MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Gibson Les Pauls
Thread Tools Display Modes
Old 05-03-2012, 02:27 AM   #1
doodles90210
whats under the pickup covers?
Hey sorry if this is a total noob question, but whats under the pickup covers? I got the new 2012 standard. I can kinda see it with a set of cream pups and no covers. If I wanted to switch pickups how does that work with the pcb electronics and all the fancy taps?
doodles90210 is offline   Reply With Quote
Old 05-03-2012, 03:59 AM   #2
blacklist
blacklist's Avatar
Re: whats under the pickup covers?
There's a pickup under those covers ;0
blacklist is offline   Reply With Quote
Old 05-03-2012, 05:40 AM   #3
So What
So What's Avatar
"They say I'm lazy, but it takes all my time." - Joe Walsh
So What is offline   Reply With Quote
Old 05-03-2012, 06:34 AM   #4
Comanche
Comanche's Avatar
I wanted to remove my back pickup cover to have the Jimmy Page look.
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-xpa1/v/t1.0-9/10441310_10202120144872371_3657727741838977044_n.j  pg?oh=d8165b730f0a190b15c113817fb8d85f&oe=54B9961A  &__gda__=1421302540_915f93b7e91e46e3a2ed4c3c12673c  7c
Off the farm.
Comanche is offline   Reply With Quote
Old 05-03-2012, 06:47 AM   #5
Shawn Lutz
Shawn Lutz's Avatar
Chances are they are black but really...there really is no telling until you look. I had 57's in my traditional plus. One was black and cream zebra and the other one was dual black.
http://shawnlutz.com
Shawn Lutz is offline   Reply With Quote
Old 05-03-2012, 06:52 AM   #6
BigAl
BigAl's Avatar
Dragons.
Once I stopped chasing tone,
it
stopped running away.
BigAl is offline   Reply With Quote
Old 05-03-2012, 06:54 AM   #7
kdm
kdm's Avatar
if you wanna look like Jimmy Page....you need more than that.....
kdm is offline   Reply With Quote
Old 05-03-2012, 08:59 AM   #8
Quicksilvergoat
I just had my covers removed from my Traditional Mahogany. The neck pick up is nice and clean. The bridge looks atrocious. A ton of excess wax on it and the tape they wrap them with was overlapping the top of the pick up. Seriously considering putting the covers back on. Both of my pick ups are black.
Quicksilvergoat is offline   Reply With Quote
Old 05-03-2012, 09:41 AM   #9
dspelman
You can simply pull the existing pickups (the covers stay with them) and put in a different set of pickups. You'll want to make sure that you get a set of four-wire pickups (this allows you to coil tap) rather than two-wire. A decent tech will be able to install them with pcb electronics and coil taps intact. Keep the old pickups with the guitar in case you decide to sell it at some point in the future; most people don't consider pickup swaps "upgrades" when they're *buying* a used guitar (though most folks consider it an upgrade when they own the guitar, of course), and will want the originals available.
dspelman is offline   Reply With Quote
Old 05-03-2012, 09:51 AM   #10
kdm
kdm's Avatar
there lays tone.....
Old 05-03-2012, 10:03 AM   #11
JMV
JMV's Avatar
Most likely double blacks, but you won't know unless you look.
You can find out without taking the covers off, though. Remove one of the polepiece screws and shine a light inside the cavity. Now you know that bobbin color. For the other bobbin, you can carefully remove one of the small phillips screws that holds the bobbin to the backing plate. Same thing as before - you should be able to see the bobbin color through there.
Hope that helps.
JMV is offline   Reply With Quote
Old 05-03-2012, 10:15 AM   #12
Pinkie
+1
Pinkie is offline   Reply With Quote
Old 05-03-2012, 10:22 AM   #13
MineGoes211
MineGoes211's Avatar
There's a screaming Yeti inside my guitar.
MineGoes211 is offline   Reply With Quote
Old 05-03-2012, 11:55 AM   #14
iridereallyslow
iridereallyslow's Avatar
As others have said, under the covers is most likely double blacks, however it is possible to have a zebra or double cream I suppose. I just took the covers off of my 03 Standard last week. I used a razor blade and just cut the solder, then removed the wax and you're rockin!
(sorry the pictures are upside down, I'm a photo noob and was using my phone)
iridereallyslow is offline   Reply With Quote
Old 05-03-2012, 11:57 AM   #15
MineGoes211
Do the pick ups sound louder? Just curious.
Old 05-03-2012, 12:07 PM   #16
iridereallyslow
I should add that I removed the pickups from the rings to take the covers off. When re-installing after I got the covers off, they seemed to me a little louder. After about a minute of playing with the pick up height, I honestly can't tell a difference. The pickups sound exactly the same to me with the covers on or off. If you don't change the height of the pickups in the rings after removing the covers you could possibly have a volume difference, but nothing a slight adjustment shouldn't fix.
Old 05-03-2012, 01:03 PM   #17
Quicksilvergoat
What's a good way to remove the rest of the wax from the top of the pick up without damaging anything? Had my covers removed and my bridge looks ugly. Thanks
Old 05-03-2012, 01:06 PM   #18
Crotch
Premium "Member"
Crotch's Avatar
They are double blacks for sure. I emailed Gibson this same question after ordering my 2012 Standard.
15 Gibson ES335 63 Reissue Clapton Tribute
14 Gibson Dave Grohl DG335 Pelham Blue
14 Gibson R9 Sunrise Tea VOS
13 Gibson Les Paul CC7 Shanks
13 Gibson Les Paul Standard Bonamassa LTD. GoldTop
09 Gibson SG Robby Krieger CS Cherry VOS
17 Fender Custom Shop Eric Clapton Journeyman 2TSB
13 Fender Custom Shop Eric Clapton Strat Mercedes Blue
96 Fender Jagstang Sonic Blue
94 Fender Custom Shop American Classic Strat White
70 Fender Stratocaster Black
Friedman Small Box
Marshall SL5 Combo
Crotch is offline   Reply With Quote
Old 05-03-2012, 01:06 PM   #19
Jackassrock
Jackassrock's Avatar
Just scrape it off with something dull enough not to scratch up your bobbin. Then wipe vigorously with a rag.
Jackassrock is offline   Reply With Quote
Old 05-03-2012, 01:27 PM   #20
Quicksilvergoat
Thanks for the response. I'm at the rag stage then. One last question. I mentioned earlier the tape that's wrapped around the pick ups overlapped the top a bit. Is that tape a available so I can rewrap them? I just want to clean up the look. It was too much for me to expect the local shop to do it when they removed the covers. Here on out doing everything myself.
Old 05-03-2012, 01:31 PM   #21
Jackassrock
Just pull off some of the tape and cut it. It's not a big deal really. It should be wrapped around a couple tines. If you want to replace it thats fine too. You could wrap it with electrical tape if you want to. You won't see it from the top.
Old 05-03-2012, 01:59 PM   #22
Webtroll
Webtroll's Avatar
Doesn't another thread indicate there's unicorn dandruff under them?
Webtroll is offline   Reply With Quote
Old 05-03-2012, 02:04 PM   #23
babatube
babatube's Avatar
pure evil
^^Pawel Kuczynski
babatube is offline   Reply With Quote
Old 05-03-2012, 03:47 PM   #24
Lurko
Lurko's Avatar
Ich bin ein NERD.
Lurko is offline   Reply With Quote
Old 05-03-2012, 04:08 PM   #25
Lowdown
Lowdown's Avatar
Yes. That's right. Unicorn Dandruff all working in tandem to produce Tonal Moleculation
[IMG]http://i590.photobucket.com/albums/ss342/wyreandwood/Forum%20****/Translational_motion.gif[/IMG]
They will look like this -
Caked in excessive wax.
Lowdown is offline   Reply With Quote
Old 05-03-2012, 04:56 PM   #26
Shawn Lutz
Shawn Lutz's Avatar
wow, mine had hardly any wax on the bobbins at all.
Old 05-03-2012, 05:01 PM   #27
phil b
Just an FYI, Dimarzio actually holds the rights to double cream, So you wont see that color on any new pups that arent from them. I have seen some small boutique makers that have gotten away with it, but thats about it. Who woulda thought!!
phil b is offline   Reply With Quote
Old 05-03-2012, 05:05 PM   #28
Zack
Zack's Avatar
a solid layer of unrefined sex
Everybody knows valves are better.
Zack is offline   Reply With Quote
Old 05-03-2012, 06:01 PM   #29
Kalamazuu
Kalamazuu's Avatar
Yep, I was just about to say that. They won't be double cremes. However, Gibson did do a run of pickups (I think BB pros, and I want to say like 400 or 200 of them?) and I've seen a one-off '57 Classic that an employee made.
Kalamazuu is offline   Reply With Quote
Old 05-03-2012, 06:50 PM   #30
Shawn Lutz
Shawn Lutz's Avatar
the way around that used to be sell them with covers, chrome/nickle etc. I think Seymour Duncan has even stopped doing them as well. You could custom order say a JB in double cream with a chrome cover...and then just remove the cover.
Forum Jump
