#2 (permalink) |
Re: Bridge grounding....
I did this. If I had noticed before I refinished the guitar, I'd have done something different. I'll add a washer paddle the next time I change strings.
#4 (permalink) |
Well....like I said...if I had noticed before the refinish, I'd have done it differently but this is unobtrusive and can be removed if need be.
#5 (permalink) | |
I like yours, though...no holes... |
#7 (permalink) |
Not sure that I understand the original question. What happened to the wire that ran from the tail insert to one of the pots?
Charlie '74 LP Standard-tobacco burst, and 7 misc. lesser guitars |
#9 (permalink) |
Thanks, I didn't know that some came without. Mine has the "human hair", but has never been a problem. Now that I think about it, they probably used high E string clippings.
#11 (permalink) |
gauge is not a factor , even pup wire will work - unless you're grounding for lightning . .
You've got to pick up every stitch, Beatniks are out to make it rich, Oh no, must be the season of the Witch ?
#12 (permalink) |
That is very clever.
#13 (permalink) |
No longer cares....
![]() Join Date: Apr 2008
What I did when I installed a Bigsby on my SG was to drill a hole through the pickup cavity into the mounting screw hole of the Bigsby, then run a bare wire into the screw hole, where the threads of the screw would make contact. I soldered the other end to a suitable ground somewhere on a pot body.
You could do a similar procedure on a bridge or TP screw hole, couldn't ya?
I officially don't care anymore!
#14 (permalink) |
![]() Join Date: Apr 2007
yes. with a TOM bridge, it is very easy.
a. pull out the TOM bridge stud b. drill hole from bridge pup cavity to TOM stud hole c. insert copper or whatever wire from TOM stud hole to pup cavity to cpa cavity d. solder to pot. e. re assemble. if there is an exsisting ground wire hole in the cpa cavity a. remove TP, use tp stud to remove TP bushing b. locate ground wire hole (possibly old GW maybe there) c. rethread new ground wire, solder to pot in cpa d. reassemble I do it all the time
#15 (permalink) | |
| Star Grounding ? | Superlead777 | The Custom Shop | 19 | 03-25-2009 11:53 PM |
| Grounding and Shielding | Yaemish | Epiphone Les Pauls | 6 | 02-17-2009 09:25 PM |
| Grounding | Belzeebub | The Squawk Box | 6 | 12-23-2008 03:13 PM |
| Please HELP with Grounding!!... | crispacket | The Custom Shop | 7 | 09-01-2008 04:23 PM |
| Grounding question... | Gaetano | The Custom Shop | 2 | 04-02-2008 10:21 AM |
