Old 10-19-2009, 09:45 AM   #31 (permalink)
Ole'Lefty's Avatar
Re: MOP Traps Feeler
You are a Master. Seeing that sample layout-I got to thinking. Notice the 3D effect when the numbers are on, instead of in the shield. How about this--the white shield, black pearl numbers, depth of cut for numbers about 3/4 or 7/8 the thickness of the numbers-leaving the numbers just proud. I think that the location on the headplate is guarded enough by tuners and design that the risk of chipping or breakage would be minimal. I'm no creative genius here, but the idea of two- three dimensional logos could really enhance many designs(I'm claiming trademark and common law patent for US(we). If I received them in pieces, I would very gently polish and ease the numeral edges. Imagine just how cool that would look!!!!Yes, patent, copyright, trademark and every other kind of protection for Tulsah and Tobey,3D Logo Wizards Int'l., LLC(tm) aka T & T 3D Logo Wizards Int'l., LLC(tm)
Going back to the original plan--the changes to make production easier are fine with me. The sign does not have to be a true replica-just representative of the real sign. So, do what is most practical for you. I'll have black pearl to send you in a few days. Thanks, Mike
"I'm not colorful-I'm crazy."
Ole'Lefty is online now   Reply With Quote
Old 10-19-2009, 10:57 AM   #32 (permalink)
tulsah's Avatar
You know ... there's some real possibility here. Instead of cutting the numerals through the shield, I would simply pocket them to whatever depth it takes to keep the inset numerals proud. The other advantage of this would be that the oval in the body of the '"6" would not be separate from the rest of the shield.
The first trick though is to get the numerals to fit properly. Once that is done, then everything else should be simple. I'll let you know as this progresses.
-tulsah
tulsah is offline   Reply With Quote
Old 10-19-2009, 11:01 AM   #33 (permalink)
Ole'Lefty's Avatar
Tulsah-we could be millionaires here. BWAAAHHAHAHA(Dr. Evil) Thanks, O'L
Old 10-22-2009, 10:12 PM   #34 (permalink)
tulsah's Avatar
Hey O'L, I haven't forgotten about you, but I have had some other irons in the fire that needed to get finished up. I will be getting back to the fit of the numbers over the next couple of days. I will also be ordering some premium black pearl blanks tomorrow for this and other such work.
As for the work on the traps, I am also looking into a number of options on that front. The original set that I made last week were cut from material that is 0.054" thick. From what I have found, this is as thick as most other sets in MOP, and others have indicated that it should be sufficient. However, I am also considering cutting sets from premium 0.080" thick MOP. This would definitely insure that the inlay would remain sufficiently thick after sanding to the fretboard radius. It will likely be another week before I have a set of these for show.
As always, comments are appreciated. Thanks.
-tulsah
Old 10-23-2009, 10:43 AM   #35 (permalink)
Ole'Lefty's Avatar
No hurry on my end. On the last two trap boards I have done, I pre-radiused the pearl(.050-PSA on an old test fretboard) and then put binding tape(couple layers) on the bottom mounted template at the edges-I could somewhat "fake" a radiused cavity-it worked out well. I did a shallow cut to the full margins of the pearl-then added the tape which deepened the sides of the cavity-in each tape-on pass, I barely overlapped the centerline on each cut from the opposite side-ended up "radiused." This is on the pin router-cutter coming in from above the wood. One of the rare occasions lately where I actually felt a bit clever. O'L
Old 11-01-2009, 08:49 PM   #36 (permalink)
tulsah's Avatar
I made some great progress on the "Route 61" prototype today. The real trick here was to get the numbers '6' and '1' cut from mother of pearl and then fit into the shield logo without any gaps. Per Ole'Lefty's request, the goal was to have the shield in white MOP and the numbers in black MOP - to look as close as possible to the sign. I am still waiting on black MOP from my supplier, so all of the testing has been done strictly in white.
The process for this will involve cutting the shield in white - the numbers are discarded, but the oval center of the '6' is retained. The numbers are then cut from another piece of pearl and take only the slightest tap to fit into the shield. The same goes for fitting the oval center back into the '6'. As you can see from the photos, the fit is fantastic - better than the camera reveals. The two different pieces of white pearl do contrast well as they had different grains to them.
This is going to look awesome when it is done in two colors! Any comments? Thanks.
-tulsah
Old 11-01-2009, 09:17 PM   #37 (permalink)
SiriusAbbott's Avatar
Any comments?
holy crap!
that looks phenomenal
holy crap...things are truly suck right now
SiriusAbbott is online now   Reply With Quote
Old 11-01-2009, 09:40 PM   #38 (permalink)
MRJ
MRJ's Avatar
Great work as always T.J.!
MRJ is offline   Reply With Quote
Old 11-01-2009, 09:41 PM   #39 (permalink)
pinefd's Avatar
Wow, that looks amazing, Tulsah!
Just curious...are you able to cut partial depth into the MOP instead of all the way through? So, in the case of the Rte. 61 sign, if you could cut the numbers half the depth (for example) and then fill it in with black epoxy and sand flush, it would look great. I'm just thinking that it could be potentially a lot easier than going the black MOP route (but definitely not as cool).
Frank
Check out my website at: www.lesstallguitars.com
And check out some of my personal gear at: Historic Les Paul Database
pinefd is online now   Reply With Quote
Old 11-01-2009, 09:59 PM   #40 (permalink)
tulsah's Avatar
Frank
Frank,
You are correct - I can cut the numbers as a partial depth pocket and the cavity could be filled with epoxy. Without any doubt, this would be an easier method. Now that I have all of the clearances and compensations worked out, it really isn't too difficult anymore. What we see here is the result of the request from Ole'Lefty for a white shield with pearl numbers set in. If it does go forward to anything more, then I guess all options would be considered. In a sense, this was also a bit of a test from my end to see if I could get the numbers to fit properly. Thanks for the comment and observations.
-tulsah
Old 11-01-2009, 10:02 PM   #41 (permalink)
Ole'Lefty's Avatar
Frank-I think Tulsah can do anything. I am sure impressed. I have black pearl stock on the way to me as well. I think your idea would look good too-but if we can do the black and partially buried in the white shield-well, spectacular hardly covers it and Tulsah and I are claiming the 2D as trade dress for guitar logos-besides my trademark app. sent in for approval on the "HighWay 61" Guitars[tm].Like I said, we will be, oh well, thousandaires<G>. What a bright spot for me-ain't coughing blood no more(there is a blues song there) and a glorious logo-and, just in time, a trial starting tomorrow-nasty, but a challenge-I was hired as a specialist/consultant-details are terrible, but I have spent my life dealing with the worst man does to his fellow man. One must be detached-just like a surgeon. O'L
Old 11-01-2009, 10:19 PM   #42 (permalink)
tulsah's Avatar
Not quite ... but thanks for the confidence and compliments! I should have a refreshed supply of material either tomorrow or Tuesday. Once it arrives, I was planning on cutting one more set of numbers from true black pearl. If your discerning eye accepts the result, then we can talk further as to how or if we move forward. It sounds like you'll have plenty to keep you occupied.
Also, as I had mentioned before, I am getting the thicker pearl stock in the new shipment. I was planning to cut a set of traps for general interest. Thanks again to all.
-tulsah
Old 11-02-2009, 08:25 PM   #43 (permalink)
tulsah's Avatar
Well, I did get my pearl stock today, and it looks great. My next step is to cut another complete Route 61 logo - white shield, black numbers.
I also received a supply of the heavy blanks (0.080") thick that I think will make for some incredible trapezoid inlays. The figure of this pearl is really great.
Anyway, first comes Route 61, and then I'll try a set of traps from the heavy stock.
-tulsah
Old 11-02-2009, 09:05 PM   #44 (permalink)
Ole'Lefty's Avatar
Sounds great. My black pearl came in today-if you need it, just email me address. And thank you for taking on this project. Ole'Lefty
PS-I am exhausted-full day of trial and immediately to the universtiy to teach a Criminal Justice class-another class first thing in the morning then back to courthouse. I love it, but I'm still tuckered out. O'L
Old 11-03-2009, 09:40 PM   #45 (permalink)
tulsah's Avatar
OK, so here is the final result of all of the test cuts and fits of the 'Route 61' logo. The first shot shows a fresh cut shield in 0.063" white MOP. The second shot is of the individual numbers in 0.063" black MOP. The other shots show the marriage of all four pieces - shield, numbers and center oval in the '6'. I can tell you that the camera picks up a lot more than the eye does, and does not always tell the truth. For example, where it may appear ragged around the edges of the numbers, it is not. The shots may also give the impression that there are gaps in the fit of the numbers and the shield. Again, there are not.
... project complete?
-tulsah
Old 11-03-2009, 09:48 PM   #46 (permalink)
tulsah's Avatar
I should also post as to progress on the original topic of this thread. I just finished cutting a set of traps in the highly figured 0.084" MOP. The photos just don't do justice to how nice they look. The extra thickness of this material ensures that they would not get too thin or sanded through. As before, they are cut to be exact fits to those on the Catto V10 drawing. As always, any comments are appreciated. Thanks.
-tulsah
Old 11-03-2009, 09:55 PM   #47 (permalink)
MRJ
MRJ's Avatar
That looks great T.J.! People have to take into consideration that they are looking at an enlarged picture. Like you said the camera will show things that our eyes would never see. I can say, having the benefit of seeing your work in person that it is of the up most quality.
Old 11-03-2009, 10:40 PM   #48 (permalink)
inspectorted's Avatar
Those look nice! can't wait to get my set. These are going to look great with my rosewood.
inspectorted is offline   Reply With Quote
Old 11-04-2009, 07:13 AM   #49 (permalink)
Ole'Lefty's Avatar
Tulsah-I am not surprised. I am however, stunned at the unique and elegant final result. I could not have asked for more. I am humbled by your committment to a challenge and your relentless pursuit. Thanks does not seem like enough. Please direct email me so we can work out my obligation to you and getting a few of these masterpieces to Iowa. Highest regards, Mike Tobey
Old 11-06-2009, 10:57 AM   #50 (permalink)
tulsah's Avatar
Hi Mike ... email sent. Thanks.
-tulsah
Old 11-12-2009, 09:13 AM   #51 (permalink)
Ole'Lefty's Avatar
As all of you must assume, I am excitedly awaiting the arrival of my logos. I still wonder at the beauty of them. O'L
Old 11-12-2009, 09:22 AM   #52 (permalink)
decoy205's Avatar
This is really cool! Great work Tulsah!
decoy205 is offline   Reply With Quote
Old 11-12-2009, 11:13 PM   #53 (permalink)
tulsah's Avatar
Thanks for the compliments. This one has been really fun to develop and produce. I only hope Ole'Lefty is as impressed when he receives the real deal!
-tulsah
Old 11-12-2009, 11:43 PM   #54 (permalink)
PoorMan's Avatar
TJ, those traps look really nice. Maybe I missed it, but have you set pricing?
PoorMan is offline   Reply With Quote
Old 11-13-2009, 10:48 AM   #55 (permalink)
tulsah's Avatar
Thanks Dave. PM Sent.
-tulsah
Old 11-13-2009, 06:29 PM   #56 (permalink)
-tulsah
T.J. No problem with the .054" traps. I guess if they are thicker like .080" you would have more manual clean out to do. Your traps worked out well for me. Thanks
Old 11-13-2009, 09:51 PM   #57 (permalink)
tulsah's Avatar
Thanks for the update Ted. I am really looking forward to seeing that fretboard in its final form.
-tulsah
Old 11-19-2009, 10:19 PM   #58 (permalink)
PoorMan's Avatar
Payday tomorrow...Me wanty.
PM sent.
Old 11-19-2009, 10:40 PM   #59 (permalink)
tulsah's Avatar
Reply sent. I'll be making several sets of these over the weekend so that I have them on hand, as required. Thanks again.
-tulsah
PM sent.
Old 11-20-2009, 06:58 AM   #60 (permalink)
Ole'Lefty's Avatar
I posted my wondrous pleasure with my logos in Raven's thread. The result is nothing short of spectacular. Thanks, T. Ole'Lefty
Gas mask bra traps Ig Nobel prize KSG_Standard The Backstage 4 10-05-2009 12:15 AM
Mini Traps skipdog Luthier's Corner 4 09-07-2009 06:43 PM
Speed Traps AmazingJourney The Backstage 1 06-26-2009 11:04 AM
Build Feeler JackofAllTrades53 The Custom Shop 6 05-17-2009 08:08 PM
FS or FT just a feeler Peaceman Member Classifieds 11 01-29-2009 11:59 AM
