#1 (permalink) |
One of Brit's "employee seconds?"
This one's kinda cool. Marked as a second. But it's got some unusual features. Factory Grovers, black plastics. Nicely done darkburst. I remember reading a post by Hot Brit that sometimes employee's marked a nice guitar as a second so they could get theirs hands on it cheap. Wonder if this is one of those?
1977 Gibson Les Paul Standard | eBay
LP's - '57 Alnico Custom, '61 Standard, '80 Heritage 80 Elite, '82 Heritage 80 Std., '83 Spotlight Special ASB, '83 Flametop 59 Reissue, '84 Goldtop Reissue, '05 Music Rising, '08 Spotlight proto ![]() Others - '59 ES-225TD, '64 Melody Maker, '69 Firebird I, '07 Martin OMC-28E Amps - '57 Fender Super, '77 MusicMan HD130R/212RH, '09 Orange Dual Terror 196? Echoplex EP-1 - serial # 856 |
#9 (permalink) |
Re: One of Brit's "employee seconds?"
Good eye. And am I not seeing a volute here?
#11 (permalink) |
Very difficult to tell, given the low light and the color. Which brings up something else. The color of the neck is significantly darker than the body. I wonder if it and the volute were shaved down and resprayed - which could account for the difference in the lower half of the headstock's color. Anyone here in the Baltimore area? I'd love to get a hands on description.
#12 (permalink) |
I'm not seeing a volute either. *shrug*
My Gibbos: 8x Epi FB 300 80 LP Pro Deluxe 86 LP Studio Std 87 SG Custom 91 SG Jr 93 SG Spc 94 SG Std 96 Firebird V 98 LP Std 98 Flying V 99 SG-X 01 SG Jr 02 SG Voodoo 03 Epi G-400 Vintage 07 Epi LP Std 08 SG Classic 08 SG Classic 08 Epi Goth T-Bird 10 SG 61 RI 11 SG 60s Trib 11 MM SG 12 SG 70s Trib
#13 (permalink) |
![]() Join Date: Aug 2010
look at the photo of the back of the headstock, the photo with the tuners on, still not convinced then send a question to the Ebay seller.
#15 (permalink) |
I looked at all the photos...looks smooth to me. If I wanted to contact the seller, I would, but I really don't give a toss...just sayin I don't see it either, that's all.
#16 (permalink) |
The top on that Tobacco Standard is gorgeous. Tim Shaw pickups on a '77 Les Paul is interesting. If I'm not mistaken, the original asking price was $2999 now it's $2500. Baltimore is not too far away. J.T., I will call to see if I can get an in hand description of the guitar. I'll let you know.
#18 (permalink) |
Fumble Fingers
![]() Join Date: Mar 2010
The dates on the pots suggest that they have been replaced as have the pups. Everything there is early eighties. The neck looks to have been shaved and re-sprayed. The color is lighter around the serial number and other markings. They are asking a lot for a non-original guitar.
Les is more! |
#20 (permalink) |
I expanded the photos and examined them carefully, i was wrong there is no volute, it was just a shadow i was seeing.
I now believe the guitar is a 1982 model, 1378136 pot codes dates the pots to being manufactured 36 week of 81, pickups are Tim Shaw reissues, the cutaway shape is the shape that was used in the early eighties and the small headstock. Also grover tuners were fitted as standard equipment at that time. But the serial number is not correct for a 1982 model, so it is a mystery for sure. |
#21 (permalink) |
Fumble Fingers
Hot-Brit, how do explain the serial number then? This was made during the time they had a date code in them. It clearly has a neck that was stamped in '77 and they only serialize finished guitars. The pot codes are clearly 81. The pups are 81 & 82. The knobs are wrong as you noted. The finish around the serial number is odd to say the least. The guitar tells a different story than the owner does...
Les is more! |
#23 (permalink) |
large frets, the speed knobs are newer replacements, the poker chip looks new and pickguard looks like it is not original, it is a Custom style guard.
#25 (permalink) |
![]() Join Date: Mar 2007
Actually, the serial number is stamped on the neck before it is fitted into the body. This is the production norm, BUT there is nothing stopping an employee from making a custom shaped neck, and stamping the serial number later on a finished guitar either.
#26 (permalink) |
also the lacquer on the back of the headstock in the area around the serial number has obviously been sanded off for some reason, why? could it be because the original number was sanded off and then re-stamped with a different number?
#27 (permalink) |
It's unclear to me whether it's been sanded off, or if a respray may have only been done up to the point where it gets lighter in color. I'm starting to wonder if this might have been a re-neck, or if someone modified the original neck. If the seller had a return policy I'd take a chance on it, just to figure out WTF it is...
#28 (permalink) |
Fumble Fingers
It does look like 3 piece mahog but could be maple. Would have been maple in '77, right? May be a parts guitar made at the factory and stamped as a second. Hence the employee second theory. This could very well be the case. Neck stamped in '77 with no volute, or volute removed, assembled in '82 with Shaws.
![]() It is a very interesting guitar with a mysterious origin...
Les is more! |
#30 (permalink) | |
