MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Luthier's Corner
Unread 02-09-2010, 07:40 PM   #31 (permalink)
crushmorgan's Avatar
Re: Royalite Binding
awesome....now if only I had the money
2008 Gibson SG Special Faded Red
crushmorgan is offline   Reply With Quote
Advertisement
Unread 02-09-2010, 08:28 PM   #32 (permalink)
73Custom's Avatar
very cool Tom
'73 LP Custom
'05 LP Standard Faded
'04 LP Goldtop Classic
Marshall TSL122
73Custom is offline   Reply With Quote
Unread 02-09-2010, 08:53 PM   #33 (permalink)
expo's Avatar
Originally Posted by alk-3 View Post
Yes, it should be 40 for binding, but it only allows it to be set up one way for some reason. I'll be spending some time over the next few days updating everything.
Alright
expo is offline   Reply With Quote
Unread 02-09-2010, 10:08 PM   #34 (permalink)
mapleflame's Avatar
Thank you bro, I just ordered some. I bet my guy Larry the Luthier will want some too.
No thank you to Burst
I'll Bronze instead.
I just love the green left on my arm in the morning. It Looks Like Victory.
mapleflame is offline   Reply With Quote
Unread 02-09-2010, 10:53 PM   #35 (permalink)
MLP Sponsor
alk-3's Avatar
Okay, I spent some time making the site a bit more user friendly. Cart option on all items, fretboards now available, and links to the home screen on each page.
Thanks to everyone who has ordered the binding already!
alk-3 is offline   Reply With Quote
Unread 02-09-2010, 10:55 PM   #36 (permalink)
73Custom's Avatar
excellent, the cart option is great !!!
'73 LP Custom
Marshall TSL122
Unread 02-10-2010, 02:07 PM   #37 (permalink)
MLP Sponsor
alk-3's Avatar
I just added the new tops to the site as well.
Unread 02-14-2010, 03:15 PM   #38 (permalink)
Sunburstman's Avatar
Hey Tom!
I ordered some of the royalite binding too, but I have a question can you dissolve bits of this material in a glass with acetone to make the so called binding glue?
P.S. You are doing great work!!! Speaking just for me and probably alot of other begining builders, we all have learned a wealth of knowledge from you and magnus!!!
Thanks,
J. M.
Sunburstman is offline   Reply With Quote
Unread 02-14-2010, 05:58 PM   #39 (permalink)
MLP Sponsor
alk-3's Avatar
Not sure if it melts in acetone as I don't use that method. I use superglue.
If I can remember I'll try it out when get back to the shop and report back.
Unread 02-14-2010, 09:32 PM   #40 (permalink)
monsterwalley's Avatar
I haven't given any thought to that. I wouldn't mind knowing either Tom.
monsterwalley is offline   Reply With Quote
Unread 02-15-2010, 05:09 PM   #41 (permalink)
expo's Avatar
That would be great to know.
Will the 8 feet be enough for two bodies if I use different neck binding?
Unread 02-15-2010, 05:14 PM   #42 (permalink)
MLP Sponsor
alk-3's Avatar
okay, I just tried it out - it does melt in Acetone.
Not sure on the length thing Expo, you'll have to measure yourself as I don't have a body here at the moment.
Unread 02-15-2010, 06:03 PM   #43 (permalink)
expo's Avatar
Great info with the acetone.
My feets are to big IŽll try to convert it. Is ist one piece exactly 8 feet long?
8 feet = 243,84 cm = 96"
if you need 53" per body (as fletch said) it is to short..hmm
I measure myself...I think its to short for two bodys.
thanks
Unread 02-15-2010, 06:09 PM   #44 (permalink)
MLP Sponsor
alk-3's Avatar
thanks
Yes, 96" long. I don't think it'll work for two bodies.
Unread 02-15-2010, 06:48 PM   #45 (permalink)
Thanks Tom!
Unread 03-25-2010, 06:26 PM   #46 (permalink)
MLP Sponsor
alk-3's Avatar
Look what showed up!
All orders are filled, and shipping first thing tomorrow morning. Thanks everyone for the pre-orders!
Unread 03-25-2010, 06:41 PM   #47 (permalink)
pinefd's Avatar
Tom, I can't remember whether I pre-ordered or not. Can you check for me? I know I meant to...
Frank
Check out some of my personal gear at: Historic Les Paul Database
http://histrungguitars.com/
pinefd is online now   Reply With Quote
Unread 03-25-2010, 06:46 PM   #48 (permalink)
Metamatic's Avatar
Frank
Same here, did I or did I not?
Metamatic is offline   Reply With Quote
Unread 03-25-2010, 06:52 PM   #49 (permalink)
MLP Sponsor
alk-3's Avatar
Frank, you didn't. Metamatic, You'll have to give me your name for me to check..
Unread 03-25-2010, 06:58 PM   #50 (permalink)
"rubs hands" together and anxiously waits
Unread 03-25-2010, 07:21 PM   #51 (permalink)
bfcg's Avatar
I did
.http://www.bfcguitars.com
bfcg is offline   Reply With Quote
Unread 03-25-2010, 07:27 PM   #52 (permalink)
pinefd's Avatar
Now I remember. I didn't order at the time because I had to try and figure out how much I needed...given my unusual size requirements. And then I forgot about it.
Do you still have some available?
Thanks!
Frank
Unread 03-25-2010, 07:30 PM   #53 (permalink)
MLP Sponsor
alk-3's Avatar
Hey Frank, i have plenty left, should have enough for a while
Unread 03-25-2010, 10:17 PM   #54 (permalink)
MLP Vendor
boogieongtr's Avatar
Tom,
Can't wait to get mine...
Jim
boogieongtr is offline   Reply With Quote
Unread 03-26-2010, 09:59 AM   #55 (permalink)
decoy205's Avatar
Nice work Tom! I wish I was building something lol.
Looks awesome.
decoy205 is offline   Reply With Quote
Unread 03-26-2010, 10:49 AM   #56 (permalink)
MLP Sponsor
alk-3's Avatar
thanks decoy, I'm excited about it. I've already done 3 bodies with it, and it is very easy to work with. The trick is to use a heat gun to soften it up.
This stuff is specifically used for thermoforming into plastic parts, so it responds to heat very well. Once it's pliable, just lay it around the horn and cutaway and in a few seconds it hardens back up and stays exactly where you put it. Pretty amazing really how well it works.
Unread 03-26-2010, 10:50 AM   #57 (permalink)
MLP Sponsor
alk-3's Avatar
oh, and it melts in acetone nicely too, making a very good glue/filler.
Unread 03-26-2010, 10:54 AM   #58 (permalink)
decoy205's Avatar
That would make sense that its easier to work with then the new plastics. I can't see the kalamazoo guys fighting with binding in the 50's if it molds easier you could see why they would use that material.
Unread 03-26-2010, 11:02 AM   #59 (permalink)
MLP Sponsor
alk-3's Avatar
my thoughts exactly.
Unread 03-26-2010, 01:07 PM   #60 (permalink)
Raz59's Avatar
Quick question Tom.
This "Royalite" plastic is Acrylonitrile Butadiene Styrene (ABS) and was only used in the top binding during the 50's, right?
Then, in the fretboard, Cellulose Acetate Butyrate (CAB) binding was used.
Or is it all "Royalite"? Sorry if this has been asked already.
Raz59 is offline   Reply With Quote
