MyLesPaul.com
Go Back   MyLesPaul.com > Music Gear > The Squawk Box
Thread Tools Display Modes
Old 05-01-2012, 03:48 AM   #1
logen99999
tweaker tube swap, put el34s in and it sounds mehh
hey guys. my stock 6l6s in my tweaker crapped out so i bought some el34s, stuck them in and it does not sound great. very muddy when you crank it. and somehow my guitar actually sounds out of tune.
what are some recommendations for tubes for this amp? my preference is for cleaner tones since i can always boost it with a pedal. at this point i'm leaning back to 6l6s. was wondering what other tubes or tube brands you guys use to get good tones in the tweaker.
logen99999 is offline   Reply With Quote
Old 05-01-2012, 03:52 AM   #2
johnbeloe
johnbeloe's Avatar
Re: tweaker tube swap, put el34s in and it sounds mehh
Did you adjust the bias if needed?!
johnbeloe is offline   Reply With Quote
Old 05-01-2012, 03:55 AM   #3
logen99999
its cathode based and self biasing, so no.
Old 05-01-2012, 04:05 AM   #4
johnbeloe
johnbeloe's Avatar
Ok
Old 05-01-2012, 04:12 AM   #5
Bandit79
Bandit79's Avatar
It probably sounds crappy because your amp has a output transformer designed for 6L6's.
You can't just put any ol' tubes in an amp.
Gear: Too Much To List
"White collar conservative flashin down the street, pointing that plastic finger at me, they all assume my kind will drop and die, but I'm gonna wave my freak flag high."
-Jimi
Originally Posted by TOMMYTHUNDERS View Post
so, essentially the way a 401k works is you work for 401,000 years and then you get 3 twist donuts.
Bandit79 is offline   Reply With Quote
Old 05-01-2012, 05:30 AM   #6
Backstage
Backstage's Avatar
Like filling diesel into a regular motor .
Backstage is offline   Reply With Quote
Old 05-01-2012, 06:29 AM   #7
Bandit79
Bandit79's Avatar
I'd like to add, you can put KT66's in your amp, since your tweaked runs off 6L6's.
I never really cared for 6L6's myself. Give the KT66's a try. They're much more colorful.
-Jimi
Old 05-01-2012, 06:51 AM   #8
TOMMYTHUNDERS
TOMMYTHUNDERS is offline   Reply With Quote
Old 05-01-2012, 03:43 PM   #9
logen99999
the amp is designed to run different tubes. there are plenty of people that put el34s in it.
but yeah i'll probably buy n ew 6l6s and go with that.
Old 05-01-2012, 04:57 PM   #10
Bandit79
Bandit79's Avatar
We're talking about the Egnator Tweaker 40, correct?
Yes, it's designed to be able to handle different tubes, damage wise. The plate voltage of the amp is not meant for EL34's. Putting different tubes in that amp won't hurt the amp for awhile, but the Output Tranny isn't designed for EL34's, so it's not going to sound like it should. It will need to be modded to sound proper with EL34's.
I've owned around 30 different amps in my life, including the Egnator tweaker 40. It's a good amp, but it's designed to use 6L6(6550, KT66 as well) type tubes.
Btw, what brand tubes are you using?
-Jimi
Old 05-01-2012, 05:00 PM   #11
River
River's Avatar
Questions are better asked before than after.
Old 05-01-2012, 05:26 PM   #12
logen99999
they are JJ el34s.
what you're saying makes sense. also it's the 15 watt tweaker, not the 40.
Old 05-01-2012, 06:39 PM   #13
HRC
HRC's Avatar
The 15 watt tweaker comes with 6V6 tubes not 6L6...
If You Can't Play 'em, Relic 'em
Bluesville Junction
The more you drink the better I sound
Vape-R-Holics - e-Cig and Vaping Forum
HRC is offline   Reply With Quote
Old 05-01-2012, 06:59 PM   #14
logen99999
my mistake, i confused them.
Old 05-01-2012, 07:01 PM   #15
HRC
HRC's Avatar
I'm taking it you also confused El34's for EL84's?
Bluesville Junction
Old 05-01-2012, 07:07 PM   #16
michaelinokc
michaelinokc's Avatar
I'm running a pair of matched JJ 6V6's in my Tweaker and it sounds absolutely incredible. You can use any octel tube in the Tweaker, but if you liked the sound before, put some 6V6's in it.
Too many guitars to list anymore. It's a sickness, and I like it.
michaelinokc is offline   Reply With Quote
Old 05-01-2012, 08:58 PM   #17
logen99999
nope
Old 05-01-2012, 09:01 PM   #18
Cygnus X1
Cygnus X1's Avatar
Wow.
Where did RH1 go?
Am I going to have to deal with this myself?
Cygnus X1 is offline   Reply With Quote
Old 05-01-2012, 09:08 PM   #19
Cygnus X1
Cygnus X1's Avatar
http://www.egnateramps.com/manuals/TweakerIM.pdf
Old 05-01-2012, 09:32 PM   #20
Bandit79
Bandit79's Avatar
they are JJ el34s.
Okay, now things are coming together much more.
Your amp runs 6V6's. Essentially the 6L6's younger brother. You would want to run EL84's if you wanted a sound similar to EL34's. You can safely run the EL84's as they don't change the load of the Output Tranny like 6L6's to El34's do.
If you want to run the bigger tubes, you'll need the "88 mod" done to your amp. You can do more research on that mod via google if you'd like, as I don't know too much about it.
-Jimi
Old 05-01-2012, 11:21 PM   #21
dleuen
dleuen's Avatar
I've had the best tones from a good set of 6V6 tubes. I had EL34's for a while but finally pulled them and put in some JJ 6V6 GTs. This I like.
dleuen is offline   Reply With Quote
Old 05-02-2012, 05:43 AM   #22
Cygnus X1
Cygnus X1's Avatar
How would this amp take EL84's?
It has octal sockets for the power tubes.
Anyhow, EL34s are good for some circuits but not others.
I generally find that amps designed for 2x6V6GT's don't sound very good with
substitutions.
Old 05-02-2012, 06:05 AM   #23
Bandit79
Bandit79's Avatar
substitutions.
An octal adaptor would let you use the EL84's.
-Jimi
Old 05-02-2012, 10:36 AM   #24
LPV
LPV's Avatar
Why not just get a good set of 6v6's ? I'm guessing its cathode bias so if they say you can run el34's you probably won't damage the OT. But they aren't going to sound like el34's because you aren't getting 450vdc+ on the plates or the resistance at the OT so they aren't running in their curve.
LPV is offline   Reply With Quote
Old 05-02-2012, 10:43 AM   #25
michaelinokc
Here's a great article about modding a 15 watt Tweaker, using a variety of tubes.
Egnater Tweaker with EL34 mod! - 12fret.com : The Twelfth Fret Guitarists' Pro Shop, Repair Shop and Lessons., Toronto Ontario Serving Musicians Worldwide since 1977
Old 05-02-2012, 10:57 AM   #26
TOMMYTHUNDERS
you would be well advised to read that.
and once again, every time i come in this thread.....
Old 05-02-2012, 12:13 PM   #27
sj250
sj250's Avatar
I tried EL34's for a while and eventually went to 6V6 before I sold my Tweaker. I recently grabbed another one used that came with 5881's. I have to say I really really like these tubes in there! Great chimey cleans and awesome crunch when needed. Regardless of tubes though the best thing I ever did was pair it with a Scumback H75. I never liked the stock G12 and when I got the 2nd Tweaker I grabbed an empty 1x12 and put a Scumback in it. Those speakers are fantastic.
sj250 is offline   Reply With Quote
Old 05-02-2012, 01:06 PM   #28
logen99999
i did read it, i decided to try to experiment. in this case the tone wasn't that great from the el34s, so i'm asking for better recommendations before i keep spending money on tubes. what's wrong with that?
Old 05-02-2012, 02:19 PM   #29
TOMMYTHUNDERS
Dude. Why didn't it sound great with EL34s? Can you answer this question? Because I really don't think you're getting it.
Old 05-02-2012, 04:44 PM   #30
logen99999
you're insinuating that it didn't sound great because the amp was designed for 6v6 tubes. that doesn't mean it will sound worst with other tubes, in some cases it may sound better, or just different. in this case i was experimenting with el34s.
the author of this article used el34s, so do many people, they like their results.
just because an amp came stock with some tubes doesn't mean it wont work with others.
also tone down the jerky attitude, otherwise dont comment at all.
Forum Jump
