MyLesPaul.com
Go Back   MyLesPaul.com > Music Gear > Tonefreaks > Pickups
Thread Tools Display Modes
Old 05-31-2008, 03:16 PM   #1
slideman
Les Paul Classic String Spacing/Pickup Swap?
Does anyone know the spacing at the "bridge" for a Gibson Les Paul Classic.? I was told that if the spacing exceeds 53mm or 2.1" that I would need an F-spaced pickup. On Dimarzio's website, he indicates that later Gibson LP's (from the 90's on) may require f-spaced humbuckers. Anyone know?
Thanks.
slideman is offline   Reply With Quote
Old 05-31-2008, 03:38 PM   #2
stryker59
stryker59's Avatar
Re: Les Paul Classic String Spacing/Pickup Swap?
im not sure of the spacing but i used normal spaced humbuckers when i swapped the pickups out in my classic and havent had a problem....im guessing that the spacing is normal!
you've been weighed, measured, and found wanting!
stryker59 is offline   Reply With Quote
Old 06-02-2008, 01:24 PM   #3
J.LaGrassa
My Les Paul Classic was made in 2005 and the bridge pup is definitely F-spaced, I just Installed a set of the Dimarzio Anniversary pickups on my LP and got the F Spaced bridge ..its pefectly spaced!
J.LaGrassa is offline   Reply With Quote
Old 06-02-2008, 09:53 PM   #4
stryker59
stryker59's Avatar
niiiice gt!!!
Old 06-02-2008, 10:07 PM   #5
Inside Guy
I am no longer @ Gibson
Inside Guy's Avatar
LP Classics have a 500T in the bridge. The Bridge pickup has wider pole piece spacing than the neck pickup.
Inside Guy is offline   Reply With Quote
Old 06-02-2008, 11:42 PM   #6
SKATTERBRANE
Guest
Posts: n/a
Yes, any Gibson pickup with a T at the end of the model has the wider spacing. HOWEVER a neck spaced pickp will work just fine, as Vintage and Historics use neck spaced pickups at both positions. I take out all 490R/498T and 496R/500T pickups in any Les Paul I care to improve the tone on. If I use Gibson pickups, I usually replace them with 57 Classics.
Old 07-06-2012, 02:06 AM   #7
xenrelic
Thanks.
The stock Gibson string spacing on the bridge from the centers of the outside E strings should be 2".
Here's the saddle spacing setup procedure:
Make sure the outside E strings are placed on the saddles so they have an equal amount of space from the edge of the string to the edge of the fretboard while maintaining the 2" center to center spacing.
Tap the strings down on the saddle with a plastic hammer to create their slot. You want just a deep enough slot to keep the string from popping out under playing tension.
Then to get the centers for the other strings, all you have to do is divide 2" by 5, which gives you the spacing between each string at the bridge which is .40"
Set the strings on the saddles and tap each one down to create its slot.
Then if you want, you can take the proper sized nut files and further smooth the slots out. Keep the slot depth no more than 1/2 of the diameter of the string for the best tone. You can also use a radius gauge to match the radius of the fretboard when filing the 4 center string slots.
On most Gibson Les Paul guitars, the fretboard radius = 12"
Some vintage Les Pauls and Custom Shop models like the Florentine will have a 10" radius on the fretboard.
StewMac makes a compensated string slot spacing rule that takes the different string gauges into account for a more even distribution of the 4 middle strings. It's supposedly a more comfortable feel that wont change with different string gauges.
I like both but I prefer the stock Gibson spacing, myself.
xenrelic is offline   Reply With Quote
Old 07-06-2012, 02:11 AM   #8
xenrelic
You should definitely go with the F spacing a.k.a. Trembucker spacing for a Les Paul Classic.
Old 07-06-2012, 09:29 AM   #9
SKATTERBRANE
I have had MANY Les Paul Classics and even though their stock bridge string spacing is 2-1/15" the 57 Classics with 1-15/16" spacing works just fine. (the first thing I did was to throw away the 496R/500T pickups and put in 57 Classics) So don't limit yourself to a "F-spaced" pickup! In fact all Gibson Les Pauls work just fine with "neck spaced" "G-spaced" "PAF spaced" or 1-15/16" (49.2mm) spaced pickups.
Remember all vintage Les Pauls, and Les Paul made through 1987, and all Historic Les Pauls use 1-15/16" spaced pickups in the neck and the bridge. There is no reason any of the newer Les Paul cannot work well with this vintage spacing as well.
In fact I have no idea why Gibson went through the trouble of even developing a 2-1/16" spaced pickup at all.
In fact Gibson's Custom shop model version of the Les Paul Classic came stock with 57 Classics. All 57 Classics and Burstbuckers have 1-15/16" spacing for both neck and bridge.
SKATTERBRANE is offline   Reply With Quote
Old 07-06-2012, 10:00 AM   #10
Who
Who's Avatar
Do you know if DiMarzio's non-F spaced are " normal" width?
As Skatter mentioned, F spacing is probably never needed, but I recently bought a 36th Anniv for the bridge of my '74, and I like the way it looks, lined up over the poles. Sounds fine.
Before that, I had a SD neck pickup in the bridge. Worked just fine.
Why not just measure the distance of your strings? If you don't own an accurate enough ruler, go get one. They are cheap, and will be all kinds of useful.
Who is online now   Reply With Quote
Old 07-06-2012, 10:09 AM   #11
SKATTERBRANE
I am pretty sure that DiMarzios spacing is more narrow in both the neck and the bridge than Gibson's. So, if you order DiMarzio, you may HAVE to get their F-spaced for the bridge, because their neck spaced is even more narrow than Gibson's neck spaced pickups.
DiMarzio's spacing is unique.
Old 07-06-2012, 10:15 AM   #12
SKATTERBRANE
Gibson spacing: 1-15/16" (49.2mm) 2-1/16" (52.4mm)
Chinese (metric) spacing: 50mm and 53mm
DiMarzio spacing: 48mm and 51mm
A Dimarzio neck spacing of 48mm may not work best in the bridge. However Gibson's neck spacing works just fine in the bridge, because Les Pauls were DESIGNED for this.
Forum Jump
