Go Back   Les Paul Forums > The Les Paul > The Custom Shop > Luthier's Corner
Like Tree1Likes
Unread 01-16-2010, 12:54 PM   #1 (permalink)
TKOjams's Avatar
looking for plans to build a router table
Hey guys, at some point I'm going to build my own LP but, first I have to aquire the tools to do the job. I picked up a router today but all the tables seem like junk and much smaller than what I'm looking for. Does anyone have any plans for a router table that they would be willing to share?
Thanks,
Ken
TKOjams is offline   Reply With Quote
Unread 01-16-2010, 02:46 PM   #2 (permalink)
'59_Standard's Avatar
Re: looking for plans to build a router table
Jo/Expo posted about a Router Cutter supplier the other day and they had a page or two on building a Table - if its of any use. Someone else may have a link to some other plans.
Wealdon Tools
'59_Standard is offline   Reply With Quote
Unread 01-16-2010, 03:36 PM   #3 (permalink)
TKOjams's Avatar
Wealdon Tools
Thanks for the link, that should be usefull in the future.
Unread 01-16-2010, 03:49 PM   #4 (permalink)
SG Marc's Avatar
I think the most famous router table is the one that Norm Abram built. I know I cant build anything close to that, but, there are many plans for it on the net: Norms router table ,, just search "norm abram router table " forums usually have pdfs on similar designs.
SG Marc is offline   Reply With Quote
Unread 01-16-2010, 04:47 PM   #5 (permalink)
bfcg's Avatar
I highly recommend a lift table and get the one that accepts the cylindrical router motor, it gives you more up travel.
Something from this page: http://www.woodpeck.com/liftshome.html
.http://www.bfcguitars.com
bfcg is offline   Reply With Quote
Unread 01-16-2010, 06:52 PM   #6 (permalink)
DRF
I've been contemplating building or buying a GOOD router table. I have one of those table top ones from Canadian Tire/type thing. Its about as good as a router bolted to a hole in plywood...good for truss rod channel and back roundover and thats it.
I would like to step up to a full blown shaper or a heavy duty table-something that can handle a big long bit so I can rough shape neck profiles with a template.
As the old adage goes...get the best tool you can afford. In the real world that meant to me a $150 table top.
DRF is offline   Reply With Quote
Unread 01-16-2010, 07:20 PM   #7 (permalink)
bfcg's Avatar
I have run out of space for any more stationary tools. I thought about a shaper and then I got a pin router instead. 500 square foot addition going on in the spring.
Unread 01-16-2010, 07:36 PM   #8 (permalink)
SG Lou's Avatar
Speaking of Pin Routers, has anyone see this?
I was thinking about getting one but i'm not sure of it's quality !
G0587 Bench Top Overarm Router
"It's all Iommi's fault. I blame him entirely"
A.L.S. aka Lou Gehrig's disease Sux.
Lets rid the world of this dreaded disease
I CAN'T SEE OR POST PICS,PHOTOBUCKET IS BLOCKED ON WORK PC'S
Moritz Guitars
stmoritzguitars@hotmail.com
Guitars:
64 SG Special
Custom Shop Iommi Sig. SG
Epi Iommi SG
Jaydee "Old Boy" SG
Custom Built "Old Boy" SG replica
63 RI Strat
Amps:
Laney GL50 head w/4x12 Laney Cab.
Laney LC15R, Line6 Spyder
SG Lou is offline   Reply With Quote
Unread 01-16-2010, 07:42 PM   #9 (permalink)
bfcg's Avatar
It's good for certain things but you would be better off with buying some old heavy duty one that needs work if you plan on pounding out bodies.
Unread 01-16-2010, 07:46 PM   #10 (permalink)
SG Lou's Avatar
Bill, I don't compare to you when it comes to "pounding out bodies"
so that why I figured for what I do it would be good enough.
Moritz Guitars
Guitars:
64 SG Special
Epi Iommi SG
Jaydee "Old Boy" SG
63 RI Strat
Amps:
Unread 01-16-2010, 09:06 PM   #11 (permalink)
SG Marc's Avatar
Lou, you can build it..theres a bunch of plans for them on the web. check youtube
Unread 01-16-2010, 09:30 PM   #12 (permalink)
TKOjams's Avatar
Norm!!!!!!Norm is awesome, I was pissed when they took the yankee workshop of the air
Unread 01-16-2010, 09:39 PM   #13 (permalink)
TKOjams's Avatar
It looks like modding an old dresser would be the way to go I think.
I would just have to work out a way to mount a fence to it.
Unread 01-16-2010, 10:03 PM   #14 (permalink)
pinefd's Avatar
Lou, actually I just bought one of those as an X-Mas present for myself. I thought about getting something more heavy duty, but realized that there was no way I'd be able to get a big, heavy piece of equipment into my basement, so I "settled" on the Shop Fox. And so far, so good! I'm really getting a lot of use out of it...in fact, my router table is feeling quite lonely right now. But I have some real good tests coming up this week (hopefully), like pickup routes. I'll report back after I finish those. And one thing I'm really looking forward to trying with this little puppy is fingerboard inlay routes...but I still need to make the templates first.
Frank
Check out some of my personal gear at: Historic Les Paul Database
http://histrungguitars.com/
Please visit my new HiStrung Guitars Facebook page: http://www.facebook.com/pages/Histru...38001253029620
pinefd is online now   Reply With Quote
Unread 01-16-2010, 11:10 PM   #15 (permalink)
SG Lou's Avatar
Frank
ALRIGHT FRANKIE.....Keep us Posted and take a couple of pictures !
Moritz Guitars
Guitars:
64 SG Special
Epi Iommi SG
Jaydee "Old Boy" SG
63 RI Strat
Amps:
Unread 01-16-2010, 11:25 PM   #16 (permalink)
SG Lou's Avatar
Here's a couple you might want to check out.
http://www.bobsplans.com/FreePlans/DNLD/RouterTable.pdf
https://www.lowesrealtorbenefits.com...Mag/7.pdf?pg=5
and this link has several different designs you can choose from.
'table router free' woodworking search results at WoodworkersWorkshop.com
http://www.toolcrib.com/blog/2007/03...r-table-plans/
karlkrash likes this.
Moritz Guitars
Guitars:
64 SG Special
Epi Iommi SG
Jaydee "Old Boy" SG
63 RI Strat
Amps:
Unread 01-17-2010, 11:57 AM   #17 (permalink)
TKOjams's Avatar
Here's what I've come up with.
I'm going to pick up an inexpensive bathroom vanity, knock off the back splash and mount the router where the sink would normally set, (hopefully the hole for the sink isn't cut yet) leaving room underneath for a small shop vac for the dust port. Mount it on locking casters and......good to go..
Home Depot run!!!
Unread 01-17-2010, 01:58 PM   #18 (permalink)
bfcg's Avatar
Do you have a table saw with rails that extend out on the right side?
I built mine right onto those rails and it allows me to use the ripfence.
Have a look at this:
Router table for the table saw
Unread 01-17-2010, 02:23 PM   #19 (permalink)
bfcg's Avatar
Frank
Did you get that beast PC 7518 router for it? It is an animal.
Santa has been pretty good to you for the last couple if x-mases.
Didn't he bring you a carvewright last year?
Are you going to place the body on a ramp for the pup cavs?
You would some how have to prevent from rotating the body while routing. x y rails?
Sorry to sidetrack, I promise to get back on track.
Unread 01-17-2010, 03:26 PM   #20 (permalink)
MLP Sponsor
alk-3's Avatar
No need for rails, as long as the table itself doesnt tilt. I made some jigs for those angles, and they lock the whole body in place very well.
Of course tilting the table allows for infinite angles depending on the job, so some sort of rail setup might be worth while anyway.
alk-3 is online now   Reply With Quote
Unread 01-17-2010, 04:03 PM   #21 (permalink)
SG Lou's Avatar
I too was looking at the PC 7518.............As a matter of fact, I know a guy in my wifes Church who's a B & D, PC, etc, etc, tool rep. he told me he can get me what i want at cost so i think I'll take him up on the offer
Home Depot run!!!
Becareful of those inexpensive bathroom vanities The majority of them are constructed of cheap ass partical board
Moritz Guitars
Guitars:
64 SG Special
Epi Iommi SG
Jaydee "Old Boy" SG
63 RI Strat
Amps:
Unread 01-17-2010, 06:11 PM   #22 (permalink)
bfcg's Avatar
As long as you can slide the jig foward and back perfectly straight you won't end up with wigley lines as the stock pins are crap.
That is another thing with that Shopfox is that the pins suck. I turned all new pins for mine with much, much, much tighter tolerances.
The last negative thing I'll say is the foot control does not allow for variable pressure, either it is on or off. you can't adjust the plunge speed with the foot control.
All in all though for the money and a few tweeks, it's a great maching for what it could do.
Unread 01-17-2010, 06:20 PM   #23 (permalink)
SG Lou's Avatar
Thats good to know............Thanks Bill
Moritz Guitars
Guitars:
64 SG Special
Epi Iommi SG
Jaydee "Old Boy" SG
63 RI Strat
Amps:
Unread 01-17-2010, 10:49 PM   #24 (permalink)
pinefd's Avatar
Bill, the router I'm using currently is my old trusty PC 690 that I pulled out of my Marlin. And you're right, last year was the Carvewright, and this year the overarm router...good memory!
And for the pup cavities, I made a jig that I attach the body to that I can angle at whatever # degrees I want, and then attach the template to the base of the jig. It may, in fact, be the ramp you're referring to, but I'm not sure. I'll have to shoot some pics of the jig when I get a chance, so you can see what I'm talking about.
And thanks for the heads up on the pins. I didn't realize they weren't too accurate, but so far I hadn't noticed anyway, so they must not be too bad (or I'm just not that picky). For more precise work, like fingerboard inlay routes, I was planning on making myself my own pins anyway, especially since the smallest pin they have is too large for what I'd want.
Frank
Unread 01-19-2010, 03:07 PM   #25 (permalink)
bfcg's Avatar
I make a hardwood dowel that fits perfectly in the hole where the pin drops in, then I plunge the bit into the dowel and turn a pin on the metal lathe the exact size of the bit.
That pin gets glued into the hardwood dowel. Note: once I drop that wooden dowel into the hole, I snug it up to prevent it from rotating and never remove it or allow it to rotate, I place the pin into it while it is still in the hole.
Unread 01-19-2010, 06:50 PM   #26 (permalink)
pinefd's Avatar
Thanks for the suggestion, Bill! A side benefit of doing it that way, I suppose, is that you're guaranteed that the bit will be in perfect alignment with the pin. The only difficulty I had in setting up the machine was the pin alignment; but your method eliminates that problem.
Frank
Unread 01-19-2010, 08:30 PM   #27 (permalink)
MLP Sponsor
alk-3's Avatar
Wow, great thinking!
The pin in mine seats in ball bearings so it turns as you move the template past it. I was actually very surprised that mine remains so accurate even when adjusting the hight with the hand crank.
Unread 01-20-2010, 05:18 PM   #28 (permalink)
Bartlett Retrospec Member
Ole'Lefty's Avatar
A piece of tubing with close ID tolerance to pin and bit will align nicely. O'L
Years ago I went to the Mississippi Crossroads to make the infamous trade. Lucifer refused to deal-he said that after just a few years as a lawyer I did not have a soul to barter.
Ole'Lefty is online now   Reply With Quote
Unread 01-20-2010, 10:17 PM   #29 (permalink)
pinefd's Avatar
Thanks for the tip, Mike!
Frank
Unread 01-22-2010, 09:41 AM   #30 (permalink)
bfcg's Avatar
There is an Idea! You are using bits that have a much wider cutting diameter than I usually use so you are able to get a bearing to fit on your pin.
Eventually when I use larger bits in my machine I am going to use your ball bearing method.
I have used larger bits but I have not use them with the pin in the table. I used them with the bearing mounted to the tip of the bit.
