#1 (permalink) |
pro tools wont recognize new interface
i'm having trouble, i had an Avid M Box and one of the 1/4 inch slots broke so i returned it, decided to upgrade to a profire 2626-- no i finally have it but pro tools won't seem to recognize it-- i finally have it as the playback engine and setup (hardware) however, no sound is coming out of it (other than every other sound in my computer, besides pro tools? this never happened with my mbox) and it only has 2 inputs, still thinks it's an mbox, and when i play a session it plays through the laptop speakers.
I recroded my fingers snapping in logic, so it's read by that program, but i never use it. so in short, help please ---dylan
#2 (permalink) | |
![]() Join Date: Feb 2008
Re: pro tools wont recognize new interface
#3 (permalink) | |
Tried opening an old session but i get no audio from anywhere when i hit play. This is getting a bit frustrating
#4 (permalink) |
Bartlett RetroPAF Vendor
![]() Join Date: Mar 2009
Are you direct monitoring an input and therefore not hearing the plugins?
Your old session likely needs the track/master outputs reassigned to the new interfaces outputs.
![]() Video Demos and More Below www.re-wind.net ReWind Electric on Facebook My name is James and I build PAFs. |
#5 (permalink) |
went through them track by track changed the output but still nothing. And i got to be honest i don't know what direct monitoring is, so i probably am not doing it haha
#6 (permalink) |
Direct monitoring is when you are passing an input directly to an output, avoiding the latency caused by going through a computer. It can be great for tracking, but would prevent you from hearing any processing your computer is doing, such as plugins and automation. You are likely able to activate/deactivate it both through ProTools and through the control panel for your audio interface, so you might want to check both. You can possibly activate/deactivate it in a per-track and global way through the PT options. It's been a number of versions since I worked in Tools so I'm probably not going to be much help with the Digi-specific details.
#7 (permalink) |
Did you install the drivers? Have a look at this link
Compatibility & Upgrade Information for Pro Tools on Mac. |
#8 (permalink) | |
#9 (permalink) |
Here are my settings and how Im streaming audio thru my computer. Sessions work as they should. itunes and all audio in the computer plays no problem.
#11 (permalink) |
thanks Joey, i really appreciate it-- i'll tinker around and see if i make any progress
#12 (permalink) | |
#14 (permalink) | |
uninstalled the drivers and will try again, this has been quite the pain in the arse
#15 (permalink) | |
this thread may be of some interest as well Help!! No sound from Profire 2626 |
#16 (permalink) |
you ARE of course using the most recent driver for your OS found HERE, right? M-AUDIO - Drivers and Software Search
#17 (permalink) | |
#18 (permalink) |
It has to be a routing issue. If protools didn't see the interface, you wouldn't get to the launch screen. Do you see green audio levels in your master fader in a session? How does that correspond to levels in the software mixer? Do you see audio there? Your monitors of course are connected to outs 1&2, yes? Do you get audio in headphones?
#21 (permalink) |
Did you get up and running yet? Did you call Digi, if not?
#22 (permalink) |
No i swear to god this is the most annoying piece of hardware i've ever bought i just want to chuck it out a window
#23 (permalink) |
Call Digi. They should be able to walk you through it step by step. I used to be a dealer and, unless things have really changed, Digidesign was one of the more helpful companies concerning support to end users. They realize their clients are often musicians and not technicians.
#25 (permalink) | |
#26 (permalink) |
Wait, you're in LA. Just knock on your neighbor's door. Everyone has a studio and runs 'Tools out there, right?
#28 (permalink) | |
![]() vsn? just upgraded to OS X mountain lion, however i hear it's very similar to OS X 7
#29 (permalink) | |
To the OP:Sounds like you need a tapemachine
#30 (permalink) | |
![]() any one got a struder 24 they wanna sell?
