not place the knob back on in the right position and you should be good to go!
(If it's still the same then yer you're prolly looking at the pot.)
upl8tr is offline   Reply With Quote
Old 10-23-2012, 05:55 PM   #4
BWOTW
BWOTW's Avatar
Defintely a wiring issue, try these suggestions above! My Yamaha SG also did this, but it was a 35 year old guitar that probably hadn't had an electronics check up in quite some time. Never bothered me, though
BWOTW is offline   Reply With Quote
Old 10-23-2012, 10:24 PM   #5
Thiago
Why would anyone need to take the knob off to roll the barrel all the way down to 0? Just roll it till it stops! The numbers are just refference...
Thiago is offline   Reply With Quote
Old 10-23-2012, 10:28 PM   #6
Gibsonrocknroll
Gibsonrocknroll's Avatar
Originally Posted by deadringer View Post
sounds like the far right lug is not grounded to the back of the pot correctly. If you can solder, just heat it up and re-ground it. Otherwise take it to a tech. If that doesn't fix the problem, then replace the pot.
+1
Gibson Les Paul Standard Faded Tobacco Burst
Gibson Les Paul Standard Faded Honey Burst
Gibson Les Paul Traditional Pro Goldtop/Darkback
Gibson EDS-1275 Custom Shop
Gibson Melody Maker
Gibson SG Standard
Danelectro DC-59 Reissue
Marshall JCM 2000 DSL 100W
Marshall JCM 900 Lead 1960A
Hiwatt Custom 100W Jimmy Page
Fender Mustang III
Orange Crush 20LDX
Gibsonrocknroll is offline   Reply With Quote
Old 10-23-2012, 11:24 PM   #7
vulture
vulture's Avatar
Keep it on 10, or 11.
vulture is offline   Reply With Quote
Old 10-25-2012, 11:40 AM   #8
martin6string
Exactly.
The probable fix has already been mentioned. Re-heat the ground tab on the pot and flow a bit of fresh solder.
martin6string is offline   Reply With Quote
Forum Jump
