Old 10-15-2008, 01:43 PM   #1 (permalink)
treddingjr's Avatar
Korina LP Replica Build
I've been looking for a one-piece korina body to make a second LP Replica. I kept visiting www.exoticwoods.com but each time it said 'Out of Stock'. I went ahead and ordered it thinking I'd at least get on the list and when one came in and my turn came . . .
Well, this came today. Took less than a week.
And as you can see, 'that shape' fits nicely on it.
I have already started a neck for it, also out of korina, and will post pictures of those steps later.
I have a flamed maple top made from the same blank as my other replica and a brazilian rosewood board, a set of Buzzy's inlays, some Grover Kidney Beans, a 50s headstock inlay and some holly veneer. I am going to use a Pigtail bridge and tailpiece set again.
My plans are to use a different pickup for this build and get away from my Duncans and Classic 57s, so if you read this my friend, Skatterbrane, feel free to recommend one of your PAFs for me.
It was fun while it lasted.
treddingjr is offline   Reply With Quote
The Following 5 Users Say Thank You to treddingjr For This Useful Post:
Old 10-15-2008, 02:21 PM   #2 (permalink)
davebag89's Avatar
Re: Korina LP Replica Build
i like the idea of a korina lp, im subscribing to this thread
davebag89 is online now   Reply With Quote
Old 10-15-2008, 02:42 PM   #3 (permalink)
single cut 54's Avatar
+ 1
single cut 54 is online now   Reply With Quote
Old 10-15-2008, 04:26 PM   #4 (permalink)
Funny you mention this....I am working on a chambered Korina LP with Dave Johnson and Roman. I will try to get a post up and running as things progress.
Rick
rick13 is offline   Reply With Quote
Old 10-15-2008, 04:50 PM   #5 (permalink)
shotgunlew's Avatar
Rick
Thats quite a team ya got running there! Romans building mine as well!
60% of the time...it works every time....
Gun Control = Using Both Hands!!
Everyone Please Pray for Sgt Jeffery Crones and the rest of the boys in iraq! Get some boys!
Chris "The Gunhand" Of the MLP Pirates Crew
1986 Les Paul Jr (Cherry red Singlecut )
1994 MIJ fender Telecaster 52 reissue
1984 JCM 800 1x12 50 watt combo
Behringer 4x12 cab (Bugera speakers)
shotgunlew is offline   Reply With Quote
Old 10-15-2008, 04:59 PM   #6 (permalink)
Epi Verification Expert
Sinmastah's Avatar
Whoooooo. I loved your other thread, and I will love this one as well.
Epiphone Elitist SG Faded Cherry (Tone Mojo'd and WB'd)
Faded Cherry Epiphone SG G-400
Flamed Cherry SunBurst Epiphone Les Paul Plus Top
Fender Mexi Oly White Strat
Squier Natural Vintage M Jazz bass
Peavey Classic 50
SG's FTW
Sinmastah is offline   Reply With Quote
Old 10-16-2008, 07:57 PM   #7 (permalink)
treddingjr's Avatar
The neck material, 3 x 3 x 30 has enough korina for two necks, and since it's just as easy to make two as one, I made two; one for now and one for later.
The blank.
Masonite template of the neck profile.
Template traced on the blank.
Old 10-16-2008, 08:01 PM   #8 (permalink)
eshuffle's Avatar
Looks fantastic. Love your choice of wood.
eshuffle is offline   Reply With Quote
Old 10-16-2008, 08:07 PM   #9 (permalink)
shotgunlew's Avatar
Lookin solid my friend!
Old 10-17-2008, 03:08 PM   #10 (permalink)
treddingjr's Avatar
Here are the necks cut to the profile shape of the template.
Next they will be cut to the approximate width of the neck.
And routing out the truss rod channel. The depth is just over 1/2 inch at the headstock end of the neck.
A maple fill strip will be made and then a hole drilled for the anchor end of the rod. I used the Stew-Mac traditional truss rod.
Old 10-17-2008, 05:25 PM   #11 (permalink)
Loserface300's Avatar
nicely done, good luck...
Loserface300 is offline   Reply With Quote
Old 10-19-2008, 10:34 AM   #12 (permalink)
treddingjr's Avatar
Truss rod inserted and maple cover fitted and glued with hide glue.
While that dries, it's time to cut the body from the blank.
I used the band saw to make these cuts along the curves to make it easier for it to follow the shape. In carpenter's terms, I left the line for final shaping on the pin router.
As close as I dared to cut.
I have to plane it to the right thickness and then I'll rout the cavities.
Old 10-20-2008, 10:17 PM   #13 (permalink)
so, are you going to do a bell top...
Old 10-21-2008, 07:00 PM   #14 (permalink)
treddingjr's Avatar
Yes, a full carved top is in the plans.
I routed the body back today. All went well except for one of the inherent korina problems; a chip exploded out of the one curve. S#$% happens!
But it was repairable and once the finish is applied, it should be invisible.
The control cavity:
The switch cavity:
The cable rout:
The patch is pretty close to invisible.
Old 10-22-2008, 05:49 PM   #15 (permalink)
treddingjr's Avatar
Routing for the neck tenon - yes, it's a LONG tenon. Is there any other way?
The jig sets the neck angle. It's not a final rout as I won't do that until I finish the neck.
The back of the top and the front. This is the other part of the billet I got from NW Timber (http://www.nwtimber.com). You can see the actual piece of wood on their website before you buy it.
Clamped and glued. Hide glue throughout.
Old 10-22-2008, 06:45 PM   #16 (permalink)
rockappalla's Avatar
Great job! more pics
rockappalla is offline   Reply With Quote
Old 10-23-2008, 02:18 PM   #17 (permalink)
CARNAGE222's Avatar
MORE! MORE!! MORE!!!
CARNAGE222 is offline   Reply With Quote
Old 10-23-2008, 02:32 PM   #18 (permalink)
SKATTERBRANE
Guest
Posts: n/a
Cool!
Old 10-23-2008, 02:34 PM   #19 (permalink)
...with a big mouth
Big John's Avatar
Just curious...should the center of the top be pressed or clamped down?
Big John is offline   Reply With Quote
Old 10-23-2008, 05:53 PM   #20 (permalink)
treddingjr's Avatar
This is a work in progress and unlike my other replica, I am not as driven to be done. At least not yet anyway. Thank you for all of the nice comments, and suggestions.
I used two brads to keep the top from sliding and since both surfaces were planed true I didn't clamp the center. When I look in the cavity rout, it is all tight, no gaps so maybe I dodged a bullet!
I worked on the neck some as well.
I glued on the ears, planed the top, and then glued on the holly veneer on Tuesday so it was ready to go today.
Rough trimmed headstock.
Next up is radiusing the fretboard and fitting the inlays.
Old 10-25-2008, 04:47 PM   #21 (permalink)
treddingjr's Avatar
More headstock.
Time to shape the neck.
And the Brazilian fretboard; the fret slots are cut (actually they were cut 18 months ago when I did my other replica) and waiting for me to radius it.
I expect to do that and have the top carved by the end of Tuesday.
Old 10-25-2008, 04:51 PM   #22 (permalink)
TheWellGoodShow's Avatar
Send a message via AIM to TheWellGoodShow
more!
"Now Known as The Post-O-Matic 5000"
ZOMG! Its Gemma!!
TheWellGoodShow is offline   Reply With Quote
Old 10-25-2008, 04:51 PM   #23 (permalink)
Sinmastah's Avatar
Talk about tone. Korina and Braz Rwood. Holy crap man, this is going to sound killer.
Peavey Classic 50
SG's FTW
Old 10-25-2008, 05:21 PM   #24 (permalink)
treddingjr's Avatar
Originally Posted by TheWellGoodShow View Post
more!
Sorry but that's it for now. I'll have new stuff Tuesday.
Old 10-25-2008, 05:22 PM   #25 (permalink)
treddingjr's Avatar
That's the plan as tone to die for is the goal.
Old 10-26-2008, 01:15 PM   #26 (permalink)
eshuffle's Avatar
Looks really Good. Nice Job!! Love the wood combination....
Old 10-27-2008, 02:39 PM   #27 (permalink)
Sinmastah's Avatar
Can't wait for videos of this thing in action. What kind of Pups are planned for this thing?
Peavey Classic 50
SG's FTW
Old 10-28-2008, 07:32 PM   #28 (permalink)
treddingjr's Avatar
I am actually getting two sets; more on that later.
I thought I'd get top carving done today but my friend couldn't so I used my time wisely and worked on the fretboard. Since the last time I did this, my friends developed a new way to radius a board. Took about five minutes whereas the Stew-Mac block the last time took a day of blood and sweat - no tears but I was tempted.
This time I radiused first and routed for the inlays after that was done. No cutouts to catch your fingertips in this way.
I finished up with the trusty Stew-Mac radius tool.
Then, using the smallest pin and the smallest router bit, I went at it.
The results. I took my time; routed to depth in the middle and then made another pass on the ends at a deeper depth to be able to bend the inlay to the radius of the board.
Test fitting.
Glued in.
Ready for the taper.
Next, I'll trim the board and mark the neck for the tenon and angle and work on the '58 profile that I prefer for my necks.
I hope you are all enjoying this as much as I am.
Old 10-28-2008, 10:09 PM   #29 (permalink)
You can bend the inlays to fit? Wow you learn something new every day. This is good stuff as I'm about to do my first inlay job on a radiused board.
IceGator8 is offline   Reply With Quote
Old 10-29-2008, 10:16 AM   #30 (permalink)
treddingjr's Avatar
I used the 5-15 second curing super glue, got the one end down then the other, pressed like hell, and held on. For some of them I had to spray the accelerator to speed the curing process so it helps to have an extra set of hands at the ready.
korina explorer or korina flying V guitarguru My Other Guitars 22 10-08-2009 08:01 AM
korina, korina....how i love you so........... 1959burst Other Gibsons 38 03-10-2009 10:13 PM
Korina LP anyone? FennRx Online Auctions 0 09-24-2008 10:09 AM
Korina... PVS83 Other Gibsons 30 09-06-2008 10:17 PM
Epi Korina! Sinmastah Epiphone Les Pauls 39 07-25-2008 01:22 PM
