#1 (permalink) |
Bartlett Retrospec Member
ls80 vivisection
Hi guys, Dry Z are on my baby with their new pots and caps, so, for all those who can help and interest, i'm posting a few pics about a LS80 vintage features...
Neck pick up Bridge pick up no soldering for covers! nice double screw zebras inside! neck pick up cavity The old PCB some close up... Noble pots 500k, 2 audio (volume) 2 linear (tone), perhaps that's why that sense of "tone on - ton off" turning knobs... pcb top (pots "1" "3" stamped) tha plastic foil usually between pots and wood |
#2 (permalink) |
Re: ls80 vivisection
knob and outbuildings pick up spring... pick up ring bottom the other one bridge and brass saddles nice screw fingerboard curvature... Stop Tailpiece washer and stud naked! new wiring... 35 mm caps! Ready to try the Z's...
#5 (permalink) |
That's what I do; but I use NOS Vitamin "Q" caps. You could use the Russian PIO in the same way, if the leads (one of them, at least) are 5 mm - 7 mm longer than the cap body. Which explains why I use the NOS Vitamin "Q".
And, I actually find the controls with the PCB board to be quite good. |
#6 (permalink) |
no removal of that ****ing PCB board is the correct play for a keeper.
wether by total pot replacement or desoldering the board. however some dickheads feel that it's better to keep it all original as much as possible so squeezing in a cpl of those ruskie bullets on the board is a pain in ze assss
#7 (permalink) |
Thanks slap...
It will be quite simple re install the board and the pick ups kept untouched.... The Noble pots on mine frankly didn't allow much control especially linear tone pots... i did 50's wiring, all audio pots (best fot my taste and vintage correct ), russian caps like yoursi played it a bit tonight... it seems i found my holy grail... more info later...
#8 (permalink) | |
![]() Still considering changing the 250k's in my Burny, but it matches my voices now. Holy Chit! Those look like artillery shells! Where do you get those? And what are they? Definitely what should go in a lifer guitar. |
#10 (permalink) | |
![]() ![]() they're K40y-9s russian mil spec 22's i put them in everything.try ebay australian customs also thinks they look like shells too ..... |
#11 (permalink) | |
+1 slap, are K40y-9. i bought them here... si-maher | eBay very nice and reliable guy... those caps give me the woody and warm tone that i expect when tone knob get closed... wonderful... And Z's make really the difference... |
#12 (permalink) |
Looks like you guys went for the .010's.
Why didn't you go for the traditional .020's he has for sale? Or even the .015's? edit: I don't see the 35mm caps there. http://www.ebay.com/sch/si-maher/m.h...id=p4340.l2562 |
#13 (permalink) | |
I went for 35 mm .022, now sold out unfortunately... here they were... http://www.ebay.it/itm/130694696959?...84.m1497.l2648 |
#14 (permalink) | |
I like the .010's as as like some of the high it maintains when rolled all the way down. I actual use my tone controls a lot more now.
In all your ways acknowledge Him, and He will make your paths straight. Proverbs 3:6 |
#15 (permalink) |
![]() Join Date: Sep 2010
Caps
I've had a good experience with this guy "outtahear" on TGP. Pretty sure they're the 35mm ones. Roughly the same as a AAA battery. |
#17 (permalink) |
Just ordered a couple more and this is what he said he has in stock. Going by the voltages, would the 47u be small and the other two large? I'm on a holiday so I can't measure the ones I got last time. Not that I care either way, just curious whether Size/voltage go hand in hand.
2) .047/200V 3) .022/1kV 3) .015/1kV |
#18 (permalink) | |
#21 (permalink) |
![]() silver bullets for LP's (1000v) green goblins for strats (160v) so yes smaller voltage = smaller size green goblins are K42Y-2 .can also be found in 22's both rock harder than a clampets rocking chair i found greens to be a better match in all mahogany outfits though such as SG's,jnrs & customs |
#22 (permalink) |
Heheh. I think it's funny they're now selling this as "vintage":
Vintage Tokai cotrol plate As an aside, it seems to be accepted internet wisdom (MIJ afficionados aside) that Japanese guitars have crap electronics, but truth is it's a mixed bag with lots of good parts as well. I think a lot of people see such a PCB board and automatically conclude it must be crap. |
