#212 (permalink) |
![]() Join Date: Apr 2007
Re: Building a Chambered LP
not yet, I just put some WB pickups in last week though, and am really excited about doing another soundclip. I will snap some photos then.
ahandkerchiefsandwich.com Guitar Building Gallery Hobby Guitar Builder/ Notaluthier |
#213 (permalink) |
Well I'm new to this thread and I'm totally impressed. Well done. I've actually been a little mia from the forums for a while (building the car below takes all my time) and Roman turned me onto this thread while giving me some tips about a chambered LP I plan to build from KOA in my "Spare time".
I noticed that someone had mentioned a while back using a bridgeport mill, I have access to one (I build hot rods professionally) and was wondering what type of endmill and what speeds you guys would use. I use it on metal all the time but never on wood. ![]()
#215 (permalink) |
haha I guess that one would be a little more relevant on here. He's a car guy too, and cool as hell.
Still hoping for some bridgeport tips to make my chamber, also anything special for drilling the anchor holes for the bridge/tailpiece so it doesn't tear the wood?
#216 (permalink) |
Location: You know, you kick a duck. It's ok! Suck a duck and your forever a duck sucker! Don't suck a duck!
![]() Countdown is coming! Love the Puffy Taco!
#217 (permalink) |
Master Luthier V.I.P.
![]() Join Date: Dec 2007
Put some blue tape on top of the wood and use Bradpoint bits
Factories build guitars for profit, Luthiers build them for players ![]() |
#218 (permalink) |
Hey Borris.
I use to use a mill quit a bit when building guitars. I could mill the thickness down to where I needed. Route the neck joint, pickups, whammy bar placement. etc etc Just like using a router only you didn't have to worry about the damn thing jumping on you and going crazy on the product. As far as bits I used what ever size best fitted what needed pocketing. A flycutting bit for milling the thickness down. By the way I'm a fellow car guy also. Been restoring cars here in Ky for 20+yrs now. Mostly muscle cars, but have worked on just a bought every thing. RandyB. |
#219 (permalink) |
I just wanted to thank nmguitars for taking us through this process in such a detailed fashion. I really appreciate the education (you ARE a teacher) as well as the craftsmanship that is going into this instrument. Thanks very much!
#220 (permalink) |
Super Moderator
check out some of Nick's other projects : My Strat Mod
#221 (permalink) |
![]() Join Date: Mar 2007
Can't we stop these f$%*'n idiots?!?
Check out my website at: www.lesstallguitars.com And check out some of my personal gear at: Historic Les Paul Database |
#222 (permalink) |
I don't know...
We might have a hard time getting them off!
#223 (permalink) |
With that much Viagra, I think you're right!
#224 (permalink) |
![]() Join Date: Feb 2008
WOW with all that i could knock the teeth out of my zipper!
60% of the time...it works every time....Gun Control = Using Both Hands!! ![]() Everyone Please Pray for Sgt Jeffery Crones and the rest of the boys in iraq! Get some boys! Chris "The Gunhand" Of the MLP Pirates Crew 1986 Les Paul Jr (Cherry red Singlecut ) 1994 MIJ fender Telecaster 52 reissue 1984 JCM 800 1x12 50 watt combo Behringer 4x12 cab (Bugera speakers) |
#225 (permalink) | |
I know this is way back in the thread but what size binding do you use on the body from stew mac? What size for the neck as well?
#227 (permalink) |
Ok OK, one more soundclip with the WB special brew PUs.
Soundclip
#229 (permalink) |
this thread was awesome to read, very cool
thanks
Guitars Squier Stratocaster ESP LTD V-350 Ibanez RG7321 ESP LTD MH-400 Ibanez RGT220A Prestige Epiphone Les Paul Midnight Custom Epiphone Les Paul Standard Honeyburst Amps Peavey 6505 Head Peavey 4X12 Cab Line6 Spider 112 Yamaha Budokan |
#230 (permalink) | |
The Axe Louse's & The Pickup Winder's forum can
#231 (permalink) |
What happened? I am enthralled with this project and feel like I got to the end of a great book and found the last chapter missing!
#234 (permalink) |
[/QUOTE]
On every guitar up until this point, I have routed a curved truss rod channel using a jig that I made just for this. On a curved channel, the route is deeper in the middle of the neck than on the ends. On 50s LPs including original bursts until 1960, gibson used a straight channel that is 1/2" deep the length of the neck, so I thought I would give this method a try, even though I understand that this will make the truss rod a little less responsive the closer to straight the neck is. I set the blade on the table saw to 1/2" and cut a channel in three passes just slightly wider than 3/16" for the truss rod. It is a nice fit, with just enough room to allow for the truss rod to function, but not be rattling around: [/QUOTE]I am building my first les paul, and your (and other members') building threads have been extremely helpful. I am at the stage where I need to cut the truss rod channel. I have built a few teles, and used curved truss rod channels for those. I am trying to decide if I should use a curved or straight channel for the LP. Have you noticed if the straight truss rod channel on your chambered LP is less sensitive than some of your other LPs? Thanks. |
#235 (permalink) |
Looking good
#236 (permalink) | |
#237 (permalink) |
What the heck is a Mr. Bones?!?
#238 (permalink) |
"Mr Bones, what's all about?"
#240 (permalink) |
I think the first clip is straight into a Super Reverb, the second clip is a Super Reverb with a Maxon OD820 which is a little different from the 808. On the amp I always keep the treble on 8.5 and the Bass on 0-1. The midrange I alter depending on the guitar. With strats I turn it up, with LPs I turn it down, with Tele's I keep it in the middle. I set the reverb on 2-3 and go into the #1 input with the bright switch always off.
| BUILDING a nut, odd, but yes! | GibsonGuitars119 | The Custom Shop | 21 | 08-20-2008 11:20 AM |
| Using Eld for guitar building? | fjgaston | Luthier's Corner | 5 | 06-06-2008 05:54 AM |
| Building three more! | Pwozzie | Pedals | 2 | 05-09-2008 08:52 AM |
| Building a LP Help | slash is god | Luthier's Corner | 3 | 05-09-2008 04:18 AM |
| building a lp | bandjosh | Epiphone Les Pauls | 13 | 04-20-2008 04:04 PM |
