#91 (permalink) | |
![]() Join Date: Jan 2009
Re: "camille" small build
I've never been into Canada. I'd love to get up there and do some fishing! I havent touched a pole in 6+ months but my friend still hits it daily here. We used to charter a boat out of the grand river at lake erie every year with Thumper Charters (Capt. Ron Johnson) The best!!! We used to haul Pigs outa that place. We have a HY-Vee that opened up here in town and they have walleye @$12.50/pound. That's a hell of a lot cheaper that it costs us to fish for it
#92 (permalink) | |
thanks! fletch |
#94 (permalink) | |
#95 (permalink) | |
You might want to tape your fingers up too. The damn things are sharp ![]() You tend to get a little lazy after you get started and loosen your grip a little. I think it's too early in the build stage to start staining if you no what I mean.
#96 (permalink) |
A little help please! I want to route the truss rod cavity tomorrow, and at the last minute I decided I should go with a slim taper for cami's build. Does anyone have the specs like on the stewmac plans at the 1'st and 11th frets? Since this is for a 8 soon to be 9 y.o. the 59 neck is a little thick isnt it?
#97 (permalink) |
looking in the back of The BOB the thinest 60,s neck was
thickness at f1 20.0mm (40 thou thicker than 3/4in) f11 21.8mm (just under 7/8in) width at nut of 42.8mm at body joint 54.5 thinest measurements over all (a mixture if you will) f1 20mm f1 21.8mm nut 42.5mm body join 54.3mm hope that helps |
#98 (permalink) |
Just a thought because the neck is shorter,will you be using lighter guage strings?
If so the over all neck thickness could be thiner(Ibanez style). the thinest for the stew mac hot rod style truss rod is 3mm under the adjustment nut area,(I would have thought that this was too thin but I fix cars for a living)so the thinest I see the neck at the nut is 14mm (1mm counter sink for the brass block,10mm for the truss rod) |
#100 (permalink) |
Awesome work...I look forward to seeing the finished product
1998 Epiphone Les Paul Standard MIK BABY! Peavey Vypyr 75 Rocktron Classic Wah '78 Boss OD-1 |
#104 (permalink) | |
Just been rereading my post and realised it may not have made sense.the neck measurement of 14mm is without the fretboard on. |
#105 (permalink) | |
Yeah, I figured it out. Thanks!
#106 (permalink) |
I finally got around to uploading some more photo's of progress.
Some of the photo's are self explanatory.......... I found a hooked shaped x-acto blade that worked great for getting in tight to trace the mop. Oh, I used mop on this because cami liked it better than the celluloid i used on mine. (she thinks I am building a guitar for a friend) I then followed up with a normal x acto changing the blade everytime I did a new one. ![]() ![]() ![]() ![]()
#107 (permalink) |
![]() Starting on the curved truss rod route. I already messed up on the first neck by getting the headstock too thin and had to cut another ![]() ![]() Using the jig I made for my first guitar with a shorter curve in the template ![]() ![]() ![]() ![]()
#108 (permalink) |
Making the truss rod. I don't remember anybody posting photo's of this. Not
very technical or exciting or very good pictures for that matter but here they are anyway. This is the stew mac truss rod. cutting to length...... ![]() I couldn't get the picture very good but I like to gind a small bevel on the end before I thread it, or anything else for that matter..... ![]() ![]() ![]()
#110 (permalink) |
Truss rod installed then maple strip glued in......
![]() ![]() ![]() Later I sanded down the maple strip flush to the fingerboard then glued on the wings..... ![]() ![]() Cut the taper on the finger board.... ![]() Then I finished cutting the fret slots to depth and fretted the board..... ![]()
#112 (permalink) |
Ok, Here is what I have for her headstock. You have already seen the mop duck in earlier posts.
What do you think of this? Too much? I like it, but I'd like to know others opinions. The headstock is the same as a full size other than I took a bout 3/4" off the top ![]() Here is on with my full size......
#113 (permalink) |
Thanks,
It helped me out a lot, I have a hard time with my finger on delicate operations, they've been abused pretty badly over the years.
#114 (permalink) | |
fletch |
#115 (permalink) |
Thanks, it's the third set I have ever done. At least they get a little better/cleaner on each one.
I used grizzly mop since they had the points, I don't think I will use them again though. I don't think they were very good quality. Some had pretty deep depressions that had to be sanded out and rough saw marks. Then one of them was pretty translucent like if you sand one too thin and can see the wood. (which I know from experience ) but these are all pretty thick. I didn't find out till it was glued in either.Part of me wants to route it out and replace but the other part says that's were all my problems usually start. I'll probably leave it. Oh, and the board is just a stewmac indian rosewood.......
#116 (permalink) | |
I'm thinking of doing her birthdate on the back of the headstock using the technique mongrel and ex-n have done.
#117 (permalink) |
Dude that is cool. I love seeing the mini threads. How old is your daughter.
peace n tone ![]() Never underestimate the predictability of stupidity WBpickups-My tones as fat as a Samoan ballerina Yeah my gear is beet up, Thats cause I play it. Shut up and play. http://www.myspace.com/daisychamber whiners click here http://www.youtube.com/watch?v=XDwyG...eature=related |
#119 (permalink) |
I ask cause my son wants a green one but he is only 5. I want to do a quilt top in Trans green for him. Headstock logo of the old green machine.
#120 (permalink) | |
Sounds killer dude!!!
| "The official MLP Rist Guitars build thread" | Roman Rist | Luthier's Corner | 1110 | 11-06-2009 08:19 PM |
| Feeler: Should I do a "poor mans" build thread? | ex-nihilo | Luthier's Corner | 157 | 08-08-2009 12:34 PM |
| "MLCS Probable Bargain" Small Router | Ole'Lefty | Luthier's Corner | 3 | 07-08-2009 07:28 PM |
| "Small Paul" Build... | GreaseBox | Luthier's Corner | 129 | 06-28-2009 03:04 PM |
| The "Official" How Not To Build A Guitar Thread | voices | Luthier's Corner | 62 | 02-24-2009 08:47 AM |
