#1 (permalink) |
Help Identifying my Gibson SG
So I've got this refinished SG of mine that is sorta the black sheep of my collection. I bought it from Guitar Center when I was younger and didn't know enough about guitars. Never really been sure what year it is but I've suspected it "might" be somewhere in the 60's.
The serial was pretty much refinished over but you can barely make out a few of the numbers. Someone etched the serial in the inside of the control cavity cover, 500242. It is by no means original or in great shape. The tuners are barely in there and the back of the headstock on the G string has a crack in it towards the top, but it doesn't break the veneer on the face of the headstock. The pickups are not original, they are 57 classic/57 classic plus. I think the tuners and bridge and possibly the maestro tailpiece might be original but I wouldn't bet on it. Electronics are probably not original either. Oh yeah... in my infinite wisdom I put a SG standard full pickguard on it at one time. Recently removed but the screws holes are there. ![]() It works, it plays, low action, blah, blah but I'm unsure what to do with this thing. Keep it, sell it? Any idea what this thing is worth? I mean it is a straight players guitar or if someone wanted to get crazy it would be a good restrotation project I guess. Any help will be greatly appreciated! So to recap, what year do you think this is and what's it possibly worth? ![]() I took a crap load of photos. Here's the whole album: Gibson SG pictures by scottsmith6565 - Photobucket Here's just a few to see what I'm talking about: ![]() ![]() ![]() ![]() ![]() ![]()
#2 (permalink) |
Re: Help Identifying my Gibson SG
If that SN is right, it looks like 1969. Tuners look factory, so does the bridge and tailpiece. Since it was already refinished, it is a player, and you probably did little harm by adding a few screw holes. If you want, I'd replace the tuners and try it out. It is a player's guitar, and I bet it sounds good with the '57's.
I love older modded guitars over pristine collectables, and I'd have no problem playing that SG. It was mine, I'd certainly keep it and use it. Play it a while and see what you think. mark Here's a very clean '69... http://www.rumbleseatmusic.com/vinta...ardCherry.html Pristine, they run between $3500 and maybe $5500. I never liked SG's either, till I started playing one...
"There are a million ways to play guitar." Les Paul WWKRD - What Would Keith Richards Do - my guiding motto in life, which explains a lot... ![]() Another far left gun owning veteran. |
#3 (permalink) |
Well I've never really cared for SGs personally, so I thought about getting rid of it to get another LP that I would actually play.
#4 (permalink) | |
I warn you-if you start playing it, they grow on you... mark
#5 (permalink) |
Thanks for the advice mark. I've had my fair share of playing time on it, but it just isn't my thing. Well what do you guys think it's worth in its current condition?
#6 (permalink) | |
beautiful example tho'
"If you get far enough away you'll be on your way back home." - Tom Waits |
#9 (permalink) |
A 69 will have a small volute...Earlier SG's don't have one. Didn't see a pic of that area.
If you want to sell it yourself, think about between $2200-$2800, IMO. mark
#11 (permalink) |
A volute is a bump on the back of the neck at the base of the headstock designed to strengthen the area around the truss rod cavity. I think it looks nice but it could look better with a refin (do you think the SN# is sanded off or just filled with finish?). I had a '68 and it was an amazing guitar; I'd still have it if an airline hadn't decided it would look cooler in multiple pieces. Is that finish lacquer?
#12 (permalink) | |
I'd say it's glossy.
#14 (permalink) |
I wouldn't assume the guitar is a 65 based on a pot if the SN# indicates 69, those pots could have been sitting in a box for years before they were used. Pots help with the year determination, but I wouldn't call it confirmation. From what I understand volutes started in 68/69 depending on the model, so having no volute does not mean it's not a 69.
I think; I would be considered a hobbyist, not an expert. |
#15 (permalink) |
That IS NOT a 69.
I would guess a 65 or earlier. In 1966 they went to the large batwing pickguard. Those knobs are early to mid 60s also. Definitely a restoration project. As is I would say it could bring in $2500 -$3500. Sad part is that it may be worth more if you parted it out. The PUs (I'm assuming Stickered Patent#s) could bring as much as $500 each or more. Also, a lot depends on the nut width. In 1965 they switched from the 11/16" to a 9/16" nut width. The 11/16" nut width is much more desirable.
Rewind |
#16 (permalink) | |
#17 (permalink) | |
#19 (permalink) |
Well I threw this up in the MLP classified section to see if I could trade for a lemon or amber LP. So if anyone's interested PM me.
#21 (permalink) |
![]() Join Date: Aug 2010
Can't see any of the pictures.
"An SG is your drunken brother-in-law who rides a Harley and scares women and small animals" - Thumpalumpacus |
#23 (permalink) |
I tried that. They come up as red X's.
#25 (permalink) |
Traded to 52trapeze for his '88 LPC tobacco sunburst. Should be here this Friday, looking forward to it. Hope all goes well.
