Go Back   Les Paul Forums > Music Gear > Recording Studio
Like Tree1Likes
  • 1 Post By bscenefilms
Unread 06-16-2012, 01:38 AM   #1 (permalink)
Bartlett Retrospec Member
captcoolaid's Avatar
Macbook Pro with Lion and Guitar port problem Help ....
For some reason I am not getting anything from guitar port. I downloaded all the software and installed. I also downloaded monkey but it shows no midi device selected. WTF and thanks in advance.
Only thing I can see that is wrong is the USB is flashing and it says USB not plugged in. I know it works because I just plugged it into the pc.
http://mhd-pickups.com/
Luthier pricing available.
Or visit my youtube page
http://www.youtube.com/user/MHDPickups?feature=mhum#p/f
http://soundcloud.com/mhd-pickups/madhousedesigns-gameybluesmp3
DC DOES NOT EQUAL OUTPUT. Dc is a resistance value and that is all. It WILL NOT tell you what it will sound like, it WILL NOT make you sound like another player.
captcoolaid is offline   Reply With Quote
Unread 06-16-2012, 04:56 PM   #2 (permalink)
lucidspoon's Avatar
Re: Macbook Pro with Lion and Guitar port problem Help ....
I know on my old MacBook Pro (about 5 years ago), one USB port had more power. I think a lot of computers have lower and higher powered USB ports. Try plugging it into the other port.
I'm not sure what you mean about MIDI. I though that GuitarPort was just for guitar and didn't have any need for MIDI.
Guitar
Gibson Les Paul Studio '50s Tribute Gold Top Humbucker
Epiphone Les Paul Custom Silverburst
Fender JA-90 Telecaster Ebony Transparent
Aria Pro II TA-50
Pedal
Boss SD-1
Amps
Marshall JCM2000 DSL100
Marshall Class5 Head
Blackstar HT Studio 20H
Vox Valvetronix VT20+
Cabinets
Marshall MC412 w/ Stock Celestion Rocket 50s
Blackstar HTV-212 w/ Stock Celestion Seventy 80s
lucidspoon is offline   Reply With Quote
Unread 06-16-2012, 11:38 PM   #3 (permalink)
Yeah I tried both ports. It shows USB not there. It also comes up no midi device specified in monkey.
Unread 06-18-2012, 10:57 AM   #4 (permalink)
bscenefilms's Avatar
Have you setup the hardware in the Audio MIDI Setup utility in your Applications->Utilities folder?
Audio MIDI Setup - Wikipedia, the free encyclopedia
http://www.icreatemagazine.com/tips/...midi-settings/
I cried when I wrote this song. Sue me if I play too long.
bscenefilms is offline   Reply With Quote
Unread 06-18-2012, 12:16 PM   #5 (permalink)
Joeydego's Avatar
reinstall the driver?
Joeydego is offline   Reply With Quote
Unread 06-18-2012, 01:01 PM   #6 (permalink)
On a MAC you have to run that utility to configure Midi/Audio for any DAW that you are using.
Unread 06-18-2012, 05:13 PM   #7 (permalink)
Joeydego's Avatar
which interface?
Unread 06-18-2012, 06:46 PM   #8 (permalink)
Any FW or USB connection that provides either MIDI or audio I/O. You have to run that utility to make all of the assignments (a'la Default MIDI IN <-- MBOX-01 type mappings).
Unread 06-18-2012, 08:52 PM   #9 (permalink)
Joeydego's Avatar
Is this Lion specific? I don't remember running an OSX utility installing the M audio Profire 2626. Just installed the driver and fired it up.
Unread 06-19-2012, 10:47 AM   #10 (permalink)
It's been part of OS X since 10.1 (It was included in the public beta Kodiak 10.0 as well). If you just plugged in and went with it, I suspect there was already a port definition on the system. Or the driver installer updated the config on the fly. But all IO (MIDI/Audio) on OS X has to be defined to the Audio MIDI Setup unless the driver/support app for the interface does it's own thing and bypasses the setup app by using NSAudio/NSMidi directly.
Joeydego likes this.
Unread 06-19-2012, 11:39 PM   #11 (permalink)
Joeydego's Avatar
I'm thinking the m audio driver does this upon install.
Unread 06-20-2012, 12:30 AM   #12 (permalink)
Thanks guys. I was just about to give up on it and just use the Toshiba for it. I will give it a shot and report back.
Unread 06-20-2012, 12:34 AM   #13 (permalink)
Okay will this help "see" the USB in my mac. That is were the issue is. It is not the out put it is the fact it shows Guitar Port not connected.
Unread 06-20-2012, 11:55 AM   #14 (permalink)
Joeydego's Avatar
might I ask again which interface?
