#1 (permalink) |
Hey guys,
I scooped up an Agile AL-3000 for 30 bucks because it needed restoration work including paint and everything else... the works. But hey, a set neck paul for 30 bucks. When I went to sand the body to prep for primer, I gouged the wood removing the old bridge studs. Now, I have my graphtech nvs posts that I am trying to put in but they seem to be kinda squirrely. a little crooked and all that GREAT stuff. The tailpiece still wraps around and meets both posts. I guess what I want to know is have I ruined all of my hard work or can I monkey around with the intonation saddles and the other bridge adjustments and get away with it? Thanks |
#3 (permalink) |
Re: Bridge help- Agile Al-3000
Sorry, haha my bad. I think it could go away if I tapped it all the way in as I'm just letting it slide in because I'm not ready to leave the studs yet because I have to paint still. Once I figure out how to post pics ill throw them up
#8 (permalink) |
I use 10's I'm afraid they wont straighten out because there's wiggle room in the post hole so I'm afraid when I made a mess taking the origional studs out, I ruined the hole
Yeah, I'm an idiot. |
#9 (permalink) |
Take it to a tech?
Schecter Hellraiser Special Solo-6, EMG 81, 85 Schecter Hellraiser Special C-7, EMG 81-7, 707 Ibanez RG5EX1 w/DiMarzio D-Activator bridge & The Breed neck, DiMarzio Air Norton S middle Agile AL-2000 w/DiMarzio Steve's Special & DiMarzio Air Norton, Gotoh hardware Blackheart BH5H w/Electro-Harmonix 12AX7 and JJ EL84 tubes Blackheart BH412ST Straight 4x12 ![]() Mesa Boogie Throttle Box AMT Legend D2 "Diezel" Dunlop Original Crybaby Digitech DigiDelay MXR Noise Clamp |
#12 (permalink) |
shouldn't you be able to plug the hole, glue it in tight, sand it down nicely and re-drill for the post as needed? You've said you haven't started painting it yet. A solid fill job should do the deed I would think.
HM Strats - Rhinehart RB(tele) - Epiphone Double neck Mesa 5:25 w/2 cabinets G-Major - Boss and danelctro pedals |
#13 (permalink) | |
#14 (permalink) |
What do you suggest I would use for that? I'd think wood filler but I don't think that would bond well enough?
#15 (permalink) |
It will straighten out as you tap it in. I've learned not to force it, instead put a little liquid soap on it and it will slide right in. I would go ahead and put the insert in and tape it off to paint. Otherwise you may fill the hole with paint and then really have a hard time getting the inserts in. You can plug the insert with cotton to keep paint out of the threads.
This space for rent. Inquire within. |
#16 (permalink) | |
#17 (permalink) |
Seems to be fine, I just finished popping in the bridge and tailpiece today. Almost DONE WITH THE PROJECT!
#18 (permalink) | |
#21 (permalink) |
Thanks! And the damn hardware for the pickup rings and backplate, just the screws cost me half of what the guitar did. BOOOOO
| Tags |
| agile, graphtech, ruined, tailpiece |
