MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Other Single-Cuts
Unread 02-27-2009, 08:19 PM   #1 (permalink)
whateverlikesgadge's Avatar
Tokai Wiring
Ok I just got the nerve up to take a look inside the wiring cavity of my Tokai LS90 as curiosity got the better of me. After seeing some of the pics of VladMaximus' Tokai I was expecting a PCB. I was pleasantly surprised with what I found.
I'm curious to know if anyone can identify the manufacturer of the green capacitors used.
I am thinking of changing out the caps to either Sprague Orange Drops 0.022 Bridge and 0.01 Neck or Adiophile grade transparent types as well as Oil and Paper. I'm actually quite happy with the pickups and pots.
whateverlikesgadge is offline   Reply With Quote
Advertisement
Unread 02-27-2009, 08:35 PM   #2 (permalink)
vladmaximus's Avatar
Send a message via Yahoo to vladmaximus
Re: Tokai Wiring
vladmaximus???
why me...
why ????
ha ha haaaaa....
did u mean this --->
hmm...when i first got the guitar..the pc board os there...its original pc board...
i dont want to remove or change it...i like it...
thanks...
I am VladMaximus,a musician from Malaysia...ROCK ON!!!
My Soundcloud audio works --> https://soundcloud.com/mijiero
follow my TWITTER --> mijiero666
Music Tools --->
- 1978 TOKAI REBORN LES PAUL
- GODIN ARTISAN ST6
- FENDER STRAT 50s CLASSIC 1993
https://soundcloud.com/mijiero/holy-diver-demo-by-mijiero
vladmaximus is offline   Reply With Quote
Unread 02-27-2009, 08:38 PM   #3 (permalink)
Re: Tokai Wiring
Why you? Because you've become the "TokaiMaximus"
Greetings Vlad
Unread 02-27-2009, 08:56 PM   #4 (permalink)
GLOBAL WIRING GURU
jonesy's Avatar
Wink Re: Tokai Wiring
Can't tell you exact manufacture of those Green caps, but they are most likely the mylar film caps, you see the dark red ones like that in other guitars.
A good set of PIO or even Orange drops should open up things for you and add some warmth and clarity.
If you look at the way cap leads go from tone pot to outside lug on volume that is considered modern wiring. If you were to connect cap lead to center lug on volume you would have 50's wiring which is a little bit brighter, more open sound.
Running a smaller value cap on the neck is not a bad idea in some cases.
Unread 02-27-2009, 09:00 PM   #5 (permalink)
Re: Tokai Wiring
Thanks for the info Jonesy I will certainly take that under advisement.
Unread 02-28-2009, 03:36 AM   #6 (permalink)
GLOBAL WIRING GURU
jonesy's Avatar
Re: Tokai Wiring
Your welcome bro, if you have any questions or need any help just give me a bump OK?
Unread 02-28-2009, 11:25 AM   #7 (permalink)
Re: Tokai Wiring
Will do. Cheers...
