MyLesPaul.com
Go Back   MyLesPaul.com > Music Gear > Other Guitars > Fender
Thread Tools Display Modes
Old 02-03-2012, 07:29 PM   #1
jokun
jokun's Avatar
Question Jazz bass series wiring with induvidual volumes - possible?
Hey, folks!
I'm trying to get more punch and volume out of my jazz bass and I read about the series wiring and decided it was the way to go.
I realized that most people just bypass one of the volume knobs and use the other one as a master volume, but I don't want to lose the oppurtunity to balance between the pickups.
I tried using this diagram: http://i269.photobucket.com/albums/j...ingDiagram.jpg, but I can only control the volume of the bridge pickup and the neck pickup is allways on. Is this because of the diagram, or have I done something wrong?
Is it even possible to do this?
Also: I don't want to by anymore parts, if else I would have used a blend knob and a master volume. And I don't use a switch.
Thanks!
Håkon
My last signature was stupid, so I deleted it...
jokun is offline   Reply With Quote
Old 02-03-2012, 10:52 PM   #2
coldsteal2
coldsteal2's Avatar
Re: Jazz bass series wiring with induvidual volumes - possible?
they come wired that way, you would have had to rewire them
to end up with that problem.
I have always had seperate volumes for my Jazz pu's so you can
get a good balance, thats the way they are originaly wired
I read up on the series wiring and this is what one of the guys said about it.
"I have just modified my Jazz bass. Basically, jazz bass pickups are wired in parallel, which contributes
to the distinctive sound of the think. Series wiring, on the other hand, gives a punchier, bassier sound and
higher output. The disadvantage of series wiring of jazz bass pickups is that..it doesn't really sound like a
jazz bass any more
. It is less flexible, you can't play the pickups off against each other, and so on."
coldsteal2 is offline   Reply With Quote
Old 02-05-2012, 05:16 AM   #3
jokun
jokun's Avatar
I know they have seperate volumes when they are wired i parallel, but I wonder if it's possible to have seperate volumes when it's wired i series.
And I have no problem with it not sounding like a jazz bass any more...
Old 02-05-2012, 03:31 PM   #4
coldsteal2
coldsteal2's Avatar
well seems like they would work against each other of you
have seperate volumes in series, if you turn one down it will
also reduce the output of the others, see what i mean?
There may be a better way of doing it, maybe buy using a three way switch?
Check around the bass forums maybe someone has a better
method of it
What i did was bought higher output pickups, you can retain the
wiring but still have a fatter output
Old 02-05-2012, 05:07 PM   #5
jonesy
GLOBAL WIRING GURU
jonesy's Avatar
Old 02-05-2012, 06:40 PM   #6
jokun
jokun's Avatar
Thanks guys! I now realize that it is impossible to have seperate volume controls.
Jonesy: What will happen to the volume controls when you pull the switch? I was not planning on getting more parts, but it if will work that way, I will consider it...
On the other hand; Is it possible to have one volume knob for neck volume and one master? Can anybody draw a quick wiring diagram/schematic?
Again: Thanks guys!
Old 02-05-2012, 07:02 PM   #7
jonesy
GLOBAL WIRING GURU
jonesy's Avatar
When the pickups are in parallel you will have separate volume controls. When they are in series they actually run through each other basically how the two coils of a humbucker are wired. So with the switch out and the pickups in series I think just one volume controls both like a master volume.
Old 02-08-2012, 01:29 PM   #8
jokun
jokun's Avatar
So i have searched the web some more and found this schematic: Wiring Diagram
I have tried using that to make a schematic where I can have a master volume, a volume for the neck pickup and a tone control. Can you take a look at it and see if it will work?
Old 02-08-2012, 02:27 PM   #9
MrRhoads
MrRhoads's Avatar
If you have some spare time, bring forth the soldering iron and try it out yourself
It´s a great way to learn.
Couldn´t tell were all wires were running but it might work.
Håkon? Are you Swedish?
Proud user of "JonesyBlues Customshop" parts
T-Top info read this http://www.mylespaul.com/forums/pick...490r-490t.html
Alot of good wiring help http://www.mylespaul.com/forums/tone...g-library.html
Help on soldering http://www.mylespaul.com/forums/tone...ow-solder.html
Capacitor info http://www.mylespaul.com/forums/tone...apacitors.html
MrRhoads is offline   Reply With Quote
Old 02-08-2012, 02:59 PM   #10
jokun
jokun's Avatar
I just tried it and it didn't work...
The knob that originally worked as a volume for the neck, works as a master volume now(Like it should) and the tone control works just fine.
However, the bridge volume(who was now supposed to be neck volume...) did not do anything at all... Do any of you see what is wrong?
MrRhoads: Why can't you see where the wires go? Is it the picture? I can probably draw a better one if that is the problem...
And I'm from Norway btw... (Which explains my horrible english...)
Old 02-08-2012, 04:58 PM   #11
MrRhoads
MrRhoads's Avatar
It seemed like the black wires from the pickups merged together so it was impossible for to tell which pickup wen´t to which pot.
Norway well then you´re a neighbour...
By the way, just one more month until "Vasa Loppet"
Old 02-08-2012, 05:58 PM   #12
jokun
jokun's Avatar
Yeah, the two black wires goes to the same place... Thats why I drew it like they merged together. As far as I'm concerned, that is what makes them being in series, isn't it?
And you are probably right about vasa loppet too, but I'm no skier and don't really follow all that stuff...
Old 02-08-2012, 07:45 PM   #13
Benjammin
Benjammin's Avatar
I see you already have your answer, so I have nothing to offer, but to say I have a series/parallel switch on my Jazz bass, and I love it, I use that setting more than any other probably. The lack of individual volumes doesnt bother me much, since I usually prefer the neck pickup anyways, and just dial in the amount of bridge I want
Benjammin is offline   Reply With Quote
Old 02-09-2012, 05:13 AM   #14
jokun
jokun's Avatar
Well, I don't exactly have my answer yet... I can't make the neck volume work as it should.
It's good to know that at least it's going to sound good when I'm done!
Old 02-09-2012, 04:48 PM   #15
MrRhoads
MrRhoads's Avatar
I did a drawing, don´t know if it will work
http://www.mylespaul.com/forums/memb...assseries.html
The 1st volume would affect the neck and the 2nd one not sure but i do think they´ll interact with one and other no mather what...
So maybe not completly independet volumes but a little?
Old 02-11-2012, 04:33 PM   #16
Benjammin
Benjammin's Avatar
Well, working as it should means that the neck volume would be the master volume for both pickups (and the bridge volume will still effect the bridge pickup) What it sounds like you want to do, individual volume controls while in series mode, isn't a standard configuration for pickups wired in series, and from my admittedly limited understanding, isn't possible (I have 2 guitars wired as such in addition to my bass) I hope you can find what you're looking for
Old 02-11-2012, 08:22 PM   #17
jokun
jokun's Avatar
I went over all my solderjoints today(and I switched the white and black wire from the bridge pickup, but I don't know if that affected anything...) and now it works almost as it should!
For some reason the knob which used to be the bridge volume now acts as an on-off switch for the neck. It was supposed to be a volume for the neck, but I will just leave it as it is for now.
Thanks for the help, guys!
Tags
jazz bass, series wiring
Forum Jump
