#32 (permalink) |
![]() Join Date: Jan 2008
Re: 50s LP control cavity angle
Okay, it just now dawned on me what the v is all about. I feel like an idiot for not realizng until now.
When the guitar is routed, it is first done exactly paralell to the back, then the guitar is put into a jig that angles it, which also produces the nibble marks. When the first rout and the second rout converge there is an angle change. I am away from the shop until Sunday, but I will take some photos of this being done, and the resulting v for you guys. The v is infact there, as a byproduct of the two routs. This is how I have always done it, and I use a pin router with fixtures. I'm sorry it took me this long to realize what you were talking about, but his v is in fact there. |
#33 (permalink) | |
#34 (permalink) |
No, I think it is exactly what they're talking about. The drawing that magnus made that I posted earlier shows the point of the v right on one of the pots, in actual practice this point of the v would be bisecting the cavity almost perfectly. I will post photos of this as soon as I gt home.
If you go to the burst registry you can see they did very somewhat depending on the depth the pin router was set to, but the usually land right about th middle of the cavity. |
#35 (permalink) | |
#36 (permalink) | |
But, as mentioned I will take some other shots to demonstrate it better |
#37 (permalink) | |
When I read this, I take it as the two surfaces that make up the inverted "V" are the flat surface that is parallel to the flat bottom of the guitar, and the angled surface that is cut into the flat surface for the innermost pots to sit on. The line between the volume and tone pots sentence is being taken too literally in this statement as well I believe. Where the line REALLY is is between the neck pickup volume/tone pots and the bridge pickup volume/tone pots, I think that is what he meant... it's just the way it reads that makes it seem like that. I think he meant volume and tone pots collectively, not specifically. Sometimes writers and editors in newspapers and magazines take liberty with text to make it more fluent to the reader, and sometimes things get lost in translation... This will make the pots sit at a 90° angle from the top, and make them angled away from each other- when viewed from the bottom. Basically there are only two cuts/surfaces/planes/whatever you want to call them in the cavity floor, not three. fletch |
#38 (permalink) |
alk-3 and Fletch, I agree with what you are saying. I went back and took at look at the many cavity photos I have saved and agree with the transition point being not literally between the volume and tone pots. That's why it's great to talk these things through. Alk-3, I look forward to your photos.
#39 (permalink) | |
The trouble I had earlier trying to Invision this was the v not being inverted. Doh. |
#40 (permalink) |
hallo!
my question is this:the axis of the pots are vertical to the chambered surface.so if we drill a hole for the pot how can we manage the hole to be vertical to the surface?if we use a vertical to the table drill ,the axis of the pot and the axis of the drill are not parrallel.Simply,how do you drill the pots?with angle? |
#43 (permalink) | |
#45 (permalink) |
in my opinion it's very difficult to achieve the same angle of the pot and the top surface with a reamer.
i would gauge the anlgle of the surface where the pot will be put and with a jig drill/route a hole with the same angle.i would also route the area around the hole just to put the whole pot vertical to the surface .Am i correct? |
#46 (permalink) |
You could do it that way and it would be fine, but it is not how the vintage guitars were done or how most clone builders do it. It's all about trying to make the best clone out there since most of us can't afford the real thing.
#47 (permalink) |
You guys really lost me with all of this inverted v business.
I really liked the way the control cavity came out on Ex-nihilo's 2nd build, and when I get around to building a Lester I intend on replicating that method. Is it dead on exactly identical to a '59? I don't know. Nor do I care. I know it was functional, and the jig looks simple to make and use so that is why I would like to know a little more about it. alk-3, I don't know if you even have the thing any more, but if you do please take a look at my crude illistration below of the jig that you and ex used (I don't have all of this fancy cad stuff so a pencil and paper had to do), and if you would be so kind, answer a simple question. ![]() If you took the jig, and mark a line (dotted line in the drawing) square to the straight edge of the jig then measure the angle that is created between the jig along that line and the flat surface of the guitar back what would that angle be? Would that be 8 degrees?
#48 (permalink) |
The angles are interesting on Magnus's 53GT which he says has a low top arch height. Using a CAD program I get angles approximating 3 and 5.25 degrees :
![]() and: ![]() If you want to try this at home make sure you use the extra precision King Size Sharpie! ![]() It would be great to see similar phots of a late 50's LP for comparison. |
#49 (permalink) | |
![]() Also if you look at the bottom photo I posted above, what shows as a 5.21 degree angle would be 8 degrees. This is the angle routed into the bottom of the control cavity relative to the flat back of the guitar. |
#50 (permalink) | |
By the way, all of this will be on the plans magnus and I are making. |
#51 (permalink) | |
#52 (permalink) |
Under shop arrest
![]() Join Date: Dec 2008
I use an adjustable angle jig and I adjust it until I match the angle of the top carve and go deep enough to leave the most wood possible while still allowing for short shaft pots.
#53 (permalink) | |
#54 (permalink) | |
I just think that particular jig is an elegant solution to a pretty complex operation, and you can use a handheld router which is a must for me since I don't have a pin router. |
#56 (permalink) |
Not at all. I just figured since you would have to build one like it and he's not using it that this could work out good for both of you. Since he may not want to sell it he may be willing to rent it when you eventually need it. There's nothing wrong with this jig in my opinion.
#58 (permalink) | |
#59 (permalink) |
I have nothing to add or share on this subject. But I must say that I love this constructive discussion. Very interesting, indeed.
Last week I drilled the pot holes on my upcoming GT and I searched the forums how the LP was drilled. Found nothing so I just drilled some holes a bit smaller than the plans in a 90 degree angle. Now I know how it should be and I thank this thread for that. |
| Tele Control Cavity Help | Tonal Fretter | Luthier's Corner | 5 | 09-14-2009 04:11 AM |
| In the Control Cavity-just for looks | Ole'Lefty | Luthier's Corner | 4 | 05-12-2009 11:52 AM |
| inside the control cavity...... | opalburn | Tonefreaks | 4 | 02-01-2009 07:37 PM |
| what to use to fill control cavity | chrislouden | The Custom Shop | 12 | 10-03-2008 12:42 PM |
| Can some one post a pic of the control cavity? | Sinmastah | Tonefreaks | 27 | 09-13-2008 01:07 AM |
