Old 04-05-2008, 07:35 PM   #121 (permalink)
Master Luthier V.I.P.
Roman Rist's Avatar
Re: Ask Roman ?
check your thread.
Roman Rist is online now   Reply With Quote
Old 04-06-2008, 01:29 AM   #122 (permalink)
captainbraindamage's Avatar
Re: Ask Roman ?
O wise one, impart your wisdom on an unworthy noob. I've read it's not good to leave the strings off your guitar for too long. So how long is too long? 2 days, a week, 6 months? I realize temperature and humidity and all that will factor in. But if I've got all the hardware stripped off and electronics removed, when should I be saying, phuque I better get this back together.
captainbraindamage is offline   Reply With Quote
Old 04-06-2008, 01:36 AM   #123 (permalink)
Harpozep's Avatar
Re: Ask Roman ?
Hey, that's a good question. I'd worry a lot more if it was acoustic, that's for sure. But let's see what Roman has to say. Good question there.
Behave all,
Harpozep
I'b' Use'bd' WB'bd' Pick'ups'b'
"Lyrics: Time wasted between solos"
Harpozep is offline   Reply With Quote
Old 04-06-2008, 01:45 AM   #124 (permalink)
Roman Rist's Avatar
Re: Ask Roman ?
I think these writers are full of crap.
Leaving the strings off is not what hurts a neck, The biggest factor is humidty.
Lets say for an example you send you guitar to be refinished. It is not uncommon for a lacquer finish to take months.
That means the strings are off for months.........the neck is fine.
Now here is one thing I DO recommend.....loosen the truss rod.
the truss rod being tight when strings are off, can put the neck into a condition of a reverse bow with out the string tension to pull the neck into relief.
This can create a situation where the neck retains that reverse bow in the memory of the wood. lossen the rod and you will be fine!
As to time, well let me say this; I have some guitars that are personal projects that have sat around for years with no strings.............the necks are fine.
Old 04-06-2008, 12:52 PM   #125 (permalink)
Re: Ask Roman ?
Full of crap? Naw I just got up and I took care of that. Thanks for the reply though, I'll just loosen my truss rod, it's an Epi, its got no nuts. Gonna do some fillin n drillin, and I don't want to have to hurry. Whenever I hurry is when I fuk somethin up.
Old 04-06-2008, 12:57 PM   #126 (permalink)
Re: Ask Roman ?
Oops need more coffee
Old 04-09-2008, 12:25 AM   #127 (permalink)
3dmac's Avatar
Re: Ask Roman ?
Hiya roman,
Just finished today with the last 2 finish coats. Finish is almost like glass now
Now the wait begins
Flame on !
3dmac is offline   Reply With Quote
Old 04-09-2008, 04:01 PM   #128 (permalink)
Roman Rist's Avatar
Re: Ask Roman ?
Originally Posted by 3dmac View Post
Hiya roman,
Now the wait begins
Flame on !
Looking great, you are almost ready to come work for me, of course there goes your house, your family and your income!
Old 04-10-2008, 12:34 AM   #129 (permalink)
3dmac's Avatar
Re: Ask Roman ?
Good one,
Well the house is almost payed off, I can semi retire in about 3 yrs, and the wife can do sanding !! lol
Old 04-10-2008, 01:19 AM   #130 (permalink)
Roman Rist's Avatar
Re: Ask Roman ?
Hmmmm, how does she feel about this????
Old 04-10-2008, 02:13 AM   #131 (permalink)
3dmac's Avatar
Re: Ask Roman ?
She's already High from the nitro already
would be a break
Old 04-10-2008, 05:48 PM   #132 (permalink)
GLOBAL EMO MOD
FLICKOFLASH's Avatar
Re: Ask Roman ?
Have you heard of covering a strat neck with supper glue as the finish ?
FLICKOFLASH is online now   Reply With Quote
Old 04-10-2008, 05:59 PM   #133 (permalink)
Roman Rist's Avatar
Re: Ask Roman ?
Yes, I have done it too.
What I have found to work the best is this.
Rubber gloves.....so your hands dont get CA on them.
Blue shop towels.........the kind you get at auto parts stores.
Water thin Super glue (CA)
Wet the towel with the super glue and do QUICK swipes on the neck.
Always use a fresh section of the towel, and keep swiping till you get the neck covered to your desired thickness.
Fine sand and steel wool , and you have a thin, rock hard satin finish!!
enjoy
Roman
Old 04-11-2008, 09:58 AM   #134 (permalink)
LES STORY's Avatar
Talking Re: Ask Roman ?
Hey Whats Up--
I Have A V I Want To Refinish .do You Think It Would Be Better To Sand Off The Old Finish Or Use A Paint Stripper ? I Wonder If The Paint Stripper Would Harm The Glue In The Neck Joint OR Fretbord.
Thanks -ljs
LES STORY is offline   Reply With Quote
Old 04-11-2008, 10:40 AM   #135 (permalink)
Roman Rist's Avatar
Re: Ask Roman ?
Good morning all! I don't know what the hell I am doing, being up at 7:30 !
Anyway.............
Regarding stripping finishes;
I am not fond of chemical strippers. They are messy, stink and toxic.
Because of this I have no Pro advice on using them.
I have used them and you have to tape off what ever you do not want to melt ( such as binding).
If you tape off the fingerboard no srtipper will get in there and I have never seen anyone melt the glue on the neck joint.
My weapons of choice for stripping finishes are a heat gun and razor blades.
That can be tricky because you can set the finish on fire, so practice is needed.
I simply aim the heat gun to a section and as I see it start to melt, scrape off the finish with a razor blade.
I hope this all helps some
Roman
Old 04-11-2008, 12:45 PM   #136 (permalink)
decoy205's Avatar
Re: Ask Roman ?
That must take a looooooooooooong time Roman.
decoy205 is offline   Reply With Quote
Old 04-11-2008, 04:23 PM   #137 (permalink)
Roman Rist's Avatar
Re: Ask Roman ?
For me it is quicker than stripper with 1/4 the mess
Old 04-12-2008, 05:44 PM   #138 (permalink)
Ejecto's Avatar
Re: Ask Roman ?
Just wanted to say thanks for this thread and the others like it by yourself and Greg etc.
It's like, I'm learning, but i like it?!
Always do whatever's next.
George Carlin
Ejecto is offline   Reply With Quote
Old 04-12-2008, 09:43 PM   #139 (permalink)
Roman Rist's Avatar
Re: Ask Roman ?
You are welcome, we do what we can in sharing experience.
Thank Flick, he is the one that started it!
Old 04-13-2008, 11:28 AM   #140 (permalink)
Grumpy Old Luthier
BCRGreg's Avatar
Re: Ask Roman ?
Yeah.
Thank Flick. He just unleashed us on you guys....
www.bcrmusic.com
www.grumpyoldmenband.com
http://www.youtube.com/user/unkagreg
www.ristguitars.com
BCRGreg is offline   Reply With Quote
Old 04-15-2008, 11:52 AM   #141 (permalink)
Scooter2112's Avatar
Re: Ask Roman ?
Gentleman..... how involved would it be for me to remove a neck humbucker on an Epi LP Standard, and install a p-90??
Would there be any routing/ filling involved and what should I do to prevent from chipping the poly finish beyond where any alterations would be made?
Would you recommend masking off the boundaries or something along those lines, or is there some sort of pickup ring that is made to fit the existing cavity?
Thanks!
1980 Gibson Les Paul Custom - Heritage Cherry Sunburst (stock)
2004 Epiphone Les Paul Standard Plus - Honeyburst Flame-Top (SD Phatcat P-90 / Gibson '57 Classic Plus Pups)
2002 Epiphone Elite Standard Plus Faded Cherry
2005 G&L Legacy
'79 Alvarez 12 string
Vox AD60VTX
"Have you hugged your Custom today?"
Scooter2112 is offline   Reply With Quote
Old 04-15-2008, 01:42 PM   #142 (permalink)
shotgunlew's Avatar
Re: Ask Roman ?
If you look at the thread about roman building my les paul, he does a process to my neck pocket that would be simular to how you would do the pickup ( i believe )
chris
Thanks!
60% of the time...it works every time....
Gun Control = Using Both Hands!!
Everyone Please Pray for Sgt Jeffery Crones and the rest of the boys in iraq! Get some boys!
Chris "The Gunhand" Of the MLP Pirates Crew
shotgunlew is offline   Reply With Quote
Old 04-15-2008, 02:18 PM   #143 (permalink)
Roman Rist's Avatar
Re: Ask Roman ?
Thanks!
A P-90 is longer than a humbucker but not as wide.
The body would have to be routed slightly to get the p-90 to fit
A better way to go is to install a Duncan p-90 that is the size of a humbucker.
Progressive - Phat Cat™ SPH90-1 - Seymour Duncan/Basslines
Old 04-15-2008, 06:25 PM   #144 (permalink)
Re: Ask Roman ?
Yes... that definitely looks like the way to go. I didn't want to Dr. Frankenstein it if I didn't have to, but would consider all options. I should have done my homework before asking.
Thank you, sir!
2005 G&L Legacy
Vox AD60VTX
