#61 (permalink) | |
![]() Join Date: Apr 2007
Re: 50s LP control cavity angle
What we really need is Singlecut54 to offer some help. He not only knows all about these guitars through repairing many of them, but he has a fantastic collection. Haven't seen him here for a while, so he must either be really busy or just annoyed that nobody ever takes notice of what he offers - pearls before swine? |
#63 (permalink) | |
#64 (permalink) | |
Oh, and I love a Bacon Sandwich Inlaid with sauce.
#65 (permalink) | |
#66 (permalink) | |
#67 (permalink) |
Abeunt studia in mores
![]() Join Date: Jun 2008
Here are a couple of pictures taken at the Custom shop. Although it is from modern times, I believe it may give some insight to the discussion. You can clearly see the hole in which the reference peg is sitting, is 90 degress to the back.
In the CNC the body (on the left) is being held at an angle. It very well could be referenced to the hole(s), seen in the other picture, creating at least one of the angles of the cavity. This may be evidence as well, the holes for the pots are drilled before the control cavity is routed. ![]()
#68 (permalink) | |
#69 (permalink) |
in my opinion it's not the angle of the pot the big problem.It can be possibly be drilled vertical to the bottom of the guitar with smaller hole and then reamed.The problem is the area around the hole in which the pot is screwed (inside the cavity).It must be routed at the same angle with the top surface at this point of drilling.
my question is this.Do all the 4 pots have the same angle?I dont own a LP so i cannot distinguish it from the photos.. |
#73 (permalink) |
There is nothing to wonder about.
![]() The neck pocket is routed parallel to the neck plane, the neck tenon is straight. That shows the 4,5 degrees needed for the neckangle. The angle you see under the jig on the right side puts the bottom of the mortise / the neck plane parallel to the table. Maybe it is needed for the CNC with such a long router bit, even if the head can move. Same direction as a router on a template laying on the neckplane. Where do you see the opposite? |
#74 (permalink) |
some skilled luthiers as EX-Nihilo do not refer the issue of angled cavity(if i am correct) and that's what i ask...How do they angle it?a photo would be very appreciated...
#75 (permalink) | |
Got it. Strange, the first view was obviously an illusion. I took for granted that the table was plane and the jig was lifted. Now I see that it's the opposite of what I was thinking. I am not good explaining it in words so here's a picture instead. Look at the skull.... what skull?
#77 (permalink) |
![]() Join Date: Jan 2008
Okay, so I got some time this morning to get some photos in the shop. This first one shows the fixture for routing the flat bottomed cavity. The little wedges are to keep the body from moving around in the jig because the top is attached at this point.
![]() This one shows the body in the jig. This is straight forward, and by no means is a pin router required to do this job. ![]() These next photos show the jig for routing the angled rout. ![]() ![]() And here, with the body in the jig. ![]() ![]() ![]() and here we have the resulting "v" caused by the first and second routs intersecting. This allows the pots to stick out the top at their appropriate angles. It's a bit hard to see, and does very in it's placement depending on the height the router bit is set at. Just a mm or two of router height adjustment will move the "v" around in the cavity a fair bit, thus accounting for the seeming randomness of this feature's location on original bursts. ![]() I dont have a good way to measure this angle , but Magnus and I are working on a 'mathematically correct' angle based on the resulting measurements. I did look for the original Jig we used for Scotts guitar, but I couldn't find it. I think if one were to try to make one of them, it's best to do it with trial and error based on your top carve. It's important that the angle match the top carve to give the proper results. It's not hard to do, but just takes some time, and very careful planning so you don't make an irreparable error. ![]() Hope this answers some questions. |
#78 (permalink) |
Tom,
Do the bottoms of these jigs have the patterns cut in them for the pin router to follow, or do you use another pattern along with the jig? -tulsah |
#80 (permalink) | |
#81 (permalink) |
Here's the setup I used on my first replica. This one looks great from the top and very authentic, however it wasn't deep enough in the innermost pot and had to be relieved slightly with a forstner bit to get the nut on the pot.
This template was destroyed pretty much when I tried to modify it to get more angle, and then a second template was made that didn't work out so well either. The third one will be the one that will work if I ever get to it, I am going to make it hinge on the crown of the "V" that everyone is talking about and make the depth adjustable. |
#85 (permalink) |
This one took less time to build actually. This one also does a much better job. You just pop the body in and the machine does the rest. With the one we used on Scotts, you have to get it lined up perfectly, which takes ages. If it's not perfect it cuts into the body outside of the cavity cover.
This jig is also used on a different machine. They're both routers, but one is hand held, and the other is a monster overarm pin router.
#86 (permalink) | |
-tulsah |
#87 (permalink) | |
#88 (permalink) |
wow, what a head full of info on this thread. I've wondered about this but never pressed the questions as I'm not yet reaching critical mass here... I'm still fiddling with building a few Juniors before stepping up to a carved top Std.
Kudos to all who have shared there methods to the madness, we do appreciate your sharing your tricks, tips and ideas. So, let me step off the dock here and ask perhaps an obvious question that seems to be either ignored as it's irrelevant to the topic or perhaps it's been overlooked or simply a non issue. To me, the whole purpose of angling the control cavity bores are to make the control knobs on top be at right angles to the top carve where that particular pot shaft comes out through the top. If that's the case, then wouldn't one want to make sure that the thickness of the maple cap or roof on the control cavity has a common thickness across all four pot holes? If that is the case, say all the cavities are supposed to be 5/32" thick at the maple, then it really depends on how that particular top was carved to get it right? If the guy running the slack belt back in the day was a little heavy handed he could waste away a good bit of maple around the control knob area of the top. Isn't it possible that a fixed common jig could cut too deep into a top that's been carved a little deep which may result in a dangerously thin cap over one or more control knob holes? Now take that scenario and apply it to any home builder/luthier and you know the top carve isn't going to be the same from builder to builder and probably not the cavity either? Would it not be better to simply define what thickness the finished maple cap is where the 3/8" holes come through the top and just bore each individual cavity (the small round part where the pot sits) to be a consistent thickness relative to the top being made? Granted, that may not be the way the vintage ones are made but I think I'm just searching for simplicity here. |
#90 (permalink) | |
For the average home or garage guitar building just building one for themselves to play with, doing each pot with a forstner bit is probably the easiest way to make it all work for them, but in a production setting where the people doing the work are not necessarily skilled luthiers the pattern makers are charged with the task of making jigs that allow said unskilled worker to pop the body into the jig and rout it with no real concern of what they're doing. Also, as a side note, when jigs like the one I made for the pin router are used there is no chance of going through the maple because the body rests maple side down on the jig, after the carve is complete. So the router indexes off the carved top. If the carved top is thinner, then the body sits lower in the jig, thus not allowing the router to cut through the top, and always guaranteeing the same top thickness under the pots. I hope all this makes sense! |
| Tele Control Cavity Help | Tonal Fretter | Luthier's Corner | 5 | 09-14-2009 04:11 AM |
| In the Control Cavity-just for looks | Ole'Lefty | Luthier's Corner | 4 | 05-12-2009 11:52 AM |
| inside the control cavity...... | opalburn | Tonefreaks | 4 | 02-01-2009 07:37 PM |
| what to use to fill control cavity | chrislouden | The Custom Shop | 12 | 10-03-2008 12:42 PM |
| Can some one post a pic of the control cavity? | Sinmastah | Tonefreaks | 27 | 09-13-2008 01:07 AM |
