Go Back   Les Paul Forums > Music Gear > Other Guitars
Unread 03-19-2010, 08:55 AM   #1 (permalink)
kitarr's Avatar
Send a message via MSN to kitarr
Sticky acoustic's neck
Hey.
I got kinda sticky neck. Is this the best way if i use steel wool to wipe that finish off?
Any problem you can't solve with a good guitar, is either, unsolvable or isn't a problem.
kitarr is offline   Reply With Quote
Unread 03-23-2010, 09:21 PM   #2 (permalink)
Fretboard's Avatar
Re: Sticky acoustic's neck
Before you go steel-wooling anything I would recommend you wipe the guitar with a rag and if possible some fretboard conditioner or cleaner. Just make sure not to over apply.
Guitars:
1976 Gibson Les Paul Custom
1968 Martin & Co 0-18
1980 Martin & Co D-28
1973 Fender Telecaster Blonde (Blackguard)
Amps
Fender Blues Deluxe 40 watt
“All I can do is be me, whoever that is.”
-Bob Dylan
Fretboard is offline   Reply With Quote
Unread 03-25-2010, 08:22 AM   #3 (permalink)
King Matthew's Avatar
I have found what works the best for me is 0000 steel wool, lightly. Just a few passes at a time. Then I spray some finger-ease on the back of the neck and rub it back and forth until it is nice and smooth, soft, and fast. There have been some guitars that I have had to do this to several times to get just right. Remember there is no going back after you have done it though. YMMV.
King Matthew is offline   Reply With Quote
Unread 03-25-2010, 08:25 AM   #4 (permalink)
dennistruckdriver's Avatar
Originally Posted by Fretboard View Post
Before you go steel-wooling anything....
Originally Posted by King Matthew View Post
I have found what works the best for me is 0000 steel wool....
Nothing like a little contradiction to confoozle the OP.
Unread 03-25-2010, 08:41 AM   #5 (permalink)
Well for clarification..........I would try fretboard's advice first.... I thought that it would go without saying that you should try the non-permanent method first.
