Old 12-16-2007, 12:24 PM   #61 (permalink)
Mr Bones's Avatar
Re: Building a Chambered LP
Ok, now it's time to bring these two parts together by routing a mortice for the tenon:
Then slowly test fit the tenon, and the make adjustments, then test, then adjust etc etc for about an hour until the joint lines are perfect. I use Freddy G's advice with the tenon of making it tight enough to pick up the body by the unglued neck and not have it fall out.
Glue time:
Mr Bones is offline   Reply With Quote
Old 12-16-2007, 12:26 PM   #62 (permalink)
Mr Bones's Avatar
Time to stop for a bit and clean up the shop. I've been moving at a pretty good pace, and haven't stopped to clean up since last Sunday.
Old 12-16-2007, 05:21 PM   #63 (permalink)
61LPSG's Avatar
Fantastic thread ! I admire your work, and love that top...mmmmmm.
I've always wanted to do this, and may find the time when I retire.
Can't wait for the next "episode".
Sometimes it is better to remain silent and be thought a fool, than to open your mouth and remove all doubt...
61LPSG is offline   Reply With Quote
Old 12-16-2007, 05:44 PM   #64 (permalink)
Mr Bones's Avatar
Thanks 61LPSG, but you won't have to wait long. I went down to start cleaning up, and inevitably didn't get very far before I decided to do "one more thing." I use a stew mac fret slotting jig, but only to get a mark on where the slots go. I dont like the saw, and have much better results using a different saw, and doing the final fret slots after I have radiused the board.
After I have cut all 22 slots plus a cut for the "23rd fret," i.e. the end of the fretboard, and the nut, I cut the two ends off with a hand saw:
I found these inlays for a steal about a year and a half ago, so I bought about 15 sets. They aren't especially vintage-correct, but I really like the look of them on a nice dark board:
I lay out the inlays, and trace around them with pencil
then start routing the cavities with a dremel and a 3/64" bit:
I then clean up the routes with a .055" straight cut bit. These tiny bits are perfect for getting the points routed.
Then one by one I fit the inlays to the routes and glue them in with Duco cement. Nice tight routes with very few gaps to fill. I did get one inlay off center which Im pissed at myself for. That 6th inlay will bug me for the rest of my life
Old 12-16-2007, 06:02 PM   #65 (permalink)
single cut 54's Avatar
Great work nm ,How many hours do you estimate it will take to complete the project and what's the average hours you spend on a Les Paul type guitar.
single cut 54 is offline   Reply With Quote
Old 12-16-2007, 06:16 PM   #66 (permalink)
lp59aholicDon's Avatar
IS that neck Tenon longer that the original LP type configuration It sure looks like it from picks , Neck angle? and how much cant does the neck have ? How are you going to radius the fretboard?
I am a sheepdog, Its not just a vocation, its my nature Live with it, Lead, Follow, or get the hell outta my way . Tis better to have the sword and live by it, than to reach in need and find the scabboard empty .Democracy is two wolves and a sheep voting on whats for dinner- Ben Franklin Don't be talkin' the talk if you can't walk the walk
lp59aholicDon is offline   Reply With Quote
Old 12-16-2007, 06:30 PM   #67 (permalink)
I'm looking forward to the radiusing of the board too.
Old 12-16-2007, 07:37 PM   #68 (permalink)
tiedstick's Avatar
This is pretty amazing MM. I plan on giving my Epi LP a new burst and finish next year and I'm looking forward to seeing how a pro does it beforehand. Awesome work so far!
tiedstick is offline   Reply With Quote
Old 12-16-2007, 07:55 PM   #69 (permalink)
Grumpy Old Luthier
BCRGreg's Avatar
I love seeing stuff done WITHOUT CNC.
Well done, sir.
www.bcrmusic.com
www.grumpyoldmenband.com
http://www.youtube.com/user/unkagreg
BCRGreg is offline   Reply With Quote
Old 12-16-2007, 08:02 PM   #70 (permalink)
Mr Bones's Avatar
The tenon goes past the fingerboard into the neck PU cavity, I will take a shot with the fingerboard on soon. The neck angle is 4 degree for this one. I really could have taken it down to 3.5 and been fine, but wanted to give a little room. The last time I tried to get a neck angle as small as possible, everything worked out great on the drawings, but I came up about 1/64 short and couldn't get a super low action.
Old 12-16-2007, 09:47 PM   #71 (permalink)
Mr Bones's Avatar
I hope you guys aren't expecting anything elaborate for the radiusing. I know my table top is flat (I rechecked it), but to be sure, I clamped an MDF board to it, then taped the fingerboard with double-sided duct tape (I use this stuff for all templates/ temporary sticking), which I ran down the entire back of the fingerboard to make sure I didn't make the board uneven (I did pat the tape with cloth though so it wouldn't bond so tightly that I wouldn't be able to get it up, or would snap it getting it up).
Then I stick 60 grit sandpaper to an aluminum 12" radiused sanding block:
and proceed to go through all the grits from 60-2000. It's a nice touch to have a really polished fingerboard, as it plays more smoothly, and the polishing actually darkens the board, almost like it has finish on it. I like to get it to where it shines:
Radius:
On the guitar:
I can't wait to see the fingerboard once I get some oil on it at the end. This board turned out to be darker than I thought it would be.
Old 12-16-2007, 09:51 PM   #72 (permalink)
Mr Bones's Avatar
Well done, sir.
Thanks Greg. If I wanted to build more than just a couple of these a year, I would trade the hand tools for CNC in a heartbeat, but as it is now, my favorite parts are when I get to turn the power tools off.
Old 12-16-2007, 09:54 PM   #73 (permalink)
Mr Bones's Avatar
Hard to say. At this point I have around 40-50hrs in it, but time wise I would say I am maybe halfway at this point. It gets a lot slower once you get past the initial stages of making it look like a guitar. My first few guitars, I got to this point and thought wow, I am almost done, and then rush through finish sanding and paint. I learned the hard way that finish sanding and painting really should take about as long as the guitar if it going to look good. I'm still not there yet with the whole package, though I am learning to get better about the finish work, but as Flick can attest, as he has seen a two of my first three guitars, they look good from a distance, but up close you can tell I went too fast on the final stages.
Old 12-16-2007, 10:15 PM   #74 (permalink)
pinefd's Avatar
Wow, Nick, I can't believe how fast you just zip through this stuff. I would imagine, though, that since this is your 8th, you have all of your templates already made, and are beginning to get real comfortable with your techniques. And I know what you mean about things starting to slow down at this point. So, do you still think you'll be ready to shoot this before Christmas?
pinefd is offline   Reply With Quote
Old 12-16-2007, 10:27 PM   #75 (permalink)
Mr Bones's Avatar
I think so, since I am off work for next week, but with the baby you never know . It also looks like the weather may get above 50 next week, so I will want to get some painting done on some other guitars. The templates are already there, which REALLY helps time-wise, and I've added some tools like the table saw and mitre saw which really make things like the tenon go MUCH faster. I had the house to myself today too, which was nice to just immerse myself in it. The biggest slowdown for paint at this point will be when the pigtail stud bushings arrive. Neck binding should be here by Tuesday via stew-mac.
Old 12-16-2007, 11:31 PM   #76 (permalink)
Master Luthier V.I.P.
Roman Rist's Avatar
I love this thread.
You are doing a great job and, It makes me a bit envious.
I usually have 10 guitars going at once..................but for other people!
I'd love to have the time to build just one, one at a time for me.
Carry on brother and enjoy yourself!
Factories build guitars for profit, Luthiers build them for players
Roman Rist is offline   Reply With Quote
Old 12-17-2007, 11:03 PM   #77 (permalink)
Mr Bones's Avatar
Not a whole lot of progress today, as I spent most of the morning cleaning up shop:
I then went to work on truing the neck. The back side of the radiused sanding block is perfect for leveling as it is wide enough and perfectly flat:
I check it with a straight edge as I go until there are no dips twists or rises. There are shims under the end of the body and the back of the neck holder that you can't see in this pic, but they are there to stop the neck flexing while I sand on it.
Before I glue the fingerboard on, I want to route out the pickup cavities since I have to stick a template right where the fingerboard will be:
I was really nervous to see where my internal routing and blocks were going to come out. I knew I had measured everything, but could no longer see anything inside. Luckily everything underneath appeared where I expected it to:
I like to move the bridge pickup about 3/16" closer to the neck that a standard LP. I like em a little warmer, and with the wraptail, it takes a bit of the snap out of it while still getting the sustain of the wraptail:
I hope that my neck binding shows up tomorrow, or I will be treading water a bit.
Old 12-18-2007, 12:14 AM   #78 (permalink)
MLP Chaplain
ReverendJWblues's Avatar
Im curous to know just exactly how you carve the tops.
JW
JW
http://www.myspace.com/jwblues54
Robert Johnson went to the crossroads to sell his soul to the Devil, what have you done with yours?
ReverendJWblues is offline   Reply With Quote
Old 12-18-2007, 12:40 AM   #79 (permalink)
Mr Bones's Avatar
Just take a fingerplane:
(mostly just the second one from the left) and slowly plane away the wood until the top carve begins to take shape. The pics you see now, the top carve is still not completely finished. There is still a bit of clean up to do, and as I get closer and closer to what I think is the final carve, I will spray sand and sealer on it so that i can see any high spots or dips or chips in the carve.
Old 12-18-2007, 03:24 AM   #80 (permalink)
BobbyK's Avatar
Wow... this is excellent.
I'd really like to get into this, I did a lot of research a few years ago, and started building a mandolin-size four stinged instrument.
Time, money, and tools slowed me down.
I suppose as, it was only a minor project (the thing doesn't even have a truss rod... but looking at yours, I might go that step further) I focused more on playing guitar...
I've still got plenty of time later in life to get into it though.
BobbyK is offline   Reply With Quote
Old 12-18-2007, 11:28 PM   #81 (permalink)
Mr Bones's Avatar
Ok, I was trying to figure out this morning how deep to drill the stud holes, but managed to actually get ahold of the man at pigtail himself and get the question answered. I had already made a template for the stud holes, and marked out the guitar ready for the drill press:
Once I knew that the bushings and studs were 7/8ths I could drill the holes 15/16ths deep:
I spent most of today working on another guitar, but did get around to this one. My neck binding arrived first thing this morning, so I went next to gluing the fingerboard on. I am remiss, because I was squeezing this into a busy morning, and didn't snap any shots, but it was pretty straightforward. Gluing the fingerboard on it always tricky, and I need to devise a method to make it easier to not have the board slip sliding around. After a stressful minute or two I got it clamped up where I wanted it, using a cutoff of neck binding, and a dummy nut as a guide. I made sure to clean up any squoozen out glue so that it would not present any issues for the neck binding.
This evening I took the clamps off, and checked the board. As suspected I needed to do some leveling. Here is where the fine sanding I did earlier helped out, as I could see low spots pretty quickly. There wasn't too much to sand, but I want the board to be perfectly straight before fretting.
Old 12-18-2007, 11:34 PM   #82 (permalink)
Mr Bones's Avatar
Next, I started on finishing cutting the fret slots. I mentioned earlier that I don't much like the fret saw that comes with the stew mac fretting jig, so I just use that jig to outline the fret slot locations, and I cut the slots to depth using a hand saw, and a block to keep me perpendicular:
I take a business card and mark the depth of the fret tang onto it so that I can get my slots to the correct depth:
Then I bend some medium fretwire with a healthy bit of overbend:
(BTW, at this point, any tips from the pros are much welcomed. My fretting and fretwork knowledge is very, very basic, and my methods pretty crude.)
And proceed to hammer the frets into the slots:
Then clip the ends up to the edge of the board:
Tomorrow, I will clean up the fret ends, and bind the fingerboard.
Old 12-19-2007, 12:03 AM   #83 (permalink)
Roman Rist's Avatar
Here is a tip, fret and bind your fingerboard before you glue it on.
Much easier.
Old 12-19-2007, 12:06 AM   #84 (permalink)
Roman Rist's Avatar
Make an MDF clamping jig.
On your table saw cut a 1/6th inch "relief" for each fret so you are making good contact with the wood as you clamp
like this;
Old 12-19-2007, 12:08 AM   #85 (permalink)
Mr Bones's Avatar
If fretting off the neck, how do you deal with the backbow of the fretted board other than overcutting the slots, or is it even something to be worried about? My thinking was that it may make the fretting and binding a little more difficult, but it allows me to have better control over the fretboard and neck being dead straight before the frets go in.
Old 12-19-2007, 12:11 AM   #86 (permalink)
Roman Rist's Avatar
like this;
Old 12-19-2007, 12:17 AM   #87 (permalink)
Roman Rist's Avatar
Cut the slots "slightly" oversize and use 2 part epoxy......or, what I like to do is this.
I have a "fretting jig"
It is a 2 inch thick chunk of hard rock maple that I do all my work on.
I simply tack glue the board (3 drops of glue does it)
And work away! when you are ready to glue on the board, get a hot knife and transfer from the "jig" to the neck.
You can let the fingerboard sit for weeks and nothing wierd happens to it. it stays nice and straight!
Old 12-19-2007, 12:28 AM   #88 (permalink)
Roman Rist's Avatar
You can also put some relief into the neck. tighten up the truss rod, put a bit (very little) of back bow in the neck itself.
plus you can see if your truss rod works
Anyway, with the backbow, do all your sanding, when you are done, loosen up the rod again......and you will have ever so slight a relief in the neck.
When you glue on your fingerboard you will have NO problems.
Sometimes this is A MUST!
you can have a neck that is perfectly straight..........string it up, and guess what.....................it stays too straight and you have buzz!
The sting tension is not enough to pull the neck into a bit of bow!
that sucks!!!!!! then you have to refret!!!
Trust me, I have had it happen a million times.
Nowadays, before ANY finish goes on one of my guitars she gets strung up and played......just to make sure
cheers
Roman
Ps. Oh god, I am giving away secrets
Old 12-19-2007, 09:34 AM   #89 (permalink)
decoy205's Avatar
This is the most interesting thread ever. I love this.
Guitars are the best. not only can you make music with them but if you are so inclined you can be a wood worker, electrician, Painter. it's a living breathing useful piece of art. When i see stuff like this. It really makes me appreciate them even more. It also makes me realize that a lot of the cheaper bolt on guitars are more like toys then guitars. Real guitars are built this way.
Awesome thread man thanks for sharing.
decoy205 is offline   Reply With Quote
Old 12-19-2007, 10:21 AM   #90 (permalink)
Mr Bones's Avatar
Thanks Decoy, and Roman, I appreciate the tips, I am going to try that on my next neck which should be in a few weeks.
This morning I cleaned up the fret ends starting with a dremel and cutoff wheel. I use the flat top of the wheel not the edge and carefully flush the end of the fret up to the board:
Then I take a sanding stick and finish it off:
I then sand a bevel onto the fret ends with a block.
Next I glue up the two side pieces of binding with duco cement:
BUILDING a nut, odd, but yes! GibsonGuitars119 The Custom Shop 21 08-20-2008 11:20 AM
Using Eld for guitar building? fjgaston Luthier's Corner 5 06-06-2008 05:54 AM
Building three more! Pwozzie Pedals 2 05-09-2008 08:52 AM
Building a LP Help slash is god Luthier's Corner 3 05-09-2008 04:18 AM
building a lp bandjosh Epiphone Les Pauls 13 04-20-2008 04:04 PM
