#1 (permalink) |
What exactly is the difference between an SM-57 and a SM-58?
hey guys, was wondering, what is the difference between a SM-57 and a SM-58. we have a SM-58, but everywhere you hear "Record guitars with 57's, it sounds best". is there much difference, and would you use a 58?
Our house is a sanctuary for neglected instruments
#2 (permalink) | |
Re: What exactly is the difference between an SM-57 and a SM-58?
The only difference is the housing, which DOES create a slightly different frequency response. Nothing you couldn't address with EQ during tracking or mixdown.
"The time I burned my guitar it was like a sacrifice. You sacrifice the things you love. I love my guitar. Music is my religion."~Jimi Hendrix Lefty Phillips on Facebook ...and on ReverbNation Happy Hour w/Gabe Nelson Walkin Out w/DB Miller Addiction w/Gabe Nelson (video) Quote:
#3 (permalink) |
As stated above, it's the same mic, same capsule except the SM57 is more of a direct mic and the SM58 has a proximity effect because of the ball shape- you can pick up bassier frequencies from the top, bottom and sides.
a boat. |
#4 (permalink) |
Yeppir, and they are both pretty much bullet proof...
Sometimes... "He had delusions of adequacy." - Walter Kerr |
#5 (permalink) |
I have a lot of experience with recording, performing & microphones etc.
As has already been noted, they're almost identical mics. They're both amazing all rounders and close to bullet proof. You typically use an SM-58 for live vocals because it is omni-directional i.e. it captures sound from all angles so if as singer is moving around (as most do), the mic will still pick up their voice fairly evenly. You'd use an SM-57 more for recording instruments / amplifiers where you know they're not going to move around much - the benefit here is that the SM-57 mainly picks up what's right in front of it and ignores the rest, so you don't pick up unwanted noise - just what it's pointing at. Even though those are the typical uses for each microphone, because they're so similar you can use either one for almost any application. I've used SM-58's to record instruments and I've used SM-57's live ;0 Make sense? Also, do not be afraid to buy these used! Great way to save cash and they'll still probably outlive you :0 |
#6 (permalink) | |
-Matt '12 Gibson LP Standard Trans Amber/'12 Gibson LP Traditional Mahogany Worn Brown '11 Gibson LP Custom Shop R0 VOS Southern Sunset Burst/'11 Gibson LP Classic Custom Antique Natural '11 Gibson LP Studio '60s Tribute Darkback Vintage Sunburst/'10 Gibson LP Traditional Pro Goldtop Darkback '10 Gibson LP Custom Shop 50th Anniversary R0 VOS Cognac Burst/'08 Gibson LP Custom Shop G0 VOS Dark Burst '07 Gibson LP Classic Custom Ebony/'07 Gibson LP Classic Antique Honeyburst |
#7 (permalink) |
Thanks Thunder, my apologies! You're absolutely correct. For some reason, I thought the 58 was omni-directional and the 57 was a tight cardioid (but not hyper cardioid).
Indeed the reason why the 58's are used for live vocals is because of the foam to help protect against wind and popping p's... If I was only using a mic in a recording environment, from the two, I'd pick the 57 because it's slightly smaller, doesn't have the foam which steals a tiny bit of high frequency and....... LOOKS a little cooler
#8 (permalink) |
I've recorded guitars with a Shure SM-57, SM-58, and an old Unidyne III 545L. I achieved basically the SAME results (the 545 has a slightly more pronounced top end, but that's it) with these 3 mics. All use the same cardioid capsule. Placed in the same spot, I can get virtually the same amp sound with minimal EQ'ing. I also use either a 57 or 58 for live vocals, both with similar success (I find I have to sing "over" or "under" the 57 to cut down on breath passing over).
I suggest owning at LEAST one of each though. They're great utility mics to have around, and can fill in a LOT of places in a pinch if need be (I remember an evening when they became overheads for live sound fill).
![]() MAD MARTIGAN: Original Rock On The Space Coast 2012 Homemade Les Paul Amberburst 50's wiring, MojoTone CTS Pots, Orange Drop caps, MojoTone Custom Wound PAF Clones 2002 Gibson Les Paul Special Faded 50's wiring, MojoTone CTS pots, NOS USSR PIO caps, Seymour Duncan Antiquity humbuckers 2011 Phaez SIBLY with a Dr. Hobbitstein 1x12 with a UK Celestion G12H30 1965 Univox U45-B with a 1961 Quam AlNiCo 12" 1965 Univox U-42 |
#9 (permalink) |
SM57 is less obtrusive on snare (doesn't get in the way physically) and let's a thin voiced vocalist ( Tom Petty comes to mind) get closer to the capsule for more proximity effect. that's about it.
