#1 (permalink) |
How would you handle this neck issue?
I just finished showing the neck tenon for my LP build. When I dry fit it, the neck top is perfectly flush with the top side of the body (switch side). However, the bottom side of the body (horn side) is slightly lower than the top of the neck. Maybe 1/32nd inch or 0.5 mm. What should I do here?
1. Do nothing. 2. Do nothing for now. Fill gap with glue/dust mix after neck is glued on. 3. Or, shave the tenon down so that it' flush with the bottom of the body. Then shave the top of the body down flush with the tenon.
Kevin "Never, ever, ever sell your gear...unless it's left handed and to me." The difference between me and a luthier is I know how to build something that looks like a guitar and has six strings. I have no idea how to build a good guitar. 1959 LP Replica Build #1 The Modern '59, PRS, and LP Builds #2, 3, & 4 Flying V Build #5 |
#2 (permalink) |
![]() Join Date: Mar 2007
Re: How would you handle this neck issue?
I would glue a veneer to the top of the tenon and then level it flush with the body.
![]() blah blah blah, blah blah blah blah blah. BLAH?! Blah BLAH BLAH???!! A.Lifeson |
#3 (permalink) |
Freddy, I'm not quite following you. The tenon is square. The is issue one side if the neck mortise is higher than the other.
#4 (permalink) |
Oh I see...sorry, I misunderstood.
OK then in that case I would re-level the body so that the tenon is proud by the same amount on both sides then shave the bottom of the tenon down so that it's flush. I think it's important to keep the relationship between body and neck square.
#5 (permalink) | |
#6 (permalink) |
How about some pics?
2011 LP Custom Hot-Mod 1955 Black Beauty (BB1, BB2) 2011 LP Classic Custom Antique Natural (57 Classics) 2007 LP R9 Sunset Tea Burst Yamano (BB1, BB2) 2011 PK Custom S-Style (Duncan SSL-1s) 2010 Carvin Bolt Tremolo (Carvin AP11s) 2005 Brian Moore iGuitar i81.13 Emerald Green (iMs + RMC Piezo) 1976 Ibanez Les Paul 2351AV Antique Violin (Super 70s) 1969 Ovation Balladeer 1111-4 Natural Marshall JVM205, Class 5, JTM-1, JMP-1, JCM-1, DSL-1 Egnater Tweaker 15 - 112 cab Vox AC4TVH - V112TV cab |
#7 (permalink) |
![]() Join Date: Jun 2009
check the mortise depth on both sides, make sure they are the same. if they are off its likely the top carve around the mortise needs a tweak or two.
if the tenion is square all around then something is off between the body and mortise. if the mortise depths are correct then I would glue a thin a shim to the bottom of the tenion and resand it till everything is perfection. |
#8 (permalink) | |
Thanks for the help guys
#9 (permalink) | |
First check the FULL depth of the body on both sides of the mortise. you may find a slight thickness difference.. Then check the back of the body to the bottom of the mortise...because any thickness issues can become compounded here. I've even routed a body with a box jig, only to discover that a tiny build up of sawdust had gotten under one side of the jig and created a slight tilt in the mortise. grrr. anyway, if both of these sets of numbers come out the same, then your next stop would be the top of the mortise. remove any needed material only from the top surface.. once all those numbers jive, then you gotta go back to the tenion and make sure its bottom surface is parallel to the necks reference surface ( where the fingerboard will glue to) once that lines up, the your sides have to be squared to the top and bottom of the tenion. easy as a slice of sawdust pizza! ( thats something my daugther used to make while playing in my shop as a little kid. she would get a few round "speaker hole cutouts" and use them as plates and then she used all the different colors of sawdust found on the floors and machines to make a "Dust Pizza" obviously totally useless.. but they looked great! and she was entertained for hours.) |
