Go Back   Les Paul Forums > The Les Paul > The Custom Shop > Luthier's Corner
Like Tree28Likes
Unread 06-20-2010, 11:54 PM   #61 (permalink)
Bartlett Retrospec Member
monsterwalley's Avatar
Re: build #3 56 Goldtop
Thanks guys! As sick as this is going to sound...... It was kinda fun
I also know that next time I drill an input jack hole too big, I will be able to fix
it even better.
______________________________________________
monsterwalley is offline   Reply With Quote
Unread 06-21-2010, 01:20 AM   #62 (permalink)
beuford23's Avatar
Location: Middle Earth: AKA CFB Gagetown, Oromocto New Brunswick
My grandfather taught me that if you make a mistake then make sure the "fix" looks like it was an intentional part of the design: aesthetics or function. Either way, I think it turned out great.
beuford23 is offline   Reply With Quote
Unread 06-21-2010, 02:08 PM   #63 (permalink)
Fumble Fingers
gtr-tek's Avatar
Originally Posted by monsterwalley View Post
Thanks. Where are you located in Kansas?
About 65 miles west of KC. The storms have been moving around a lot!
Nice save on the jack hole!
Les is more!
gtr-tek is offline   Reply With Quote
Unread 08-17-2010, 10:57 AM   #64 (permalink)
Pennstate913's Avatar
So are there any update pics, or have you finished this awesome project?
Pennstate913 is offline   Reply With Quote
Unread 08-17-2010, 11:10 AM   #65 (permalink)
SG Lou's Avatar
Damn, Nice save on the jack hole resize !
Now i just hope my "patch" job comes out just as well. Only problem is I won't have a jack plate to cover my screw up !
Can you see the screw up in the cut away?
Yup, I forgot that the binding channel get cut AFTER the top is contoured !
Thank god it dawned on me before i did the entire cutaway
"It's all Iommi's fault. I blame him entirely"
A.L.S. aka Lou Gehrig's disease Sux.
Lets rid the world of this dreaded disease
I CAN'T SEE OR POST PICS,PHOTOBUCKET IS BLOCKED ON WORK PC'S
Moritz Guitars
stmoritzguitars@hotmail.com
Guitars:
64 SG Special
Custom Shop Iommi Sig. SG
Epi Iommi SG
Jaydee "Old Boy" SG
Custom Built "Old Boy" SG replica
63 RI Strat
Amps:
Laney GL50 head w/4x12 Laney Cab.
Laney LC15R, Line6 Spyder
SG Lou is offline   Reply With Quote
Unread 08-17-2010, 07:05 PM   #66 (permalink)
I've gotten a little further. I've gotten the neck roughed out, the inlays in the braz and am finishing up the binding. On this one I am going after the "refretted" look, so I'll do the frets over the binding.
I also got commissioned to build a guitar for a friends daughters. So unfortunately mine will go on the back burner for now. It would be nice to be able to spray both at the same time. We'll see.
Unread 08-17-2010, 07:16 PM   #67 (permalink)
Thanks! Complacency after a couple successful builds is trying to get me around every corner And when I do get some time to work on a guitar, I have to try and keep myself from racing through procedures.
Good thing you caught the binding route before you got all the way through,
shouldn't be quite as bad. I'm sure you'll sneak out of it successfully
I have followed your sg builds with great envy, I would love to build one for myself someday. It's on the list, ha-ha........ thanks for checking the thread out.
Unread 09-01-2010, 12:01 PM   #68 (permalink)
RAHAZ's Avatar
Any update to this Goldtop?
1932 Gibson L-00 "Stacy" (Needs Restoration)
2003 Epiphone Les Paul Custom Elite "Elly"
2008 Epiphone J-200 "Noel"
???? Tacoma Acoustic-Electric "Ruby"
Under Construction
2008 Hilleboe 5-String Bass "Amethyst"
2010 Hilleboe Mjöllnir
2010 Hilleboe Redwood Mjöllnir
RAHAZ is offline   Reply With Quote
Unread 09-01-2010, 02:27 PM   #69 (permalink)
SG Lou's Avatar
Here are a couple of pictures of where I am at currently....
First time attempting the angle route in the control cavity. Very frightening for me to pull the trigger on the router I think it turned out ok for my
first time.
Looks great to me........whats the chances of sharing a drawing of that template you used ?
Moritz Guitars
Guitars:
64 SG Special
Epi Iommi SG
Jaydee "Old Boy" SG
63 RI Strat
Amps:
Unread 09-01-2010, 06:01 PM   #70 (permalink)
Sure, no problem. I'll get some photo's and post them tonight.
Unread 09-01-2010, 06:56 PM   #71 (permalink)
Here you go Lou.....
These two pictures show the template I used. I started with around 7 degrees if I remember correctly. I ended up "tweaking it" and I'm not sure off hand
what I ended up with. I made it to use with a 3/4" bushing and 1/2" bit.
I drilled 1/16" holes where the pots go. Then used tooth picks to figure my depth and angle. I used the carpenters and regular pencil to help center up my jig and double check my cutting depth. I messed around lining it up and second guessing myself for a day before I got brave enough to pull the trigger on the router.
This is the bit I ended up using with a 3/4" bushing. Fletch helped me find it.
I think Preeb's thread pretty much sums it up though.
1959 Les Paul Build - Page 11 - Telecaster Guitar Forum
Unread 09-04-2010, 12:59 PM   #72 (permalink)
PoorMan's Avatar
The top I got from Tom...
Tom sells plaintops?
Awesome build BTW. I subscribed.
PoorMan is offline   Reply With Quote
Unread 10-12-2010, 11:00 AM   #73 (permalink)
any updates?
Unread 10-12-2010, 05:35 PM   #74 (permalink)
rockappalla's Avatar
yeah updates?
rockappalla is offline   Reply With Quote
Unread 10-12-2010, 07:08 PM   #75 (permalink)
I wish I had some updates. Sorry I don't. It's on the back burner currently.
A friend of mine commissioned me, well, he's paying for the parts anyway, to build a guitar for his daughters. He had enough confidence in my other builds to go for it. It is chambered with the normal Les Paul stuff. No aging though. Bright shiny nickel, and a nice cherry burst. Haven't come up with the name on the headstock yet, something that ties in with his girls. If he likes it,
hopefully I get a modest donation for the guitar building fund
Unread 10-12-2010, 09:34 PM   #76 (permalink)
topo1983's Avatar
Send a message via MSN to topo1983
great job
where I live is not got that type of router bits
you think if I use this bit?
would have to change the tip to make a neat cut
I think it can work
topo1983 is offline   Reply With Quote
Unread 10-12-2010, 10:22 PM   #77 (permalink)
Abeunt studia in mores
MRJ5's Avatar
I think it can work
That will not work.
That is a drill bit and not made to cut with it's sides and will burn up quickly.
Additionally the router speed is much faster than a drill and the bit is not designed for that speed. If the bit is not EXACTLY the same size as the collet, it could fly out and cause injury.
Use the proper router bit please!
MRJ5 is offline   Reply With Quote
Unread 10-12-2010, 10:51 PM   #78 (permalink)
great job
I think it can work
Thanks for the compliment
As for the bit, as MRJ5 said, bad idea. Those twist drill bits don't have the tolerance for the rpm of a router. I'm afraid it would sail out and do some serious damage to your guitar and possibly even you. If it did stay in the collet, you probably wouldn't see what you are doing through all the smoldering wood.
Unread 10-12-2010, 10:52 PM   #79 (permalink)
ievans's Avatar
Seriously.
Don't put anything but a router bit in a router! 20,000 RPMs are no joke.
I'm certain you can get a router bit in Argentina somewhere.
ievans is offline   Reply With Quote
Unread 10-13-2010, 02:34 PM   #80 (permalink)
topo1983's Avatar
ok ok ok
after several attempts, managed to find a company that offers me this kind of tool for CNC
saying this
hardy to 25.000rpm
Unread 10-13-2010, 06:29 PM   #81 (permalink)
ok ok ok
saying this
hardy to 25.000rpm
Much better (safer) idea.
Unread 10-14-2010, 02:22 PM   #82 (permalink)
MLP Vendor
dougk's Avatar
ok ok ok
saying this
hardy to 25.000rpm
That will work, any ROUTER bit will work or even good aluminum end mill bits.
This is what I use: http://www.facebook.com/photo.php?fb...12433198791469 its sweeeeeeet
Originally Posted by DoneOne View Post
dougk 1:9 "there is nothing new under the Sunburst"
4/27 KAUER/RHONEY OPEN HOUSE! FOOD-MUSIC-BEER-GUITARS!
Owner: Kauer Guitars
Fan us on Facebook
Kauer Guitars: Federal Raid Free Since 03!
dougk is offline   Reply With Quote
Unread 10-14-2010, 09:08 PM   #83 (permalink)
i am wet's Avatar
looking good!
--Main Rig--
~Guitars~
2008 Gibson Les Paul Studio--Alpine White
2009 Gibson SG Special Faded--Ebony
2009 Epiphone Les Paul '56 Gold Top--Gold
1985 Fender F200 -- Natural
~Amps~
Egnater Renegade 65w Head
Egnater Tourmaster 2x12 Cab
Blackheart Little Giant 5w Head
2 Blackheart 1x12 Cabs
~Pedals~
Fulltone OCD
MXR Stereo Chorus
Dunlop 535Q Wah
TC Electronics Polytune
Radial ABY
i am wet is offline   Reply With Quote
Unread 06-08-2011, 06:59 PM   #84 (permalink)
RAHAZ's Avatar
Hey Monster... Did this build die?
Under Construction
Unread 06-08-2011, 07:05 PM   #85 (permalink)
Nope, I just got done doing a build for a good friends daughters
Then had to finish up a few other wifely duties and am getting back on it.
I was going to revive this thread in the next week or two ironically
Unread 06-08-2011, 07:15 PM   #86 (permalink)
RAHAZ's Avatar
Great googily moogily. Lucky kid! I hope she plays the hell out of it.
Under Construction
Unread 06-08-2011, 07:16 PM   #87 (permalink)
fatdaddypreacher's Avatar
what an excellant diversion. bet that's one happy little lady.
great job!
fatdaddypreacher is offline   Reply With Quote
Unread 06-08-2011, 09:42 PM   #88 (permalink)
great job!
It was actually for both his daughters. I hope they start
arguing over it enough that I am forced to build another.
Unread 06-08-2011, 10:45 PM   #89 (permalink)
Reverend D's Avatar
I know even though I love em I'd have to beat my brother senseless to gain control of that guitar... hehe... (He's 64 now, I think I can take him.. haha).
Regards,
Don
Reverend D is offline   Reply With Quote
Unread 06-09-2011, 01:45 AM   #90 (permalink)
Drew224's Avatar
You're really good, man.
Scarlet White
Drew224 is offline   Reply With Quote
