MyLesPaul.com
Go Back   MyLesPaul.com > Music Gear > Tonefreaks
Thread Tools Display Modes
Old 10-03-2010, 09:36 AM   #1
kingswood127
Humbucker height question...
When adjusting the height of a humbucker, do you measure from the adjustable pole piece side or the fixed side?
The adjustable side on my humbuckers are about 1/16" or so higher than the fixed poles.
Thanks for any advice!
kingswood127 is offline   Reply With Quote
Old 10-03-2010, 09:40 AM   #2
River
River's Avatar
Re: Humbucker height question...
Mine usually have covers on them, so the adjustable poles.
Old 10-03-2010, 09:43 AM   #3
kingswood127
I forgot to mention, the pole pieces on my humbuckers (both adjustable and fixed) are exposed...
Old 10-03-2010, 09:44 AM   #4
River
River's Avatar
I assumed that. I'd still measure from the adjustable poles.
Old 10-03-2010, 11:03 AM   #5
gtr-tek
Fumble Fingers
gtr-tek's Avatar
I've found a good rule of thumb I got from Bill Lawrence's website where you use 2 nickels on top of the pup on the bass side while holding the string down on the last fret and adjusting until the nickels just touch the string and a single nickel on the treble side, same procedure. This gets them pretty close to start. I'll usually adjust the stronger one lower to achieve balance in the middle position. I've found having them too close causes intonation and sound problems.
Les is more!
gtr-tek is offline   Reply With Quote
Old 10-03-2010, 05:14 PM   #6
Sinster
Sinster's Avatar
Gibson Tone Tips #33: String Height
'16 SG Faded
'14 EVH Wolfgang
'13 Traditional
'12 Mahogany Traditional
'12 Studio
'11 Gary Moore BFG
'10 50's Tribute Studio
'09 Squier Strat SE CSX
'09 Mahogany Studio
'07 Squier Tele
'95 Fender Strat
BFG Owner Group
Proud Owner of a Cygnus 7 amp!
Sinster is offline   Reply With Quote
Old 10-03-2010, 05:34 PM   #7
onehippie
onehippie's Avatar
after you get the 2 outer poles set on both pu's its also a good idea to adjust the remaining poles to the radius of fingerboard or bass side 3 all the same as the outer bass pole distance from bottom of string with last fret held
and the 3 treb to the same as the outer treb pole distance from bottom of string
onehippie is offline   Reply With Quote
Old 10-03-2010, 09:03 PM   #8
TeleDog
TeleDog's Avatar
It's a good tip, but the strength of that magnet is not the same for all pickups, so I guess having a pre-set distance from the poles to the strings is just a guide, and not some absolute. You're setting up YOUR guitar and no two are alike.
“Teledog. Telecasterus Fanaticus Dogius".
Got a Mac or iPod? Join our Apple Dogs group!
TeleDog is offline   Reply With Quote
Old 10-03-2010, 10:01 PM   #9
NYPV
NYPV's Avatar
I like to set the neck first. Go by ear!! You'll probably find it sounds better a little lower then factory recommendations. Set high E side, while fretting on the last fret,and drop the low E string side a little more to lose the boomy bass. When you have good string to string balance raise or lower bridge pup to match volume. Hit high E with pup selector on neck, then switch to bridge and balance volume. Same with low E string. All this with all controls maxed, important. All strings, all pups should all be the same volume. Now you can tweak via the tone and volumes to your liking
NYPV is offline   Reply With Quote
Old 10-04-2010, 09:58 AM   #10
gtr-tek
Fumble Fingers
gtr-tek's Avatar
Very true. Like I said, a good place to start. It gets you in the ballpark and you tweak it from there. Bill Lawrence certainly knows his stuff! I've used this method to set up all of my guitars and others I've worked on and it works. Difference in pups are mere fractions of an inch, usually much less than 1/8". Balancing the middle position is the trick.
Les is more!
Old 10-04-2010, 10:07 AM   #11
sharptan
sharptan's Avatar
Does changing the pickup height really make that much of a difference? It's maybe something I'd like to do on my LP...
sharptan is offline   Reply With Quote
Old 10-04-2010, 10:16 AM   #12
Rich
Non sequitur
Rich's Avatar
I don't actually measure anything, but adjust them until they sound and feel right the way I like them.
http://www.mylespaul.com/forums/tone...r-pickups.html
Originally Posted by Rich View Post
I just wanted to quote myself in my signature.
Rich is offline   Reply With Quote
Old 10-04-2010, 10:24 AM   #13
gtr-tek
Fumble Fingers
gtr-tek's Avatar
It certainly can. Too close and you can get odd tones and notes that don't ring true due to too much magnetic pull on the strings. Too far and the sound is weak and thin. There is a sweet spot in between and you need a place to start.
Les is more!
Old 10-04-2010, 03:24 PM   #14
River
River's Avatar
Same here. I eyeball them to be like they were or like my other similar guitars, then sit down with a set of headphones and a screwdriver.
Some pickups react so strongly to height changes that I've thought I broke a solder connection. Others don't seem to care much, unless they're almost touching.
Old 10-04-2010, 04:36 PM   #15
mudfinger
Thanks for the memories!
mudfinger's Avatar
I like to keep the coils low, and the screws up high; but, I started off my career as a Fender man, and I do still love the sound of Leo's pups.
Ginger, my #1, before she donated her bridge pup to the Monsterbucker:
Flora, my #2, in her current configuration:
Coils are pretty much level with the rings, screws are way up high. It's not a sound you'd expect to hear from a humbucker, but it sure puts a smile on my face.
"Music is the Mother of all Art."~Lefty Phillips
mudfinger is offline   Reply With Quote
Old 10-04-2010, 11:55 PM   #16
exactopposite
How would you describe the difference? I'm curious.
exactopposite is offline   Reply With Quote
Old 10-05-2010, 02:05 AM   #17
djlogan33
djlogan33's Avatar
Hold down the strings on the last fret
  • Average neck Pickup height = 3/32" (little closer on the high-E string)
  • Average bridge Pickup height = 1/16" (little closer on ther high-E string)
...B
djLogan
...U
...E
...S
-Gibson Les Paul Studio (Wine Red) with a Bigsby B7g
-Gibson B.B.King "Lucille"(Ebony) - signed by B.B.King
-Gibson B.B.King "Lucille"(Ebony) - with a Bigsby B7g
-Fender '52 Reissue Telecaster with a FAT Warmoth neck
-Fender Blues Deluxe Reissue Tweed tube amp -40w
-Fender Blues Junior Tweed tube amp -15w
-Fender Cyber-Twin tube & digital amp -130w
-Fender GDEC 3 Thirty BLUES digital amp - 30w
djlogan33 is offline   Reply With Quote
Forum Jump
