#1 (permalink) |
Neck shaving on polly neck
Hi you all. I have an Edwards Les Paul copy that i really,really like but the gummy and sticky poly neck really bothers me while I'm playing.
So I'm interested in shaving most of the polly of my neck.The thing is that i don't want to shave it to a naked wood,but to leave some "cover" because i'm a bit affraid about neck stability,humidity ecc. I also read somewhere that if i don't remove 100% of polly that sticky feel will eventually come back with time.So i would like also like to know your opinion on this matter. I allready read some of past treads, where people were advised to use 400-800 grit sandpaper but everything i found was to shaving it to the bare wood. How to know how deep i can go? So give me every advice you think wolud be usefull (as well telling me not to do it ).
#5 (permalink) | |
Re: Neck shaving on polly neck
My mistake. It looks gummy and it feels sticky .I think it's polly because i tried to sand down just a bit and dust is white and its smells like plastic.But than again maybe i'm wrong,i'm not the expert here .P.s. dennistruckdriver - when you posted the photo i remebered Monty Python sketch - dead parrot
#6 (permalink) | |||
![]() Quote:
#8 (permalink) | ||
before encouraging someone to start sanding. But that's just me.
![]() Quote:
#10 (permalink) | |
I meant photos of the finish you're trying to fix. There are several threads here with photos of folks sanding, "shaving", and refinishing their necks. Also of folks just taking a Scotch-Brite pad (the rough green stuff on the back of some kitchen sponges) to them.
![]() Quote:
#11 (permalink) | |
I know,i know, probably you will tell me - Why did you started withouth asking nothing and then ask as nothing happened? I have to clarify that i don't care about the look and that I knew that i could not compromise stability-integrity of the neck with little sanding.I am determined to do it. I would just like to see some advice how "deep" should i sand before I reach a point of no return (bare neck) but also i'm open to "curse" comments on my idea . So if somebody is sorry for me , don't be. "There is a sucker born every minute".
#12 (permalink) | ||
![]() Quote:
#13 (permalink) |
![]() Join Date: Jan 2008
In Instances such as what you're experiencing I usually just rub down the back of the neck with 000 or 0000 steel wool each time I do a string change. After doing it 3 or 4 times the neck just stays silky, probably due to the lacquer hardening and becoming less sticky. I don't know if Edwards guitars have poly or lacquer, and I have never tried the above method on poly.
#14 (permalink) | |
Motocrossin' truck driver
![]() Join Date: Apr 2008
#15 (permalink) |
EDIT: Was going to make a truss-rod joke, but I see Dennis beat me to it.
Anyway, I did this on my Xaviere the other day, I took parts of it down further (accidentally) than I'd planned, but those parts seam to actually be less sticky than the lesser sanded stuff, which seems to have some sort of uber-thin 'finish' or something still covering them. I think I'll go a bit further sometime and even it out. As for the grit of sandpaper, I have no idea... I think it was blue (is sand paper universally colour-coded?), but having said that, I am colour blind, so it may have been purple. After that I managed to find some finer stuff, and then some really fine stuff to finish it off and It feels really nice. I did a pretty shabby job, it looks like hell and I've got that poly shit wedged up in close a few of my frets (I'd suggest masking it or something ) but I'm sure that isn't going to be too hard to get rid of. But I'm happy with it anyway.
#16 (permalink) | |
#17 (permalink) | |
#19 (permalink) | |
and to clean fingerboard.
#23 (permalink) | ||
![]() Quote:
#25 (permalink) | |
Nice, Alex. A name is starting to come to me, but it hasn't arrived yet.
Neck by Alex: ![]() None finer. Observing your locations, what's the difference between Croatia and Croatia, Italy?
![]() Quote:
#26 (permalink) | ||
#27 (permalink) | |
student in Italy,Venice.Hey Truth thanks, but for now i would like to do "this little thing" myseft,and afterall it is not very exepensive guitar.If i want to do a pro job with "real" finish i would most likely contact you knowing that you dig the vintage "groove". |
#28 (permalink) | |
i would do that same thing guys suggested you, fine sand paper, maybe 800 or 0000 wool, and of course be careful to do it lightly not to sand through to the wood
#29 (permalink) | |
The guitars are full poly with a thin nitro on top, only for the look. Could this cause chemical problems? |
#30 (permalink) |
I don't think so.If you wipe nitro off,poly will remain and if i'm not wrong poly is more "hard" and "seels" wood more than nitro. This is also the reason nitro is more wanted- because wood breath better and suond is more clearer. Naturally the biggest issue is the thicknest.
| Bent neck/Sloped neck issue..? Les Paul Standard faded ´50 | jochelito | Gibson Les Pauls | 20 | 09-14-2009 08:32 AM |
| Shaving 50's Neck to 60's? | djd100 | Luthier's Corner | 3 | 05-12-2009 07:52 PM |
| Squire Strat Neck vs Les Paul Standard 50's or 60's neck | sebah | Gibson Les Pauls | 5 | 12-22-2008 04:33 PM |
| Neck Shaving | stonevibe | The Custom Shop | 33 | 06-12-2008 05:27 PM |
| I got a question - Neck shaving | GuitarGod319 | Luthier's Corner | 29 | 06-11-2008 11:03 PM |
