Old 08-23-2009, 11:30 AM   #1 (permalink)
SG Lou's Avatar
LP DC JR Project Started.
I had some left over White Limba aka Korina so I decided to build a LP DC Jr.
I was able to get a nice 1/4 sawn piece from one end of the board for the neck but the board wasn't thick enough so i had to add a piece . The "Scarf" joint runs between the first and second set of tuner holes so it should be ok.
You can faintly see the joint on the neck blank pic.
Body blank glued up.
After the blank was rough cut I used my old tried and true method of milling the tenon end of the neck to the 3 degree angle.
I have to admit, I was blown away by Icegator8's TR slot cutting jig so I contacted him and after a few email exchanges I got the info I needed and built my own Slot Cutting Jig.
Slot cut , perfectly in the center.
Nut pocket cut using chisels and a small drum sander on a Dremel
"It's all Iommi's fault. I blame him entirely"
A.L.S. Sux, Lets rid the world of this dreaded disease
St. Moritz Guitars
http://www.freewebs.com/stmoritzguitars/
stmoritzguitars@hotmail.com
SG Lou is offline   Reply With Quote
The Following 13 Users Say Thank You to SG Lou For This Useful Post:
Old 08-23-2009, 11:33 AM   #2 (permalink)
MRJ
MRJ's Avatar
Re: LP DC JR Project Started.
Nice! Real nice! I can't wait to see more!
MRJ is offline   Reply With Quote
Old 08-23-2009, 11:40 AM   #3 (permalink)
SG Lou's Avatar
TR ready to installed and glued up.
Filler strip planed flush and partial shape of headstock bandsawed out.
Body shape being rough cut.
Body edge rounded over and sanded.
Thats what I got done so far in 2 days. I'm out of 1/4" dot inlays so i'll order some on Monday. Once thay get here I'll be able to continue on the fingerboard and once the FB is finished being inlayed I can continue on with the rest of thee assembly.
St. Moritz Guitars
Old 08-23-2009, 11:48 AM   #4 (permalink)
Nice looking wood and an interesting build you have going.
BeBop is offline   Reply With Quote
Old 08-23-2009, 11:55 AM   #5 (permalink)
GreaseBox's Avatar
Looks great!
I love DC's!!!
"...I've eaten the sun so my tongue has burned of the taste..."
GreaseBox is offline   Reply With Quote
Old 08-23-2009, 12:07 PM   #6 (permalink)
PoorMan's Avatar
Looks great, Lou!
PoorMan is offline   Reply With Quote
Old 08-23-2009, 01:44 PM   #7 (permalink)
Looking good!!!
Where did you get the body template?
tubeman426 is online now   Reply With Quote
Old 08-23-2009, 01:48 PM   #8 (permalink)
SG Lou's Avatar
Originally Posted by tubeman426 View Post
Looking good!!!
Got it from Ron over at GBT
Gibson Les Paul Set Neck Template
St. Moritz Guitars
Old 08-23-2009, 09:22 PM   #9 (permalink)
Texas07R8's Avatar
Amazing! Damn that's got me pumped to do a DC.. Looking forward to the rest of the story.
Texas07R8 is offline   Reply With Quote
Old 08-23-2009, 11:19 PM   #10 (permalink)
Loserface300's Avatar
how many PUs? and whats the harware and finsh going to be cuase dis is EPIC!!
Loserface300 is offline   Reply With Quote
Old 08-24-2009, 01:11 AM   #11 (permalink)
j.six's Avatar
That body looks excellent, and I love the truss rod slot jig!
Sully
j.six is offline   Reply With Quote
Old 08-24-2009, 04:20 PM   #12 (permalink)
SG Lou's Avatar
I think i'm going old school, 1 Dogear ,etc,etc.
Not sure about color as of yet. That Korina is GORGEOUS so I don't want to cover it up if I don't have too.
ANY SUGGESTIONS ON THE COLOR
St. Moritz Guitars
Old 08-24-2009, 04:47 PM   #13 (permalink)
That's it
thanx for this threat
can't wait to see more of it!!!!!
joebonsai is offline   Reply With Quote
Old 08-24-2009, 05:44 PM   #14 (permalink)
I was having a look on jacksonsrareguitars.com.au
and under Hamer there was a korina DC JR in natural korina.
I thought it looked a little pasty.Maybe with a tinted clear.
wizzbang is offline   Reply With Quote
Old 08-24-2009, 06:29 PM   #15 (permalink)
make it natural with a little yellow mixed with clear, like PRS does on their korina models, then paint a black stinger on the back to cover the joint.
shtdaprdtr is offline   Reply With Quote
Old 08-26-2009, 07:22 PM   #16 (permalink)
SG Lou's Avatar
Re: LP DC JR Project Updated !
During my days off from work ( Being I work 12 hr shifts every month I get 7 day off in a row ) I managed to get some more work done on the Jr.
Headstock shaped and Veener glued up and shaped:
I used my Laser to make sure the neck was aligned perfectly with the body and set up the guides to route the neck mortise:
Added vinyl tape to the sides of the guides to make the pocket a hair smaller and than I can fine tune the joint so I get a snug fit of the neck tennon
A perfect fit after a little tweeking :
St. Moritz Guitars
Old 08-26-2009, 07:30 PM   #17 (permalink)
SG Lou's Avatar
Time for some routing and drilling of the pickup cavity, control cavity and jack hole:
Holes drilled out in the headstock:
Some other shots:
So thats it for now. Tomorrow will be a busy day as I gotta prep my copy of Old Boy and later pay a visit to see Tony Iommi and Geezer Butler.
I'l l be driving up to Wallingford CT to see Heaven & Hell from Back Stage !
I got a call from Iommi's guitar tech and he told me to come up and that I'm already on the Guest List !
I CAN'T WAIT !
St. Moritz Guitars
Old 08-26-2009, 08:36 PM   #18 (permalink)
69GTLP's Avatar
That is a great build, pure simple elegance
Chris
Long Gone 69 Deluxe
http://www.reverbnation.com/whiskeyandrebellion
69GTLP is offline   Reply With Quote
Old 08-27-2009, 10:43 AM   #19 (permalink)
the oj guy
ojedad23's Avatar
Omg!!!!!
ojedad23 is offline   Reply With Quote
Old 08-27-2009, 11:38 AM   #20 (permalink)
landsharkey's Avatar
What were the two depths for the pickup cavity and the router bit(s) you used? How did you locate the jackplate hole (on the same centerline as hole to the pickup cavity? And the body roundover is 1/8" radius?
Sorry for all the ?'s but this is just too cool. How does Korina look with a cherry finish?
landsharkey is offline   Reply With Quote
Old 08-28-2009, 10:08 AM   #21 (permalink)
SG Lou's Avatar
Sharkey,
I had only pictures to go off of so I guess-timated on the jack hole.
Not very accurate I know but what the hell.
I did however get VERY LUCKY as you can see by where the drill bit exited into the pickup cavity. I PRAYED that the bit wouldn't wonder and come through the top !
I got a pdf file of a dogear route from another topic here and used that to make the first routes template. The router bit was a 3/8th
I do believe the first depth was 3/4" and than i routed the remainder at half of that.
Yes I used a 1/8th roundover bit.
St. Moritz Guitars
Old 08-28-2009, 11:21 AM   #22 (permalink)
ex-nihilo's Avatar
I love this guitar!
ex-nihilo is offline   Reply With Quote
Old 08-28-2009, 11:48 AM   #23 (permalink)
LG2
LG2's Avatar
Nice build Lou..
LG2 is offline   Reply With Quote
Old 08-28-2009, 12:01 PM   #24 (permalink)
SG Lou's Avatar
Originally Posted by LG2 View Post
Nice build Lou..
Thanks ex-nihilo and LG, I just hope my 59 Replica comes out just as good !
I'd like to get that started on that build but the all important neck blank is eluding me.
I just can't seem to find to right one and being a tightwad I don't want to pay over a $100 for a blank............so we keep looking !
St. Moritz Guitars
Old 08-28-2009, 12:24 PM   #25 (permalink)
ex-nihilo's Avatar
I wouldn't wait too long South American Mahogany is getting harder to get.
Old 08-28-2009, 02:01 PM   #26 (permalink)
Sharkey,
Thanks for the info. The drill hole to the pickup cavity couldn't be better. I may have drawn that route for the dogear. Just didn't know if you found a good source for the depth.
Old 08-28-2009, 04:15 PM   #27 (permalink)
The Thruth's Avatar
Send a message via MSN to The Thruth
Nice build SG Lou
The Thruth is online now   Reply With Quote
Old 08-28-2009, 04:18 PM   #28 (permalink)
Texas07R8's Avatar
damn nice man.. can't wait to see more.
Old 08-28-2009, 06:25 PM   #29 (permalink)
awesome photos,They are so clear & show all the steps.
That white limba is beautiful,you are a lucky man.
Old 09-01-2009, 01:22 AM   #30 (permalink)
SG Lou's Avatar
Thanks Wiz. I just wish I had more time to work on it.
I have a Hamer that needs its final coats of clear, an SG that need to be clear coated, a scratch build SG project for a customer...... I need to retire so I can do this stuff F/T
St. Moritz Guitars
A little project that I started lp_junkie Epiphone Les Pauls 8 04-07-2009 11:16 PM
Soon to be started Fix SG Marc Luthier's Corner 17 03-14-2009 08:37 AM
Getting started Chimera Epiphone Les Pauls 17 11-01-2008 06:23 AM
What started it all Fixxxer The Backstage 23 01-06-2008 02:45 AM
ive started a group lp junior freak The Backstage 16 10-11-2007 06:19 PM
