MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Epiphone Les Pauls > Other Epiphones
Thread Tools Display Modes
Old 08-21-2012, 08:11 AM   #1
elche
elche's Avatar
Epiphone SG G400 China with neck binding
Hi, I'm looking for an SG with neck binding after having seen the Barcham MIK (and some other ones here and there...): I've found a 2009 Vintage Cherry that seems to be MIC (according to TRC shape).
It does have a nice neck binding and it comes in the matte finish that I prefer.
It sells for 180 euro (about 230 USD) including a hard case.
Is it common to find a MIC SG with neck binding?
Thanks
EDIT: I've found these pictures (http://www.sheltonsguitars.com/2008/...n-8-13-08.html), I was convinced that all MIK's had the "GIBSON" TRC while this one looks exactly like the one I've found (except for the color). Is this the same quality that Barcham claims for his one?
elche is offline   Reply With Quote
Old 08-21-2012, 09:10 AM   #2
purevilpleasure
purevilpleasure's Avatar
Re: Epiphone SG G400 China with neck binding
Hate to say it...but no one will be able to say until you have your hands on it and see how it plays....you have good and bad...each one is different from one to the other. I'm sure it will be just as good as any other Epi.
Me on Facebook.......
Donk’s FB
purevilpleasure is offline   Reply With Quote
Old 08-21-2012, 11:04 AM   #3
NovaSDF
I have a made in China g-400 and it's really not a bad little guitar, especially for the price. I like to custom mod guitars, so the Epi was the way to go. Installed CTS pots, PIO caps, custom pickups. Nice sounding guitar.
The only issue (common with most Epis) is that the frets may not be as perfectly level as you would like. I found that I was able to get a pretty low action height of around 4/64 with some stiffer strings (Dunlop Heavy Core .10's) but had to spend some time tweaking the truss rod and bridge. No buzz, which is good.
I'm not a fan of the Epi ABR-1 bridge, but you can replace it with a Gotoh for about $30 (US).
When you consider the cost of the guitar + the cost of paying someone to level the frets (unless you can do it yourself), you're still saving a lot of money vs. a Gibson for a very well built little guitar.
I love mine. (Well, I do now.)
Two things you should never forget: 1 - The only time it's okay to work with amateurs is if you're making porn 2 - If you want to work with clowns, join a circus!
NovaSDF is offline   Reply With Quote
Old 08-21-2012, 12:11 PM   #4
Barcham
Elitist Club Member
Barcham's Avatar
The one in the pictures is a 2005 made in Korea. Nothing to worry about with the TRC. They vary from year to year and factory to factory. My vintage is Saein made in 2004 and is marked SG on the TRC. My friend's is a 2003 Unsung and is marked Gibson I think. So it's nothing to worry about. If you found one that MiC, I'd expect it to be of similar or equal quality and a 2009 would be one of the last ones ever made.
That's a great price by the way, especially with a hard case in the deal. These are great guitars, in my opinion the best SGs Epiphone has ever made other than Elitist and other MiJ models. For that price I'd jump on it! You definitely won't regret it.
'04 Epi Elitist '61 SG Faded Cherry
Roland Micro Cube
The Guitar Dater web site does NOT help you determine if a guitar is real or fake. It ONLY decodes the serial number according to a set formula. They have no database of guitars.
Barcham is offline   Reply With Quote
Old 08-21-2012, 04:18 PM   #5
El Greco
El Greco's Avatar
Are you sure that it's MIC? AFAIK the MICs don't come with neck binding! Maybe you should find more info about this guitar (serial number, photos)! The TRC as Barcham said varies! Mine is a 2006 MIK and have the SG TRC like Barcham's but I have seen the gibson also but in older models (pre 2004 I think)! You can find info here SG - The Unofficial Epiphone Wiki about this model! If it is a MIK Vintage G400, this price is a steal, go for it!
El Greco is offline   Reply With Quote
Old 08-21-2012, 04:31 PM   #6
El Greco
El Greco's Avatar
The neck and fingerboard are awesome! Also you can recognize the MICs from the veneer top and back, the MIK Vintage G400s don't have!
This is the MIC
This is the MIK
Also some info here http://www.mylespaul.com/forums/epip...xperience.html
I hope that I helped!
Old 08-21-2012, 06:18 PM   #7
Barcham
Elitist Club Member
Barcham's Avatar
Vonserke is correct, I believe. Now that I've had time to give it some thought, I don't recall ever seeing a vintage G-400 with the bound neck that was MiC. All the ones I've seen were made in Korea and I've never seen one dated newer than 2005, maybe 2006.
Another important difference between the earlier Vintage series, besides no veneer and the binding, and the newer faded models is that they have a one piece neck. I believe it's the only Epi to have a one piece neck apart from MiJ guitars.
Roland Micro Cube
Old 08-21-2012, 06:43 PM   #8
elche
elche's Avatar
Sorry about the confusion, I was sure it was a MIC since the seller told me the guitar is from 2009 and also because I believed that the TRC on MIK was the one with the two lower screws a little bit higher and the GIBSON engraving, as on MIK LP's.
Now that I've learned (thanks MLP...) that the TRC can be different and noted the differences in grain I'm quite sure it's a MIK, just waiting for a SN picture and then I think I'll go for it!!!
Thanks all for the precious infos, I'll let you know!
Old 08-21-2012, 06:51 PM   #9
elche
elche's Avatar
Just another question: I've read in the specs for the MiK Vintage "USA designed pickups", are they different from the ones found in MiC?
Old 08-21-2012, 08:44 PM   #10
Barcham
Elitist Club Member
Barcham's Avatar
I wish I could help you regarding the pickups but mine had Seymour Duncans installed when I got her. My friend's has the stock pups and has no complaints about them at all. Maybe someone else could fill in some more details about the stock pups.
Here's the original Epiphone news release on this model.
Epiphone - Vintage-G-400--Why-Is-This-Guitar-Shaking-Up-The-Industry-
Roland Micro Cube
Old 08-22-2012, 03:21 AM   #11
El Greco
El Greco's Avatar
The stock pups are good (for my ears), and they have higher output than the later G400 pups (as far as I can tell). The ''USA designed'' means nothing to me, all the Epi pups are USA designed! So it's up to you to decide if the pups are good or need replacement! When you receive some photos please post them, It will be helpful! Good luck my friend!
Old 08-22-2012, 09:10 AM   #12
elche
elche's Avatar
UPDATE:
I've received some more pictures, I'm now sure it's the MiK Vintage Cherry I'm looking for!!!
It's a 2006 Unsung (right?), it has some small wear signs (small dents on the headstock, some oxidation on pups screws and a tuner to be replaced) but nothing too serious, I'm trying to get it for 170 € including a nice hard case and some accessories.
What do you think?
Old 08-22-2012, 12:38 PM   #13
El Greco
El Greco's Avatar
wtf? It's the same factory, year, month and color like mine! Grab it elche! It's April 2006 Unsung Korea
Here is mine the day that I bought it, now has different tuners
Old 08-23-2012, 03:28 AM   #14
MrGansburg
MrGansburg's Avatar
Originally Posted by elche View Post
UPDATE:
I've received some more pictures, I'm now sure it's the MiK Vintage Cherry I'm looking for. It's a 2006 Unsung (right?),
€170 for this and a HSC is a great price. Good luck with it.
MrGansburg is offline   Reply With Quote
Old 08-23-2012, 11:44 AM   #15
paruwi
€piWiki Team
paruwi's Avatar
[url]http: //w w w.couponsavings.sh!t/ewa/girl.jpg
[url]http: //w w w.couponsavings.sh!t/for/girl2.jpg
Yeah, and you're a ****ing dumba$$ spammer......
PeteR
I don't have any reason to lie to you - I just do it for fun
paruwi is online now   Reply With Quote
Old 06-02-2013, 03:13 PM   #16
serch777
Hi guys, what Epi model are these? Elitist?
Guitars:
Gibson Les Paul Classic Custom cream
Gibson Flying V ebony
Gibson SG standard ebony
Amp:
Peavey 5150 2x12 60w combo
Speakers:
WGS 12'' HM75 75w 8ohm
WGS 12'' RETRO 30 75w 8ohm
Pedals:
Emma Electronic PisdiYAUwot
Maxon OD808
MXR Black Lebel Chorus
BOSS Digital Delay DD-3
BOSS Compression Sustainer CS-3
serch777 is offline   Reply With Quote
Old 06-02-2013, 03:16 PM   #17
Barcham
Elitist Club Member
Barcham's Avatar
Impossible to tell from those pictures alone. They do look like JDM guitars but whether they are Elitists or not cannot be determined without seeing the back of the headstock.
Roland Micro Cube
Old 06-02-2013, 04:08 PM   #18
serch777
Yeah, they have neck biding but the headstock looks a bit different from the Elitist models. Maybe it's the wrong angle, but I'm still confused.
Guitars:
Amp:
Speakers:
Pedals:
Maxon OD808
Old 06-02-2013, 04:42 PM   #19
Barcham
Elitist Club Member
Barcham's Avatar
Nothing to be confused about. Elitists and other MiJ guitars that were made strictly for the Japanese Domestic Market had the Gibson Dove Wing, aka Openbook, headstock. All MiJ Epi Les Pauls and SGs, export and JDM have the Gibson style truss rod cover as well.
Roland Micro Cube
Forum Jump
