#1 (permalink) |
Les Paul Jr. wiring quesiton
Hey all I'm pretty new to the world of guitar tech but I was wondering about the grounding requirement for a P-90 Les Paul Jr. type wiring. The guitar has a wraparound bridge- how would I go about wiring a ground to it and from which pot (volume or tone?)
Thanks for all your help- this forum is a very valuable resource to say the least. |
#2 (permalink) |
Re: Les Paul Jr. wiring quesiton
It has to be grounded from the treble side wrapover stud bushing. It comes inot the control cavity through the same hole as the silver braided wire from the P90 and the ground gets soldered to the back of the volume pot (see first pic).
The trick is that the hole from the ground wire is drilled from the p\up cavity through into the stud bushing hole. The wire is the then looped back into the p/up cavity and then pushed through the hole for the p/up wire like in the other picture. You can just see it (the ground wire) by the two holes in the corner of the p/up cavity. Hope that helps! |
#4 (permalink) |
Yes
"It's all Iommi's fault. I blame him entirely" A.L.S. aka Lou Gehrig's disease Sux. Lets rid the world of this dreaded disease ![]() St. Moritz Guitars http://www.freewebs.com/stmoritzguitars/ stmoritzguitars@hotmail.com Guitars: 63 SG Jr. 64 SG Special Custom Shop Iommi Sig. SG 61 RI SG, Epi Iommi SG Jaydee "Old Boy" SG Custom Built "Old Boy" SG replica 63 RI Strat Amps: Laney GL50 head w/4x12 Laney Cab. Laney LC15R, Line6 Spyder Vox Brian May Special |
| Help with les paul wiring | Gibby1960 | The Custom Shop | 4 | 09-07-2009 07:11 AM |
| Les Paul Wiring harnesses | lp_junkie | Business Classifieds | 2 | 09-02-2009 11:33 PM |
| Epi Les Paul Wiring Help :C | Hipatch3 | Epiphone Les Pauls | 2 | 08-08-2009 02:37 PM |
| Feeler: Complete Gibson Les Paul BFG wiring kit, killswitch, pots, caps, wiring. etc. | djwilbanks | Member Classifieds | 25 | 03-18-2009 07:34 AM |
| 01 Classic tone quesiton about RS Works Kits? | dfris | Tonefreaks | 4 | 09-12-2008 07:59 PM |
