Go Back   Les Paul Forums > Music Gear > Recording Studio
Like Tree10Likes
  • 1 Post By renthepen
  • 1 Post By campbellj
  • 1 Post By IndianScout
  • 2 Post By Escher
  • 1 Post By 2themax
  • 1 Post By middy
  • 1 Post By dudu
  • 1 Post By Kalz
  • 1 Post By BuzzHaze
Unread 03-11-2012, 09:38 PM   #1 (permalink)
BrettNasty's Avatar
HELP! Can't have amp in apt!
Can I plug in and record to my computer and still get the tone. What kind of hardware is required?
BrettNasty is offline   Reply With Quote
Unread 03-11-2012, 09:59 PM   #2 (permalink)
Re: HELP! Can't have amp in apt!
I would like to know that too, my cam sucks at recording I need to get into this century.
Pinkie is offline   Reply With Quote
Unread 03-12-2012, 12:50 AM   #3 (permalink)
android13's Avatar
Come on guys, you should get a decent microphone or two.
I for one can attest to the fact that the P-90 + BB3 combination is rather godly.
Originally Posted by EasyAce View Post
If you're not trying to tell a story---and what is the blues if not a music that tries to tell a story---your "chops," actual or alleged, won't impress anyone in the long run.
android13 is offline   Reply With Quote
Unread 03-12-2012, 08:08 AM   #4 (permalink)
renthepen's Avatar
My opinion is that a good amp + good mic + good preamp + good software is crucial if you want to have a "real" sound...
... but its totally possible to get a decent tone just by using a pod or other effect processor, or even by simply using a software amp emulator with a DI.
Honestly, I often use GTR, Eleven free and Amplitude to add some texture to my guitar sounds (in parallel to the original tracking) and I almost always record my bass tracks line-in and adjust the sound later.
If you got good ears and real knowledge in mixing, you can record a professional album from your apartment for sure.
Joeydego likes this.
renthepen is offline   Reply With Quote
Unread 03-12-2012, 08:22 AM   #5 (permalink)
campbellj's Avatar
Check out a Fender Mustang line of amps. I'm pretty sure they come with software so you can connect it to your computer and record, plus use headphones. They are in the price range of a good software package and you have an amp if you ever decide to take your guitar somewhere else.
22Frets likes this.
campbellj is offline   Reply With Quote
Unread 03-25-2012, 01:23 AM   #6 (permalink)
joshuatree725's Avatar
If you can't have an amp in apt, get a Mac and use Garageband for recording. It has tons of different amp modeling built into the software with all the effects you could choose from. No need for separate amp or effect pedals.
joshuatree725 is online now   Reply With Quote
Unread 03-25-2012, 04:21 PM   #7 (permalink)
Bartlett Retrospec Member
IndianScout's Avatar
Guitar Rig
IndianScout is offline   Reply With Quote
Unread 03-28-2012, 04:36 AM   #8 (permalink)
I can't tell you the number of times I've types this now...
ISO BOX!!!!
It truly is THE solution. I use mine all the time. built correctly, you can do about anything soundwise, even in the middle of the night.
If you aren't familiar with them - look on youtube and google. Its just a box that you put your cabinet and a mic into, then you close it up and it isolates the sound form the room. you can crank your amp and very little if any sound escapes the box...
Plug the mic into your pc interface and you are all set... record a real amp almost silently.
Thumpalumpacus and TheDevice like this.
Escher is offline   Reply With Quote
Unread 03-28-2012, 04:53 AM   #9 (permalink)
+1.
I have a boogie 1x12 sealed in a old PA roadcase made of 1/2 ply with 2" hard foam inside, moving blankets draped over it in a closet, close mic'd with a older sm57 offset about 3" off center.
Not totally soundproof of course but I can jam a 100 watter on 5-ish without creating a issue with the neighbors.
Clip below is a tone test with my new 100watt SLO clone using my iso box, forgive the sloppy playing
http://soundcloud.com/theelectronicdevice/slo-clone-tone
ISO BOX!!!!
"Standard 82" Pre-Pre-Historic R9, 2003 Standard, 2007 Standard, 2011 Traditional plus, 2001 Standard, 2000 Classic, 2003 Classic, 1978 Pro, 2011 Studio Deluxe 60's, 2011 Studio 60's tribute GT, 2010 Faded Studio, 1991 LP Special DC, 1999 SG Standard, 2005 SG Classic, 2009 SG Classic, 2005 137 Custom, 2004 137 Custom, 2005 ES 165 Herb Ellis, 2000 Tal Farlow, 2000 Explorer, 2004 Explorer, 94 Custom Shop 54 strat, Eric Johnson strat, 2X 2000 62 avri tele designer, 2X 2000 avri 52 tele + 30 more...
TheDevice is offline   Reply With Quote
Unread 03-28-2012, 12:12 PM   #10 (permalink)
2themax's Avatar
I just ordered one of these Nady Axehead Headphone amps - arrives today - Amazon $28 shipped. The plus was it's USB rechargeable - it seemed like all the other flavors used batteries.
NADY AxeHead AxeHead
During the week we stay on our boat (saves a long commute) and even though I keep a VOX Mini 3 on board - it's just too loud in the evening and the headphone sound is marginal (also requires dodging the phone cord in a small cabin area). So I thought I'd give this a try - hard to beat for the price.
I'll post an update after trying it out - it's not going be anything like the Guitar Rig - but it's under $30.
Good luck...
BrettNasty likes this.
Sometimes... "He had delusions of adequacy."
- Walter Kerr
2themax is offline   Reply With Quote
Unread 03-30-2012, 07:50 AM   #11 (permalink)
2themax's Avatar
Update on the Nady Axehead... basically it works and it's mobile. I like the Nady headphone sound better than the VOX Mini-3 - I think the VOX effects create a background noise with phones. But the tone is pretty limited, the casing could be a little tougher but it's not bad for the price.
Bottom line is it's an inexpensive way to practice with headphones. If I was in an apartment and couldn't make noise I'd be looking for other options - something virtual like OP's suggested where you could dial in a decent sound or find a smaller amp and build an ISO cabinet (checked out a couple of you-tubes and they really look like a good idea). But... I don't think your going to silence a 100w Marshall at 7 in a small apartment with an ISO.
So there lot's of options...
Good luck
- Walter Kerr
Unread 04-03-2012, 01:54 PM   #12 (permalink)
2themax's Avatar
Nady fell apart yesterday, on it's way back to Amazon - skip it... real low quality construction.
- Walter Kerr
Unread 04-04-2012, 03:56 PM   #13 (permalink)
middy's Avatar
I've had the Hughes and Kettner Cream Machine & Blues Master for years and they are great for all tube low watt home jamming. The cream machine is a one 1 watt amp and the Blues master is a 5 watt amp. They sound really good and will give you all the creamy tubeyness you could ask for at low volume. They are also fantastic for recording into a DAW. I use the cream machine thru git rig 4 using only a bit of gate and the psychedelay and it kills. The blues master is really great for getting a warm glassy clean tube sound and using git rig effects as well. Built in redbox classic if needed. Class A and they are full on not starved plate. They can also be configured to act like a BK butler tube driver in front of an amp pedal style. Very underrated secret weapons.
middy is offline   Reply With Quote
Unread 04-04-2012, 04:00 PM   #14 (permalink)
dudu's Avatar
Look for an amp with power scaling. Then place a DI box between the head and the
cabinet. Then run that line level signal to your computer and apply cabinet simulations
to it.
If your amp has an FX-loop, you have a quicker option: take the signal from FX-send
into your computer (it's line level).
Start here:
Recording good guitar sounds at home | dudu.ro
OwnHammer.com - Home
Red Wire Impulse Responses | High quality guitar speaker cabinet IRs for use with convolution plugins
Hop on my SoundCloud
dudu is offline   Reply With Quote
Unread 04-04-2012, 09:57 PM   #15 (permalink)
Kalz's Avatar
when people are around the house i plug headphones into my amp. It's not super high end headphones but it gets the job done to practice
Gibson '76 LP Custom- "Charlotte"
Gibson '06 LP Standard - "Jenny"
Fender '98 Strat - "Rachel"
Fender '11 Tele - "Sasha"
PRS '91 CE-24 - "Rita"
Aria '60's Diamond - "Sophia"
2010 Gretsch 5122 - "Delilah"
VOX AC30C2
GFT-90 -> Mosfet 2 -> EHX Small Stone -> DD-20 -> Neunaber Wet
Kalz is offline   Reply With Quote
Unread 04-12-2012, 06:05 PM   #16 (permalink)
BuzzHaze's Avatar
I have one of these and it works very well. Lots of I/O and very versatile.
BuzzHaze is offline   Reply With Quote
Unread 04-12-2012, 08:33 PM   #17 (permalink)
You guys are better off with a Fender Mustang 1,2,3 amp
AngelReyes is offline   Reply With Quote
