MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Gibson Les Pauls > Norlin Years
Unread 06-22-2010, 08:47 PM   #1 (permalink)
Ed K's Avatar
goof rings
I have a 73' deluxe with goof rings around the pickups. But, the pickups are minibucckers which I presumed are original. Does the goof ring necessarily indicate that the guitar has been routed somewhere along the way? Or did they use them on non-routed guitars as well?
Ed
Ed K is offline   Reply With Quote
Advertisement
Unread 06-23-2010, 05:30 AM   #2 (permalink)
circusboy28's Avatar
Re: goof rings
I've seen factory goof rings on Deluxes that haven't been routed for buckers, at least on one LP that I can remember seeing. I assume that you've had a look at the routs in yours?
circusboy28 is offline   Reply With Quote
Unread 06-23-2010, 07:13 AM   #3 (permalink)
Mildperv's Avatar
Re: goof rings
Goof rings are for poor minihum routes done at the factory.
____________________
I stayed for the flush but got the straight instead
Mildperv is offline   Reply With Quote
Unread 06-23-2010, 07:45 AM   #4 (permalink)
dwagar's Avatar
Re: goof rings
I tend to think they were a design idea rather than a fix for a production error (poor routing). But either way, they were installed at the factory.
Don
Primary Tone: what the body and neck does not have cannot come out as tone - Iwanade, BOTB
Originally Posted by reswot
A 50's Special is, IMO, the coolest guitar ever made.
dwagar is offline   Reply With Quote
Unread 06-23-2010, 09:31 AM   #5 (permalink)
Mildperv's Avatar
Re: goof rings
Certainly could be. I have goof ring screw scars on my Deluxe but it's been routed for HB's so I can't comment on original route neatness. I don't mind the look of goof rings, but the sporadic use of them makes me think it's cosmetic.
Unread 06-23-2010, 11:26 AM   #6 (permalink)
dwagar's Avatar
Re: goof rings
when you consider how many thousands of Les Pauls they routed for P90s, I just can't see them all of a sudden not able to route properly.
Don
Unread 06-23-2010, 12:42 PM   #7 (permalink)
choppedcadillac's Avatar
Re: goof rings
goof ring is a misnomer; its a pick-up schroud
choppedcadillac is offline   Reply With Quote
Unread 06-23-2010, 01:15 PM   #8 (permalink)
Mildperv's Avatar
Re: goof rings
Maybe not the router, but I have certainly had grain flaws and have had an edge flair from time to time. Particularly if it is flat sawn.
Unread 06-23-2010, 08:01 PM   #9 (permalink)
Ed K's Avatar
Re: goof rings
Circusboy,
I've not taken the pickups out. I figured since the rings were seated with what looks like a nail or a tack, rather than a screw, I'd leave it alone. Thanks to all for the info.
Ed
Unread 06-23-2010, 11:19 PM   #10 (permalink)
Re: goof rings
Yep, it's been a while & I'd forgotten that they were originally tacked not screwed. I was actually talking to a mate about this yesterday, he's been around a long time and he reckons that Gibson used them on guitars with minor finish issues around the pick up cavities...so there's another theory for you!
Unread 06-24-2010, 05:33 PM   #11 (permalink)
Ed K's Avatar
Re: goof rings
If I was to take off the rings what is the best way, so that the tacks will reseat when I put them back on?
Unread 06-24-2010, 11:46 PM   #12 (permalink)
hbar's Avatar
Re: goof rings
Ok, I'll ask. What are goof rings? I've been here for a while, but this is the first I've heard that phrase.
my band, the circle
1974 Custom - Honeyburst ex-Black Beauty
1980 Custom - Silverburst
1981 Custom - Wine Red
1994 Standard - Candy Apple Red
2007 Studio - Platinum
hbar is offline   Reply With Quote
Unread 06-25-2010, 09:38 AM   #13 (permalink)
Re: goof rings
They're the extra white plastic outer rings that fit around the white plastic mini hum rings on some seventies LP Deluxes. I've never seen it but apparently they are on some LP Pros too.
Unread 06-25-2010, 11:36 AM   #14 (permalink)
Csharp's Avatar
Re: goof rings
hbar, Here they is....
Charlie (Luddite Standard)
'74 LP Standard-tobacco burst, and 8 misc. lesser guitars
"It's always cool to be quoted into somebodies signature" - brettk7
Csharp is offline   Reply With Quote
Unread 06-25-2010, 02:07 PM   #15 (permalink)
hbar's Avatar
Re: goof rings
Aah, I don't may much attention to Deluxes. Ebony board or stay home, I always say.
my band, the circle
Unread 06-25-2010, 06:15 PM   #16 (permalink)
John Vasco's Avatar
Re: goof rings
I would suggest leaving them on. LP Deluxes will only go up in value over time. And those with goof rings, being a lot more scarce than those without, will, I believe, attract a higher value.
Live clip of Splinter at The Cavern, November 2006: http://www.youtube.com/watch?v=GxOCksQUKbI
There are always crowds at Stonehenge. Doesn't mean they're all f*ckin' Druids...
D Major is a key, not a pitch.
John Vasco is offline   Reply With Quote
Unread 06-25-2010, 06:17 PM   #17 (permalink)
John Vasco's Avatar
Re: goof rings
Goof rings and a 5-piece top! Superb.
Unread 06-26-2010, 04:47 AM   #18 (permalink)
Re: goof rings
I need those outer ring to retro fit P90's to my routed 71.
marantz1300 is offline   Reply With Quote
Unread 06-29-2010, 04:43 PM   #19 (permalink)
moff40's Avatar
Re: goof rings
I'm pretty sure it won't work. They're not for converting full humbucker holes back to P-90\Mini size. I suppose you could try though...
'05 Gibson LP Faded DC
'90s Gibson LP Custom
'80 Gibson LP Deluxe
'77 Gibson LP Deluxe
'74 Gibson LP Deluxe
'78 Fender Telecaster
'92 Fender American Standard Stratocaster
'11 Fender American Standard Stratocaster
'90 Ibanez RG550
'06 Line6 Variax 500
'99 Raven electric 12-string
'86 Yamaha APX-6L acoustic\electric
'81 Takamine F400-S 12-string acoustic\electric
Warwick endorsing artist:
Corvette $$ 4- and 5-string basses
moff40 is offline   Reply With Quote
Unread 06-30-2010, 09:06 AM   #20 (permalink)
sangandongo's Avatar
Re: goof rings
No, but they would make sure that the pickup didn't wobble around in the routed cavity. Remember how P90s are mounted...
j.k
'55 Gib LP Jr, '63 Gib MM, '63 FB III, '64 FB III, '65 Epi Oly, '67 SG Std, '71 LP DLX
'44 Epi Zenith, '53 Epi Zenith, '61 Fender Jazzmaster, '66 Fender Jag B&B
sangandongo is offline   Reply With Quote
Unread 06-30-2010, 09:30 AM   #21 (permalink)
Re: goof rings
I think it would work.Here's a pic of the routes on my 71 Deluxe.You can see the origanel routes are P90 size.The extra routing for humbuckers makes them slightly wider.The mini humbuckers with their rings are the same size as a P90,so the outer goof hiders should fit a P90 and the ring width should hopefully cover the humbucker routing width.
Unread 06-30-2010, 09:47 AM   #22 (permalink)
Re: goof rings
I am also pretty sure it would work.
j.k
Unread 06-30-2010, 02:20 PM   #23 (permalink)
moff40's Avatar
Re: goof rings
Maybe - but I remember comparing the goof rings to the size of a 'bucker ring, and IIRC, the goof ring is still narrower. Still, it's worth a try if you can find a pair of goof rings cheap enough...
'90 Ibanez RG550
Unread 06-30-2010, 02:51 PM   #24 (permalink)
Re: goof rings
I dont think I'll be able to find them at all,so I'll make some to fit.
Unread 06-30-2010, 05:08 PM   #25 (permalink)
veeman's Avatar
Re: goof rings
Ebay!!
veeman is offline   Reply With Quote
Unread 07-05-2010, 11:08 AM   #26 (permalink)
Re: goof rings
First step.I bought a SD vintage P90,have another on order. You can see the routing that needs hiding with a Goof hider. When the other pup comes I'll make the rings.
Unread 07-05-2010, 02:57 PM   #27 (permalink)
Re: goof rings
What I like about this is that you -can- put an HB in it without ruining the guitar.
j.k
Unread 07-05-2010, 03:05 PM   #28 (permalink)
lp_junkie's Avatar
Re: goof rings
Epiphone prototype?
Shane
Just a guitar bum...........
lp_junkie is offline   Reply With Quote
