Old 08-08-2009, 10:21 AM   #1 (permalink)
ex-nihilo's Avatar
Ex-Nihilo Build 3 -SGLP
This thread will follow the building of my own custom guitar. An SG body with a 59 Les Paul maple top carve (SGLP).
Here is a computer model to give you the idea:
I made the model so that I can CNC the top. The sharp lines will be sanded out during the build. I started a chambered American Black Walnut version:
However, I think I am going to put this one on hold and build a Honduran Mahogany one first..... with p-90s!
Hope you enjoy!
Sincerely, Scott
ex-nihilo is offline   Reply With Quote
The Following 8 Users Say Thank You to ex-nihilo For This Useful Post:
Old 08-08-2009, 10:24 AM   #2 (permalink)
SG Lou's Avatar
Re: Ex-Nihilo Build 3 -SGLP
Awesome Idea......I'll be watching this one !
"It's all Iommi's fault. I blame him entirely"
A.L.S. aka Lou Gehrig's disease Sux.
Lets rid the world of this dreaded disease
St. Moritz Guitars
http://www.freewebs.com/stmoritzguitars/
stmoritzguitars@hotmail.com
Guitars:
63 SG Jr. 64 SG Special
Custom Shop Iommi Sig. SG
61 RI SG, Epi Iommi SG
Jaydee "Old Boy" SG
Custom Built "Old Boy" SG replica
63 RI Strat
Amps:
Laney GL50 head w/4x12 Laney Cab.
Laney LC15R, Line6 Spyder
Vox Brian May Special
SG Lou is offline   Reply With Quote
Old 08-08-2009, 10:28 AM   #3 (permalink)
ex-nihilo's Avatar
Here is how I join the book matched maple boards together.
I get a piece of flat mdf (I had an LP template downstairs and that worked fine) and I two-way tape one of the maple boards down to the mdf. Then, I run another strip of tape on the mdf for the other board. This keeps the pieces flat and in place while I apply the clamps.
With the hide glue prepared, I run a hot iron across the area where I am going to apply the glue.
I apply the glue.
I press the boards together and apply the clamps.
After about three or four minutes, I remove the clamps and sandwich the boards between two pieces of mdf. This keeps everything flat (even though it will be planed again). As the moister evaporates from the glue, it will continue to suck the pieces together and become glass hard.
Sincerely, Scott
Old 08-08-2009, 11:27 AM   #4 (permalink)
The Relic Madman
Another master class!!!!! thanks a lot Scott will be following this amazing idea.
"A good guitar is in agreement with itself”
Parker.
-------------------------------o------------------------------
"There will always be more Les to come. That's certified."
Billy Gibbons.
nicolasrivera is offline   Reply With Quote
Old 08-08-2009, 11:36 AM   #5 (permalink)
Texas07R8's Avatar
awesome, frikkin awesome..
Texas07R8 is offline   Reply With Quote
Old 08-08-2009, 12:14 PM   #6 (permalink)
GreaseBox's Avatar
SWEET!!!!
"...I've eaten the sun so my tongue has burned of the taste..."
GreaseBox is online now   Reply With Quote
Old 08-08-2009, 12:33 PM   #7 (permalink)
SG Lou's Avatar
Scott,
from seeing the pictures I assume you will be using the newer style neck joint as opposed to the Early 60's box joint ?
St. Moritz Guitars
Guitars:
Jaydee "Old Boy" SG
63 RI Strat
Amps:
Old 08-08-2009, 07:24 PM   #8 (permalink)
ex-nihilo's Avatar
Originally Posted by SG Lou View Post
Scott,
Yes, that is correct. It is closer to an LP mortise and tenon and will allow for greater strength and wood to wood contact.
Sincerely, Scott
Old 08-08-2009, 09:12 PM   #9 (permalink)
Grumpy Old Luthier
BCRGreg's Avatar
Putting wax paper between the mdf and the maple will keep any squeezeout from mucking up the works, guys. Better safe than glued.
I heat up a coffee mug on the stove and use it to keep my hide glue warm while applying it, it works better than trying to get from the glue pot to the work; being portable, small and easy to clean and reuse.
Hey, Scott....
www.bcrmusic.com
www.grumpyoldmenband.com
http://www.youtube.com/user/unkagreg
BCRGreg is online now   Reply With Quote
Old 08-08-2009, 09:47 PM   #10 (permalink)
pinefd's Avatar
Great Scott! (as if you hadn't heard that one before) I'm lovin' it! Looking forward to watching this progress!
Frank
Check out my website at: www.lesstallguitars.com
And check out some of my personal gear at: Historic Les Paul Database
pinefd is offline   Reply With Quote
Old 08-08-2009, 09:52 PM   #11 (permalink)
Br0ken68's Avatar
Well we know you iron. Do you do windows too? =)
Br0ken68 is offline   Reply With Quote
Old 08-08-2009, 10:05 PM   #12 (permalink)
Master Sawdust Maker
Nelson674's Avatar
can't wait to watch this one unfold!
Scott, thank you for taking the time to share this with us!
Nelson
Learning to shrug is the beginning of wisdom.
Nelson674 is offline   Reply With Quote
Old 08-10-2009, 07:22 AM   #13 (permalink)
ex-nihilo's Avatar
Hey, Scott....
[/QUOTE]
Hey Greg, that gives me an idea as to how the binding will look. What kind of guitars are these and when were they made? I am going to place the selector switch by the top horn (like a LP), use thinner binding, a steeper carve, not a perimeter burst, quilted maple crown shaped inlays, and I'm going to use an LP pick guard too. But this picture definitely shows me that there is potential! Thanks.
Old 08-10-2009, 07:28 AM   #14 (permalink)
Grumpy Old Luthier
BCRGreg's Avatar
Robin Artisans, late 80s.
www.bcrmusic.com
Old 08-10-2009, 01:03 PM   #15 (permalink)
Greco's Avatar
Originally Posted by ex-nihilo View Post
Hi Scott,
Having owned a Gibson SG for many years, I'd be concerned about where you have the route for the selector switch in this photo. It looks like it is getting close to being right in the middle of the pickups or at least close to where a players strumming hand would hit the switch all the time. I think that's why most SGs have the switch by the knobs. Maybe it's just the angle?
Greco is offline   Reply With Quote
Old 08-10-2009, 04:00 PM   #16 (permalink)
ex-nihilo's Avatar
Originally Posted by Greco View Post
Hi Scott,
That is a very good point. Thank you for mentioning it. I will have to look into it.
Old 08-10-2009, 04:09 PM   #17 (permalink)
EtriX's Avatar
Scott, your builds are always great. I love to read and see how you've progressed between each photo op. Looking forward to see how you do on this thread. I love the SGs and I love carve tops This should be a ducey
HORROR FLICK LOVERS
"No Mr. Page, it's not malignant. Seems you have a rabid fan attached to your left testicle".
Chasing AXE-Tone® since 2008
Southpaw City
EtriX is offline   Reply With Quote
Old 08-10-2009, 10:17 PM   #18 (permalink)
the oj guy
ojedad23's Avatar
ojedad23 is offline   Reply With Quote
Old 08-11-2009, 07:49 AM   #19 (permalink)
ex-nihilo's Avatar
Hi Scott,
Alas, it is true. I will have to arrange the electronics SG style rather than LP style.
Old 08-11-2009, 09:35 AM   #20 (permalink)
Wow, good thing someone caught that!
Does anyone ever consider using a different kind of switch that wouldn't get in the way like a sliding switch?
TexasNate is offline   Reply With Quote
Old 08-11-2009, 09:45 AM   #21 (permalink)
SG Lou's Avatar
Nate,
I think Scott is trying to keep the looks of everything in the Les Paul / SG family. If it were a different guitar a sliding switch would fit the bill.
St. Moritz Guitars
Guitars:
Jaydee "Old Boy" SG
63 RI Strat
Amps:
Old 08-11-2009, 09:52 AM   #22 (permalink)
Sorry to get off topic but i think this looks so cool!
I think that these would get in the way though....
Old 08-11-2009, 09:56 AM   #23 (permalink)
Ok, now that is just wrong. lol How many knobs does someone really need?
"People should not fear the government, government should fear the people" - Thomas Jefferson
"Sex and drugs go hand in hand when you`re a rock `n` roll musician. If I were a violinist, it might be a different matter." - Slash
csparks75 is offline   Reply With Quote
Old 08-11-2009, 10:15 AM   #24 (permalink)
Luke122's Avatar
Send a message via MSN to Luke122
I've got one, works for me.
Errr...
Looks like a volume and tone for each pickup.
Originally Posted by Benniator
Who cares that you don't care that I don't care that he doesn't care that he hates Neil Young?
Originally Posted by myspace.com/jessenoah
only a buckethead fan could be so dumb
Luke122 is offline   Reply With Quote
Old 08-11-2009, 11:23 AM   #25 (permalink)
ex-nihilo's Avatar
The bright side is that even though I wanted the switch on the upper horn (like an LP), placing down by the vol. and tone knobs will be easier to make.
Old 08-11-2009, 11:50 AM   #26 (permalink)
SG Lou's Avatar
So true !
St. Moritz Guitars
Guitars:
Jaydee "Old Boy" SG
63 RI Strat
Amps:
Old 08-11-2009, 12:08 PM   #27 (permalink)
cynic79's Avatar
Looks good!
I've been giving it some thought, and the notion of a guitar with the all the appointments of a Les Paul, but with an SG style body seems more and more appealing. Something akin to the Robin Artisan, but with a carved top, would be a fantastic guitar.
EDIT: Just did some poking around and say that the Artisans supposedly did have a carved top. It's a little hard to tell from the posted pics.
cynic79 is offline   Reply With Quote
Old 08-11-2009, 12:26 PM   #28 (permalink)
jo07's Avatar
Nice!!!
MyLeftBall.
jo07 is offline   Reply With Quote
Old 08-12-2009, 07:13 AM   #29 (permalink)
Greco's Avatar
I don't think it's impossible to have the switch on the upper horn, especially as you are not cutting in the traditional SG contours in that area on the top. The way Gibson does the contours make a stich in this area pretty cumbersome. With the flatness of the horn on your design you have more scope to drill the switch cavity up further towards the point of the horn. As long as once in place the poker chip doesn't overlap the binding then it won't look weird and shouldn't be any more intrusive to playing than a Les Paul switch. I guess you could experiment and compare the placement to the Catto LP plans to see if it's viable, or mock it up in 3d?
Old 08-12-2009, 06:35 PM   #30 (permalink)
shtdaprdtr's Avatar
who said he needs a poker chip?
shtdaprdtr is offline   Reply With Quote
Well here we go, LP build #1 Mongrel Luthier's Corner 342 10-22-2009 08:23 PM
Purfling, Life Changes, and Scott (Ex-Nihilo) x_archangel_x Luthier's Corner 11 05-21-2009 06:49 AM
Epiphone build (My first build) maegnus Luthier's Corner 1 01-19-2009 07:05 PM
Anyone build one of these?? randelli Pedals 6 10-06-2008 10:54 AM
Build an Amp?? randelli The Squawk Box 0 08-07-2008 09:25 PM
Powered by vBulletin® Version 3.8.4
