MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Luthier's Corner
Unread 09-24-2009, 01:24 AM   #1 (permalink)
will c's Avatar
Stripped Strap Button Screw Holes
Hi guys,
What do you suggest I do to fix my stripped strap button screw holes. I just got this guitar off of eBay so I expected some minor crap like this.
I was thinking the toothpick-wedgie-with-wood-glue technique, but I thought I would ask you pros before I did anything with it.
Thanks,
Will
will c is offline   Reply With Quote
Advertisement
Unread 09-24-2009, 01:57 AM   #2 (permalink)
djwilbanks's Avatar
Re: Stripped Strap Button Screw Holes
Wedging in the toothpicks seems to be the go-to trick around here.
Some people plug and re-drill though.... but a few of our guys say they have 20 year old toothpicks still holding strong.
I live my life one gif at a time. Nothing else matters: not the mortgage, not the store, not the forum and all its bull****. For those ten seconds or less, I'm free.
djwilbanks is offline   Reply With Quote
Unread 09-24-2009, 03:09 AM   #3 (permalink)
Jody's Avatar
I use a wooden match ,,Stick it in,Break it off flush and rescrew the thing on again...
Jody is offline   Reply With Quote
Unread 09-24-2009, 03:12 AM   #4 (permalink)
will c's Avatar
Do you use glue or just leave it in there dry?....
Unread 09-24-2009, 03:18 AM   #5 (permalink)
Jody's Avatar
With the match I leave it dry,But you could use some wood glue If you wanted....
Unread 09-24-2009, 12:24 PM   #6 (permalink)
H.E.L.Shane's Avatar
toothpicks work great.. however, cut them in half and then split them in half, then put the four pieces in at 12, 3, 6 and 9, oclock with some glue, start the screw, cut them off flush and then finish drivin in the screw..
more complicated but you end up sith even pressure around the whole screw. using the whole toothpick on once side leaves gaps on either side of the toothpick and uneven pressure...
I'm anal... i know
H.E.L.Shane is offline   Reply With Quote
Unread 09-24-2009, 12:46 PM   #7 (permalink)
will c's Avatar
I'm anal... i know
Sounds good. So just for clarification, you drive the screw with the glue still wet?
Thanks,
Will
Unread 09-24-2009, 02:05 PM   #8 (permalink)
iplaythisgame's Avatar
Send a message via MSN to iplaythisgame
I've never used glue. I've got one going on 7ish years. And I just put it in on the side. Seems like you would want the tines(?) of the screw actually in some guitar wood. If you split it and put it all around the screw, wouldnt it be preasure holding it in and not the tines(?)
iplaythisgame is offline   Reply With Quote
Unread 09-25-2009, 08:36 AM   #9 (permalink)
Thanks,
Will
yep... that way the screw acts as a clamp.
and to the question of pressure above... yes and no.... the toothpick is going to be destroyed more or less as you tighten the screw, the pressure holds everything together at first, but the scew will also be biting into the wood in areas where its broken through the toothpick... when the glue sets, you have a very strong fix.
Unread 10-14-2009, 03:08 AM   #10 (permalink)
will c's Avatar
So I finally got some Schaller strap locks and did the repair (with glue). Seems good so far. Thanks for your help guys.
Will
