MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Vintage Les Pauls
Thread Tools Display Modes
Old 06-28-2008, 10:45 AM   #1
ES-347
since when did G used the weight relief holes
Hello all!
I am new to this forum and I couldnīt find any infos on the following:
1. When did Gibson start to drill these 9 weight relief holes into the body? Are the old traditional ones (pre 1960) done with this, too?
2. Did Gibson use hide glue for the LP before 1960?
Should be glad to learn more about this, as I am starting a 59-do-it-yourself project soon.
Thanks and best regards from Germany,
Martin
ES-347 is offline   Reply With Quote
Old 06-28-2008, 10:50 AM   #2
stinger
stinger's Avatar
Re: since when did G used the weight relief holes
1. The pre 1960 are all solid bodies with no relief holes. Not sure when they started the weight relief holes.
2. Gibson did use hide glue for the old bursts.
Steve
stinger is offline   Reply With Quote
Old 06-28-2008, 10:52 AM   #3
stinger
stinger's Avatar
Oh, and welcome to the forum. You will find alot of information here that you will find very useful in your project.
Steve
Old 06-28-2008, 02:29 PM   #4
sgberry
1982
sgberry is offline   Reply With Quote
Old 06-28-2008, 03:47 PM   #5
ES-347
THANKS for the speedy and worthy clearifications !!!
Kind regards,
Martin
Old 07-13-2008, 06:20 PM   #6
sewood
Cool Re: since when did G used the weight relief holes
Hide glue [animal] was used by Gibson to set the frets & neck in the 1958 , 59 Les Pauls. Dont know about 1960. Weight relief holes are used by Gibson on guitars with heavy mahogony bodies that would not qualify for use on a Historic 58 or 59. Gibson says you there is no sonic difference but if thats the case, why premium select the lighest "pre routed" bodies for the Historics?Out of every 500-1000 pre routed mahogony bodies, very few [3-4] weigh 4 lbs or less to qualify for a Historic RI. These are considered the premium select bodies.
sewood is offline   Reply With Quote
Old 07-13-2008, 06:46 PM   #7
ES-347
THANKS again!
Martin
Old 07-13-2008, 06:53 PM   #8
shotgunlew
shotgunlew's Avatar
+1
Oh and welcome!
chris
60% of the time...it works every time....
Gun Control = Using Both Hands!!
Everyone Please Pray for Sgt Jeffery Crones and the rest of the boys in iraq! Get some boys!
Chris "The Gunhand" Of the MLP Pirates Crew
1986 Les Paul Jr (Cherry red Singlecut )
1994 MIJ fender Telecaster 52 reissue
1984 JCM 800 1x12 50 watt combo
Behringer 4x12 cab (Bugera speakers)
shotgunlew is offline   Reply With Quote
Old 11-08-2010, 09:50 AM   #9
fabistn
fabistn's Avatar
about the holes very interestant. check this
Epiphone Genesis Lovers: Los agujeros de las Gibson Les Paul -------------------------The Gibson Les Paul Holes
fabistn is offline   Reply With Quote
Forum Jump
