#31 (permalink) | |
![]() Join Date: Mar 2008
Re: Let's talk recording
Mark |
#32 (permalink) | |
![]() Join Date: Mar 2007
I've tried everything. I've used drum machines, Jamstix (cool!), DrumSite (okay). I bought DFHS - GREAT drum sounds. Needs lots of drive space, and CPU horsepower - and doesn't come with patterns or grooves. It's just the drum samples and an interface. So if you have MIDI drum tracks DFHS works great. Or if you love programming drums one hit at a time (I don't). Then I got EZ Drummer. Lots of patterns, more available aftermarket. Couple of cool kits. Great sounds. Very simple and easy. The next stage I'm moving to is an actual drummer . I'm building a home studio with enough space for a drum kit. I'll get virtual drums, so I don't have to mic an acoustic kit, and so I can record the drums as MIDI. I'll use DFHS as the samples. Anyway, try EZ Drummer in Cubase. It'll have you up and making tunes quickly.
Historics: 2003 R9 "RoadWorn" 2006 R8 "Sweet Cherry" 2005 R7 Goldtop 2002 TV Model DC Jr. Production Gibsons: 2006 Explorer 2004 Flying V 1986 Les Paul Custom 1973 Les Paul Recording |
#33 (permalink) | |
Mark |
#34 (permalink) |
Yeah, it's $ 150. The good stuff isn't cheap I guess. Amazon has a copy used for $ 112.
Hey is that a Marauder in your avatar photo? I got a Marauder, new, in 1976. My first Gibson. Mine is wine red. Still have it.
#35 (permalink) | |
It is a Marauder...Sunburst w/ the binding on the neck. I got mine in 74 or 75. It's all torn apart right now. A couple of years ago I routed the pickguard and put in a humbucker (Rio Grande). I never used the original single coil so I wanted something that would give me a bit more versatility. I recently pulled that pickup out and put in my LP. I like it better there. I used it on a couple of the clips I have posted here. I still have the original neck pickup though. I have always liked that Bill Lawrence tone from that one. Used it for a lot of recording and it sounds great. I have have some other humbuckers laying around so I may have the big M up and running soon again I actually really like the guitar. Mark |
#36 (permalink) |
![]() Join Date: Jan 2008
mic Sennheiser 421 (and maybe a 57 at the same time)
quote from above..."The first mic you should get is the venerable SM57. You can use it to record with, and it doubles as a hammer in a pinch" DO NOT HIT YOUR MIC.....I have mishandeled a 57 and loss some of the high end, sure it kept on working but still it was damaged and I got rid of it REAPER is a free (more or less) DAW and it kicks a**....take a look at the sound on sound review |
#37 (permalink) |
Hey, figured I would chime in on what i use.
Mac G5 dual 2.0 PowerPC 4gigs ram and 2 TB of HD Protools HD 1 Apogee Rosetta 200 AD/DA converter Event Monitor Rockit Sub Mackie Big Knob monitoring system Neumann TLM149 Large Diaphram Condenser Mic API lunchbox with 2 Great River Pre-amps a 1 sm58 1 sm57 Beta 87 Mogami Cables Akai MPC1000 with jj0s 2 remote 49 midi controller Yamaha motif es6 Abelton Live Reason 3.0 Waves Gold Bundle Sonnox eq Soundtoys Melodyne and a ton of other plugins Linndrum tech 1200 record player and a gangpile of records Marhsall dsl401 w/di Epiphone elitist Les Paul I mainly record hiphop and pop music, produce beats and track vocals. In addition I do a lot of mixing for local Twin Cities artists. There is a reason why protools is an industry standard, so my suggestion to anyone thinking about getting into recording DAW is to get Protools. Anyway, here is a quick pic of some of stuff
http://www.golden-mc.com http://www.myspace.com/golden CHECK OUT MY MUSIC ^^^^^^^ IT DOES NOT SUCK |
#38 (permalink) |
I always start my songs by developing the main riffs with a unplugged acoustic or a electric going into a practice amp like roland's microcube, while simultaneously creating the drum track in fruity loops and Drumkit From Hell 2 samples. I can even add bass and ambience with fruity loops, however it's quite limited. By doing guitars and drums simultaneaously i can get somewhat of a "groove" going. I usually just start off with something that i've been working on and expand on that.
I spend many hours working on song structure, ie. intro, verse, chorus, bridge, outro. After i have a decent rough draft, I save the fruityloops file and open up Pro Tools LE and the Digi 002 rack. Import the drum track into pro tools and now i'm ready to lay down guitars and vocals. I like the sound of an amp miked, so if it's too late to use the amp then i won't even bother. I have a POD XT live but it don't cut it for me. Make me an offer and ti's yours. So i mic the amp with a Shure KSM27 condenser and usually get a pretty good sound. As a rule i always pan my first rhythm track to the mid-left and then record a second rhythm track and pan it mid-right. I just like the thicker sound that way. then i do any ambience panned in the center with my Korg Triton Extreme (make me an offer and it's yours), or lead guitar also goes in the center usually. Same with vocals and bass. I always use a little delay and some reverb on the vocals, as well as some eq, where i always roll off a little low end to make my voice fit in the mix better. Sometimes i double up on the vocals for power, or for harmony. Just like guitar harnomization. Once i'm done i export the file out of pro tools and into adobe audition so i can change it into a mp3. Then i listen to it with windows media player (that's the litmus test). In conclusion: For every 5 songs i create, usually only 1 of them is a keeper. To get something really good i have to produce TONS of material. You get what you put in is my motto. Work hard and you will see the results. Everytime i record a new song i learn a few things, sometimes minor things, other times pricless. some tips (my opinion): I never need as much gain as i think i do, nor reverb. alway use one of your recording channels for guitar, another for vocals, and so on, so you don't have to constanly make adjustments to the gain and other controls of that channel. I would recommend getting some monitors to listen to your song as you are creating it, as opposed to headphones. there's no substitute for hearing sound pass through the air. I use a pop filter with vocals, it is extremely usefull because it really does a good job of smoothing out the mix if i accidentally say a "P" too loud or something. I rarely sing directly into the mic, most of the time i sing at an angle to it. i think it's because it's a sensitive mic and if i speak directly at it the monitor will immediately peak into the red. For song structures, I take notes from my favorite bands. If you like the way a particular song goes, then steal the structure and replace it with your own riffs. after a while you will figure out what sounds best to you and develop your own style, and no longer need to bite off other songs. To me the strength of a song usually (not always) lies in the transitions. A sweet riff is cool, but the next transition can make or break it. spend time working on transitions, and ask yourself if it keeps the feet tapping, or does it murder the groove? Anybody can write a riff, but it takes time and dedication to master transition, and it will show. people will be impresed. Thanks for reading my rant. Peace!
If a composer could say what he had to say in words he would not bother trying to say it in music. -Gustav Mahler Without music, life would be a mistake. -Friedrich Nietzsche |
#39 (permalink) |
Hello all,, I Hope this thread is still alive.. hehe
i'm kind of new to this Home studio stuff but is my real passion,, the thing is that i requested for a M-audio midi controller 49key, line6 toneport x2 interface. to start with my recording stuff,, i already have some software (fruity lopps, cakewalk sonar and plan to get in the future waves mercury) im not very good with the software yet, but as soon as i get the gear i will improve on them,,, so i want to get some monitors and condenser microfones, is there any advice you guys wanna tell me??' im running on a low budget at the moment.. maybe any other gear i will need? |
#40 (permalink) |
Great topic.
I've been doing the home PC recording thing for awhile and I love it. What my goal was to see how far I could go recording with a DAW (digital audio workstation) and no mic's. What a journey its been. I use Sonar Producer and it is one of the best. For drums I use FXpansion BFD. Killer sampled drums and for bass I use Broomstick Bass along with IK Multimedia AmpegSVX software. Waves makes some of the best effects software out there and I went overboard and got the Mercury bundle. For mixing down and mastering I use Soundforge and Harbal. Little did I know when I started doing this, how addicted to it I would get. I've done numerous commercials for radio and TV as well as fixing bad mixes for some local bands. This stuff goes deep as you want to go. There is lots to learn in PC recording and I can't tell you how many times I was pulling my hair out in frustration at learning this (I can trouble shoot just about anything) but it has been well worth it. For the audio card I use M-Audio Delta 10/10LT Last edited by racerratt; 08-27-2008 at 04:02 PM. |
#43 (permalink) |
Hey i got the line 6 toneport ux2,, is there any way i can get it work without monitor speakrs?? i mean get it work with my computer speakers?
and a,, my ableton lite,, doesnt workk, is there any other good software out there easy to use? |
#44 (permalink) |
One thing I'd like to suggest is to record/save to a separate hard drive; audio files can fragment & wreak havoc on your computer's main drive.
I use a PreSonus 8-input FireWire rigged up at rehearsal; snare & kick mic'd, 2 overheads, bass direct, 1 vocal mic, with a MacBook & GarageBand. Record everything to the stand-alone 250gig hard-drive right next to the laptop... Get good levels & tones first---you won't have to tweak them later (unless you want to). |
#45 (permalink) |
HELLO THERE...
IM DOIN RECORDING STUFF AT MY ROOM TOO.. WELL,MY SETUP IS A MINIMAL SET UP ONE.. I GOT ---> - PC - AMD 2600+ ATHLON XP - RAM - 1 GIG - 500GIG HARD DISK - M-AUDIO DELTA 1010Lt SOUNDCARD - M-AUDIO RADIUM 49 KEYBOARD CONTROLLER - ESI NEAR 06 ACTIVE MONITOR SPEAKERS - RODE NT-1 CONDENSER MIC - M-AUDIO NOVA CONDENSER MIC - SHURE SM58 CONDENSER MIC - LINE 6 POD XT LIVE - PRO TOOLS M 7.4 - SONAR 7 - ACID PRO 6 IF YOU GUYS WANNA LISTEN TO ALL MY RECORDING WORKS... CLICK THIS & LISTEN TO ALL MY WORKS IN THIS PAGE OK ---> www.myspace.com/maximusmuzik THATS MY BAND & MY WORKS... DONT FORGET TO LEAVE A COMMENT ON MY WORKS OK... THANKS.. HAVE A NCE DAY OK
I am VladMaximus,a musician from Malaysia...ROCK ON!!! ![]() follow my TWITTER --> mijiero666 Music Tools ---> - 1978 TOKAI REBORN LES PAUL - GODIN ARTISAN ST6 - FENDER STRAT 50s CLASSIC 1993 |
#47 (permalink) |
I am confused about the soundcard the people mention.
I have an IBM Thinkpad. I assume I have a "business" soundcard. Do I need a decent sound card if I get a "box" (where I plug in my guitar and mic)? Hope that made sense?
Gear: 1988 Gibson Les Paul Custom Heritage Cherry 1998 Taylor 210 Acoustic 1959 Les Paul Standard 1936 Martin D-45 1950 Fender Broadcaster 1956 Fender Strat 1992 25 Watt Park Solid State Amp Dumble Overdrive Special Amp Trainwreck Amp |
#48 (permalink) |
![]() Join Date: Sep 2007
There are some real nice plugin soundcards for laptops
http://us.creative.com/products/prod...WT.mc_id=17395 or you can get a USB digital sound unit like http://www.m-audio.com/products/en_us/FastTrackUSB.html or http://us.creative.com/products/prod...&product=15186
Cold Steal soundclick...My YouTube ... Interview.. ...Sunset Strip Rock Alumni 76-83' ![]() I'm Insane (pre-ratt)...Scene of the Crime (Pre-Ratt)..Street Legal..Song of Mine..Loved You So I Lied |
#49 (permalink) | |
I'm running a desktop pc with a quadcore @ 2.8, 4 gigs memory, and an 896 MB graphics card, and Vista 64 bit. |
#50 (permalink) |
Well here my two cents on recording song:
Equipment list as follows: Tascam DP02 Recorder Art Tube Preamp Audix I5 Mike (same as a Shure 57 sort of) Zoom Electronic Drummer I record the drum track on one channel as a foundation of the song I'm recording. Then I record the guitar rhythm track two different ways. One track is an Line out direct, the other is a miked thru the Tube preamp. Without a 15 or 30 band eq I blend the direct and mike tracks in stereo and with the bass and treble at different freq to give the guitar a fuller sound. Direct EQ Freq Bass=500 High=1.7 Miked EQ Freq Bass= 400 High= 1.8 to 1.9 Then I record the bass from the post line out into the Tube Preamp and record it. EQ setting varies depending onthe song and what type of bass sound I need to hear. I love to try some computer recording software later on but they are so expensive right now I beleive I'll wait for for that~!!!! ![]() ![]()
And the Meek Shall Inherit the Earth Rush 2112 ![]() ![]() http://www.myspace.com/blackdungeoninc 2007 Gibson Les Paul Classic Zebrawood 2007 Brian May Red Special 1995 Fender Strat w/Lace Sensor Gold PUPS Dean Accoustic Fender P-bass 60th Anniversary Model Bugera 333XL 212 Tube Amp Fender Bassman 250 head with 4x10 Cab |
#51 (permalink) | |
for inputs and outputs, i like them both, but the usb's are probably the most versitile
#52 (permalink) | |
Would it go like this: Guitar -> Pedal Board -> Amp. / Mic'd Amp- M-Audio Device -> Computer Basically, run the guitar and amp as I would normally, and just run the the mic'd amp cord to the M-audio device? Or is there another mixer,etc? |
#53 (permalink) | |
Mark |
