Go Back   Les Paul Forums > The Les Paul > Gibson Les Pauls > Norlin Years
Like Tree95Likes
Unread 02-14-2012, 07:47 AM   #61 (permalink)
pmonk's Avatar
Re: Show your Heritage 80!
New pic I recently took for the Heritage love!
framos, gtrplayr1976 and Kezman like this.
pmonk is offline   Reply With Quote
Unread 02-14-2012, 08:47 AM   #62 (permalink)
gtrplayr1976's Avatar
My second 80 Heritage Standard 1980. Both were Cherry Sunburst, but not clown burst
GammyBird and BuzzHaze like this.
gtrplayr1976 is offline   Reply With Quote
Unread 02-14-2012, 09:28 AM   #63 (permalink)
69 Goldtop's Avatar
Nice one!
gtrplayr1976 likes this.
69 Goldtop is offline   Reply With Quote
Unread 02-14-2012, 09:31 AM   #64 (permalink)
Originally Posted by 69 Goldtop View Post
Nice one!
Thanks , It sounds ,and plays great. It had been refretted ,but I like these much better than the wide flat ones. I added PIO caps ,and wired it 50s style.
Unread 02-14-2012, 02:10 PM   #65 (permalink)
69 Goldtop's Avatar
Does that have Nashville or ABR posts?
Unread 02-14-2012, 02:25 PM   #66 (permalink)
Originally Posted by 69 goldtop View Post
does that have nashville or abr posts?
abr
Unread 02-15-2012, 02:38 AM   #67 (permalink)
Originally Posted by Blackdog View Post
I installed the ground wire in the proper way: pulled the insert, drilled the hole.
I bought a Faber ABR for the guitar, but didn't like the looks. The neck angle is a bit steep and the smaller bridge didn't look right all the way up there. But the other changes made sense: there was a lot of free play between the posts and the tailpiece and between the Nashville thumbwheels and the inserts. Still the guitar sounded amazing ! But with the changes it sounds just a bit better.
I also thought about changing the pots, I believe it comes with 300K volume and 100K tone. But the solder joints are unbroken, and I'm happy with the sound I got just by removing the covers, so I opted for leaving it unmolested.
It is heavy. Almost ridiculously heavy: 4.9 Kg, 10.8 lbs
There is a thread around here where the OP claims that by removing all the metal shielding from the cavities his guitar lost more than a pound. It would be great, but I find it very difficult to believe that the metal parts weight THAT much.
I dont have a heritage 80 to show but...
I read the thread you refer to about removing the shielding and I didnt really believe it so I tried it and I also lost 1lb in weight from my 81 custom.
I weighed the removed parts on a digital scales and compared the ones that were to be the replacements and its a total of 1lb in weight in difference I also weighed the guitar before and after
that 1lb makes a significant difference to how heavy the guitar feels and its enough that it stops my back ache.
one of the biggest culprits is the tailpiece.
the tailpiece on my 81 custom weighed 5 oz I replaced it with a faber which only weighs 1 oz so thats a quarter of a pound saved ,
by the time you remove all the cavity control shielding the shielding can for the jack and shielding for the three way switch and pickup covers and then change the pots you will lose a pound .
for example changing the pots on my custom resulted in a saving of 1.7 oz
it doesent sound much until you put it all together ...... then it makes a difference
a word of warning though removing the shield for the three way switch is tricky but there is a technique for doing it which will give you less of a headache if you try it
the only thing I changed that didnt make any difference to the weight was the bridge.
I bought a faber abr and it weighed exactly the same as the nashville but... all the other stuff made up a 1 lb weight loss
which was enough of a difference for me to decide to keep the guitar instead of selling it
by the way your heritage 80 guitar is stunning .....
druckpig is offline   Reply With Quote
Unread 02-15-2012, 04:58 AM   #68 (permalink)
Cookie-boy's Avatar
Location: Under the care, custody and control of Matron.
Originally Posted by J.T. View Post
They were Gibson's first official shot at a vintage reissue. Frowned upon by purists who feel they lack accuracy, they signaled Gibson's understanding that their customers wanted Les Pauls that were more like the originals. More info can be found here: Gibson Les Paul Late 70’s/Early 80’s “Pre-Reissues”: On the Road to ’59?
EDIT: Oh, yeah, they were also the first guitars to have the Tim Shaw designed PAF pickups.
Yep, first "official" shot at a production run "Re-issue" and lovely looking instruments too I must say. Not "vintage correct" as you mention but then none of the "experimental" stuff that preceded them was either.
Cookie-boy is offline   Reply With Quote
Unread 02-19-2012, 07:44 AM   #69 (permalink)
expo's Avatar
expo is offline   Reply With Quote
Unread 02-19-2012, 08:02 AM   #70 (permalink)
pmonk's Avatar
Originally Posted by expo View Post
Awesome!
Unread 02-20-2012, 05:30 AM   #71 (permalink)
Smile Re: Show your Heritage 80!
Originally Posted by kmrumedy View Post
Anyone on here have a Heritage 80 Goldtop? Only ever seen one.
I have a friend who has a Goldtop Heritage series 80, as well as a black one.. There is supposedly only made a handfull of each. I know of 3 Goldtops and 2 Blacks. But exact numbers I dont know.
I will post some pictures soon. We are 3 good friends who have 6 Heritage series 80 shared between us
All the best
henrikberger2005 is offline   Reply With Quote
Unread 02-21-2012, 07:33 AM   #72 (permalink)
J.T.'s Avatar
You do realize that this now requires you to post pics of ALL OF THEM, don't you? Can't wait to see them. And it's cool to have a nest of Heritage 80 activity in Denmark. Very cool.
henrikberger2005 likes this.
LP's - '57 Alnico Custom, '61 Standard, '80 Heritage 80 Elite, '82 Heritage 80 Std., '83 Spotlight Special ASB, '83 Flametop 59 Reissue, '84 Goldtop Reissue, '05 Music Rising, '08 Spotlight proto
Others - '59 ES-225TD, '64 Melody Maker, '69 Firebird I, '07 Martin OMC-28E
Amps - '57 Fender Super, '77 MusicMan HD130R/212RH, '09 Orange Dual Terror
196? Echoplex EP-1 - serial # 856
J.T. is offline   Reply With Quote
Unread 02-21-2012, 01:17 PM   #73 (permalink)
BuzzHaze's Avatar
Expo...that LP is GORGEOUS!!!!! me want...me want
BuzzHaze is offline   Reply With Quote
Unread 02-25-2012, 12:37 PM   #74 (permalink)
expo's Avatar
Thanks.
I will definitely sell her in the future..but I am in Europe.
Unread 02-26-2012, 11:16 PM   #75 (permalink)
J.T.'s Avatar
The darkburst is now up for grabs. My Leo's, too. If you're interested, please check the member's classifieds. Thanks!
Unread 02-28-2012, 07:09 PM   #76 (permalink)
this is my 1983 reissue. not quite a heritage 80 but close
1680dw is offline   Reply With Quote
Unread 02-28-2012, 10:50 PM   #77 (permalink)
J.T.'s Avatar
Welcome! Why don't you start up a new thread for pics of the early reissues? That way we can get to know you better and see some more cool guitars. I know there's quite a few around here. Here's yours - nice:
Unread 02-29-2012, 12:35 AM   #78 (permalink)
Zack's Avatar
op, that one on the right best flame top iv ever seen
Everybody knows valves are better.
Zack is offline   Reply With Quote
Unread 02-29-2012, 08:30 AM   #79 (permalink)
J.T.'s Avatar
Pretty cool quilt, huh? Straight on, it almost looks like a snake belly.
Meanwhile, I'm raising cash for another purchase and wouldn't be opposed to selling it. Ping me if you're interested...
Unread 02-29-2012, 05:48 PM   #80 (permalink)
YMI5150?'s Avatar
Here's my 81. Amazing quilt. getting ready to unload it.
FUS44 likes this.
www.ymi5150.com
YMI5150? is offline   Reply With Quote
Unread 03-01-2012, 06:40 AM   #81 (permalink)
J.T.'s Avatar
Very cool - pointy horn & all!
Unread 03-26-2012, 12:30 PM   #82 (permalink)
kick the dog's Avatar
Location: no floods, hurricanes or fire ants; only the rare tornado and 4 seasons.
I would appreciate it if fellow forum members could point me in the direction of a sale for one of these. I've been looking on and off for 3 years now. There are just a couple currently that I know of, but I'm not getting too excited for one reason or another. Thanks.
kick the dog is offline   Reply With Quote
Unread 03-26-2012, 03:57 PM   #83 (permalink)
pmonk's Avatar
COntact J.T., he is selling his!
A couple of choice Norlins - Heritage Standard 80 & Leo's reissue
This one is on ebay.
1981 Gibson Les Paul Heritage 80 RARE !! | eBay
Unread 03-26-2012, 05:53 PM   #84 (permalink)
Ok, let's keep this rolling.
J.T. likes this.
Atomheartmutha is offline   Reply With Quote
Unread 03-26-2012, 06:20 PM   #85 (permalink)
J.T.'s Avatar
Looks like an Elite - what year? Love that quilt - looks like sand dunes from 10,000 feet up.
Unread 03-26-2012, 06:21 PM   #86 (permalink)
J.T.'s Avatar
What gets you excited, then?
Unread 03-26-2012, 06:37 PM   #87 (permalink)
It's an Elite from late July 1980. The top makes me smile every time I open the case.
Unread 03-26-2012, 08:59 PM   #88 (permalink)
J.T.'s Avatar
Mine's September, I believe. 82680xxx, whatever that works out to. And I know that shit eating grin.
Unread 03-27-2012, 10:25 AM   #89 (permalink)
[QUOTE=kick the dog;3675235]I would appreciate it if fellow forum members could point me in the direction of a sale for one of these. I've been looking on and off for 3 years now. There are just a couple currently that I know of, but I'm not getting too excited for one reason or another. Thanks.[/QUOTE
I may be selling mine shortly if you're looking.
Unread 03-28-2012, 09:02 PM   #90 (permalink)
aubie's Avatar
Those are great looking guitars. I have a metallic red heritage standard 80 elite that is one of the best sounding guitars I've ever heard. The only problem is I can't find any info on it.
aubie is offline   Reply With Quote
