Old 01-17-2009, 01:37 PM   #1 (permalink)
SG Marc's Avatar
Soon to be started Fix
This copy (or so I believe) LP lost its head. I'm going to try repairing it once I get the fretboard removed. I plan on removing the truss rod, cutting a long scarf before the crack, making another scarf on a new piece, gluing it and then planing it. Seems like the wrong way to do it but I'm up for a challenge. I already tried heating up the fretboard to loosen it but no luck so far. I'll have to try harder.
SG Marc is offline   Reply With Quote
Old 01-17-2009, 01:39 PM   #2 (permalink)
Re: Soon to be started Fix
ah looks liek a tricky job, i hope it goes well.
black and white beauty is offline   Reply With Quote
Old 01-17-2009, 04:19 PM   #3 (permalink)
The Thruth's Avatar
Send a message via MSN to The Thruth
we want pics of every step
fingers crossed that you do it well
The Thruth is offline   Reply With Quote
Old 01-17-2009, 04:22 PM   #4 (permalink)
krokodyl's Avatar
Erm... Maybe you could try to make a headless LP?
Good luck
Nosz pani negocjowalnego afektu...
krokodyl is offline   Reply With Quote
Old 01-17-2009, 07:07 PM   #5 (permalink)
Master Sawdust Maker
Nelson674's Avatar
looks like fun!
i actually have a similar project im starting soon as well. i picked up a Parker P36 with a snapped neck. gonna see what i can do.
how exactly do you remove the fingerboard? does it matter what kind of glue was used to put it together?
good luck on your fix!
_Nelson_
Learning to shrug is the beginning of wisdom.
Nelson674 is offline   Reply With Quote
Old 01-18-2009, 12:36 PM   #6 (permalink)
SG Marc's Avatar
Hmmm, I havent thought of a headless LP.
I'll definately get photos of it , but I just started building a neck for an SG copy I'm making. I'm hoping to go back and forth and mix it up. a little fixing a little making.
I read from the other guitar forum that you can heat up the fetboard with an iron to loosen up the glue then slide a thin spatula under it to seperate it. I tried it and it didnt give at all ,so I'm thinking I may have to remove all the frets to get on top of the wood. I really didnt want to do that.
Old 01-24-2009, 08:06 PM   #7 (permalink)
SG Marc's Avatar
I started taking the fingerboard off and I hope I never have to do this again. This just didnt work out too good for me. I removed all the frets so I can get closer to the wood with the iron because it wasnt giving a bit with them on. Then the iron started melting the binding. eventually I got it off. I'll have to cut the neck down a little shorter than I planned. I ruined my wifes iron also. Now I just have to figure how to get that truss rod out. Any tips??
Old 01-25-2009, 10:14 AM   #8 (permalink)
SG Marc's Avatar
Well I just realized, I was in such a rush to get that fingerboard off that I never took the time to measure the scale length. Now I have no clue as to what it was and what to put on
Old 01-25-2009, 05:34 PM   #9 (permalink)
Nelson674's Avatar
lookin' good so far. the fingerboard seemed to come off alright with that method. what tools/process did you use to remove the frets? did they come off pretty clean?
Old 01-25-2009, 08:15 PM   #10 (permalink)
SG Marc's Avatar
Well, the iron worked part of the way. I took take a paint scraper and tried to wiggle it under the seam. Then I noticed the inlays were falling apart. The binding came off good and left a nice lip to guide the scraper. I ended up going in on an angle and was taking off some neck wood which I tried to avoid. The first fret cracked off at the slot. So about halfway down I ditched the iron, cracked off a few more frets and went berserk. I took a sharp chisel and put it just above the neck on the fingerboard and gave it a sharp whack towards the last fret. I was able to cleanly pop off all the frets that way in 5 minutes. (I know ,this is probably all wrong)Then I just worked the chisel like a plane, paring down the fretboard. If it wasnt for the truss rod I would have used a block plane. I tried again today to lift out the truss rod but it doesnt budge. I have no clue how its installed. Oh yeah, check out Ceska 's post about how he did it. They must have better irons in Finland because it worked great for him.
Old 03-13-2009, 07:12 PM   #11 (permalink)
SG Marc's Avatar
Its been a while, too many projects going on, but I started again on the neck. If this doesnt turn out well, then at least I'll get some experience trying to fix a guitar. This is the first attempt at something like this. I made the scarf joint on the guitar with a hand plane. I kept taking light shavings to get the angle I wanted. Then I took a hand saw to the mahogany blank and cut the matching angle and cleaned it up with a plane. Then glue and clamps. (Sorry for the link), the recent pics are at the bottom.
link
Woodworkerspost.com
Old 03-13-2009, 07:18 PM   #12 (permalink)
Don't hate, appreciate.
alligatorbling's Avatar
shazam! thats one hell of a job you have there... but if your confident i bet you can do it! i look froward to seeing your outcome!
"Freedom from the desire for an answer is essential to the understanding of a problem."
-Jiddu Krishnamurti
alligatorbling is online now   Reply With Quote
Old 03-13-2009, 07:20 PM   #13 (permalink)
lazz's Avatar
nasty, good luck man keep the pics coming
Put whisk down, Grobbelaar comes in peace
www.myspace.com/garymillerandthebluescollective
lazz is offline   Reply With Quote
Old 03-13-2009, 07:22 PM   #14 (permalink)
voices's Avatar
just look at the fretboard: measure from the nut to the 12th fret-then double it=scale
voices is offline   Reply With Quote
Old 03-13-2009, 07:36 PM   #15 (permalink)
DRF
DRF's Avatar
since youve gone this far just remove/route out the neck and make or buy a new(cheap) one off ebay.
DRF is offline   Reply With Quote
Old 03-13-2009, 07:54 PM   #16 (permalink)
Under shop arrest
bfcg's Avatar
+1
bfcg is offline   Reply With Quote
Old 03-14-2009, 07:33 AM   #17 (permalink)
SG Marc's Avatar
the old fretboard is gone and came off in pieces, I figure if I get a pre-slotted fretboard I can measure from the bridge up to a fret, fo rplacement.
Woodworkerspost.com
Old 03-14-2009, 07:37 AM   #18 (permalink)
SG Marc's Avatar
If this neck snaps in half like the original break did, then I might consider that new neck option as a learning experience too. If this was a real gibson, it would have gone to the repair shop. (and the guy who gave it to me probably would have kept it). I'm going to play around with this, it may be a waste of time but its still fun. I ordered a 25" scale fretboard from stewmac. I want to try mixing it up. I may try a 6 tuner on one side headstock too.
Woodworkerspost.com
I started this thread because Bobby done tole me to. BCRGreg The Backstage 22 04-15-2009 04:03 PM
Getting started Chimera Epiphone Les Pauls 17 11-01-2008 05:23 AM
What started it all Fixxxer The Backstage 23 01-06-2008 01:45 AM
Started modding a little - opinions wanted... ArchEtech The Custom Shop 14 01-02-2008 11:03 PM
ive started a group lp junior freak The Backstage 16 10-11-2007 05:19 PM
Powered by vBulletin® Version 3.8.4
