MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Epiphone Les Pauls
Thread Tools Display Modes
Old 10-17-2011, 09:11 PM   #1
waswell
waswell's Avatar
Help with wiring a tone capacitor - HELP PLEASE
I replaced the caps with orange drops and re-wired them back in exactly like they came out - problem is the caps were wired to the tone pots only - just like a Fender Strat.
Here is a link to a different way:
Les Paul Style Wiring Harness - Wiring Harnesses - LP Style Wiring Harness - Tundratone
What will I gain in sound quality if I re-wire them again with the caps bridging the volume pot and tone pots as in the link above?
Did I do it wrong?
Thanks in advance !!!!
waswell is offline   Reply With Quote
Old 10-17-2011, 09:55 PM   #2
purevilpleasure
purevilpleasure's Avatar
Re: Help with wiring a tone capacitor - HELP PLEASE
The original way is called Modern Wiring. The way you want to do it is called 50's Wiring. I wire all my guitars 50's and it has a better tone and response to my ears.
Me on Facebook.......
Donk’s FB
purevilpleasure is offline   Reply With Quote
Old 10-17-2011, 10:00 PM   #3
WildeStarr
WildeStarr's Avatar
Or... you can do the WildeStarr Ultimate Cap Mod.....
WildeStarr: Heavy Metal to the MAX
WildeStarr: "Beyond the Rain" CD coming 2016
WildeStarr "A Tell Tale Heart" CD released October 2012
WildeStarr "Arrival" CD released 2010
www.wildestarr.com
WildeStarr is offline   Reply With Quote
Old 10-17-2011, 11:56 PM   #4
SJM
Premium V.I.P. Member
SJM's Avatar
+1. 50's wiring is the way to go, just like in the diagram you posted. Ground the pots together too, also in your diagram.
______________________________
Steve-M
'52 Martin D-28
'69 Fender Telecaster
'16 Fender Classic 50's Tele
'15 Squier Deluxe Strat
'78 Ibanez Pro Mdl 2671/S-AV
'02 Epi LP Elite Std VSB
'07 Epi LP Elitist Std+ FCB
'10 Epi LP 57 Gold Top
'10 Epi LP Std Plain Top HB
'12 Epi LP 1960 T+ FCB
'12 Epi LP Ace Budokan
'14 Epi LP Custom Classic
'11 Gibson LP Bonamassa Studio
'12 Gibson LP Traditional +
SJM is offline   Reply With Quote
Old 10-18-2011, 02:32 AM   #5
BluePhil
BluePhil's Avatar
Just finished my rewiring few days ago. Used the 50s wiring. Sounds better in my ears I think. Try it.
Epiphone Les Paul '56 Reissue Goldtop
Epiphone Standard Plus TA
Ibanez Strat
BluePhil is offline   Reply With Quote
Old 10-18-2011, 10:14 AM   #6
waswell
waswell's Avatar
Thank you everyone for your comments. I will re-wire the caps this weekend.
Take care
Old 10-18-2011, 10:27 AM   #7
SJM
SJM's Avatar
Take care
Best of luck with your project. Here is a beautiful example of 50's style wiring installed. I wish I could take credit for it.
Steve-M
'52 Martin D-28
Old 10-18-2011, 01:55 PM   #8
purevilpleasure
Here's one I did not too long ago. Dimarzo PAF's in a neckthru.
Donk’s FB
Old 10-18-2011, 04:50 PM   #9
waswell
waswell's Avatar
To clarify - what tone, if any, will I gain if I go from a strat setup (cap only soldered to tone pots) versus a LP setup (cap soldered to volume and tone pot)?
Is it worth the hassle? If so, why?
Will I get a BETTER tone or just a DIFFERENT tone with more flexibility?
Old 10-18-2011, 06:46 PM   #10
purevilpleasure
I say it's a more creamy, responsive, and gritty when turned up. I have an SG with stock everything that was a bit lacking....new Orange Drop and 50's wiring made a huge difference. It was cleaner and when turned up it just growled instead of mudded up.
It's an easy 5 minute change and only you can be the true judge of it.
All I can say is A LOT of people do it.........either they are wrong or something is up with it.
Donk’s FB
Old 10-18-2011, 07:49 PM   #11
SJM
SJM's Avatar
I noticed very similar improvements on an older Ibanez LP I did this with. I too used Orange Drops. I'm doing this mod on all my Gits, in fact I have one harness finished and ready to drop in this weekend. If you look at a new Gibson, you'll notice the caps going from tone pot to volume and everything sits on a grounding plate. Unless of course it's one of the newer ones with a PC board. This is just a better wiring scheme and should at least boost your output and clarity.
Steve-M
'52 Martin D-28
Old 10-18-2011, 11:15 PM   #12
waswell
waswell's Avatar
Great comments and excellent advice. Thank you so much everybody for all your help.
You guys are the best !!!!
Take care
Old 10-19-2011, 01:50 PM   #13
onlypadog
onlypadog's Avatar
I'm planning on doing this with my latest epi standard (11yr old MIK) when I gather all the parts. Will be my first self-mod of an LP. I'm also planning on combining it with Push/Pull Coil Splitting on the Tone pots.
Has anyone done this and know if its the exact same principle as with standard pots?
And - here's another question bugging me - if this is what most people, the most common upgrade if you will - then why is it not stock? Not necessarily with the upgraded caps etc, just the wiring scheme...?
Giggidy giggidy goo
onlypadog is offline   Reply With Quote
Old 10-19-2011, 08:03 PM   #14
purevilpleasure
http://www.dominocs.com/AshBassGuitar/Gibson50s.html
Donk’s FB
Old 10-20-2011, 10:14 AM   #15
waswell
waswell's Avatar
I rewired the whole harness yesterday and used the 50's schematic. I'm still learning the way the volume and tone controls interact with each another but I must say I have more versatility with my tone. It seems cleaner, more defined with maybe a tad more grit at higher volume levels.
The Lindy Fralin PAF's are now singing the blues like they were meant to.
THANK YOU everyone for your comments - they were my muse
Old 10-20-2011, 11:03 AM   #16
SJM
SJM's Avatar
Good to hear. You may notice with 50's wiring that the volume goes from nothing to full blast very quickly. If you can't live with this, there are two ways to fix it. You can find these remedies in the "Wiring Library" in the "Tone Freaks" section. I fixed mine by using 300K Linear Taper volume pots.
Steve-M
'52 Martin D-28
Old 10-21-2011, 03:38 PM   #17
winexprt
winexprt's Avatar
I noticed that when I rewired my 2008 Studio 50's style. Pulled out the horrid PCB that came stock and put 500K CTS pots all around with repro Luxe bees and I love it.
But I'm not too crazy about the steep drop off that happens now. Basically anything below 7 is inaudible.
Did a search of the "Wiring library" for the other remedy besides changing the pots but couldn't find it. I'd really appreciate it if you could tell me what my other option would be besides 300K volume pots. Thanks in advance!
Originally Posted by singlecut View Post
"this guitar will vibrate your nuts off"
winexprt is offline   Reply With Quote
Old 10-22-2011, 05:37 PM   #18
Skit
Witch Doctor
Skit's Avatar
I don't have that happening on my guitars. The volume controls are useful throughout the entire range. Are you using stock pots?
The smoker you drink, the player you get.
-Joe Walsh
Bacchus BFV-2010K
Bacchus Korina Explorer
Bacchus Classic BLP-STD FM
1980 Tokai LS-80
Fender Japan Strat '94 ST54-150AS
Fender Japan Tele TL52-SPL/DP
Fender AVRI '59 Strat
Epi Elitist Faded CB
Epi Elitist '57 Goldtop
Epi MIJ LQ LP Special - Cherry
Epi MIJ LQ LP Special - TV Yellow
Epi Joe Perry Boneyard
1988 Kramer
Brittone plexi
MetroAmp x 2
1966 Fender BF Vibro Champ
Little Lanilei 3350LT
Peavey Classic 20
Fuchs 112
Skit is offline   Reply With Quote
Old 10-22-2011, 08:34 PM   #19
waswell
waswell's Avatar
It is happening on my guitar but it is very manageable so no worries for me. My pots are stock. My volume knob is now between 3-4 where it used to be 6-7 before the mod. Hope this helps
Old 10-22-2011, 10:45 PM   #20
SJM
SJM's Avatar
I'll see if I can find it. I know you add a resistor to each volume pot but I can't remember how it connects.
Steve-M
'52 Martin D-28
Old 10-22-2011, 10:48 PM   #21
SJM
SJM's Avatar
I originally used CTS 500K Audio Taper pots and I had this happen. I understand the RS Super Pots which are made by CTS don't have this problem.
Steve-M
'52 Martin D-28
Old 10-22-2011, 11:30 PM   #22
Phildog
Phildog's Avatar
MIne too brother!!!
'06 Epiphone Black Beauty 3
'04 Epiphone '56 Goldtop
'91 Epiphone Emperor (Pre Joe Pass)
Fender Amer Std Ash Strat
Fender MIJ Telecaster 50's Reissue
2001 Ibanez AS120
Univox U1225 (Head/Cab) B Series
Fender Blues Deluxe w/EV12S
Phildog is offline   Reply With Quote
Old 10-22-2011, 11:48 PM   #23
SJM
SJM's Avatar
Here you are my friend. It sounds like an easy fix.
http://www.mylespaul.com/forums/tone...ml#post2775389
I still like the 300K Linear Pots even though he doesn't.
Steve-M
'52 Martin D-28
Old 10-23-2011, 12:16 AM   #24
Phildog
Phildog's Avatar
Got a pair of 300K's for my LP Classic project buddy. Can't wait to hear how they sound!
2001 Ibanez AS120
Old 10-23-2011, 01:00 AM   #25
SJM
SJM's Avatar
Hey, how ya been? Let me know how it turns out, I'd love to hear about it.
Steve-M
'52 Martin D-28
Old 10-23-2011, 01:09 AM   #26
GitFiddle
GitFiddle's Avatar
Originally Posted by onlypadog View Post
...And - here's another question bugging me - if this is what most people, the most common upgrade if you will - then why is it not stock? Not necessarily with the upgraded caps etc, just the wiring scheme...?
Its all relative. It may be the most common upgrade in this and a few other forums. But that is still a very minor percentage of the millions that are perfectly happy with the stock setup.
The stock setup is probably most beneficial for the manufacturer.
Old school:
"The customer is always right"
New school:
"The customer gets what we say is right"
GitFiddle is offline   Reply With Quote
Old 10-23-2011, 01:09 AM   #27
winexprt
winexprt's Avatar
Many thanks Bro! Looks like the RS Super Pots are going to be my preferred solution.
Old 10-23-2011, 01:21 AM   #28
SJM
SJM's Avatar
Steve-M
'52 Martin D-28
Old 10-23-2011, 01:25 AM   #29
Phildog
Phildog's Avatar
There ya go!!!
2001 Ibanez AS120
Old 10-23-2011, 01:30 AM   #30
purevilpleasure
I'm never tried it but I have read up a little bit about the Treble Bleed Mode. I think that will take care of some of the roll off issues.
Treble Bleed Circuits Explained!
Donk’s FB
Forum Jump
