Go Back   Les Paul Forums > The Les Paul > The Custom Shop > Luthier's Corner
Unread 07-05-2012, 05:54 PM   #1 (permalink)
Router bit for Pickup leg routes
What size router bit or method do you guys use for routing the pickup leg holes on a 59' Bartlett plan build? 1/2 diameter seems to be just slightly to big on the corner radiuses.
thanks,
Keith R
Flynman is offline   Reply With Quote
Unread 07-05-2012, 07:38 PM   #2 (permalink)
kfowler8's Avatar
Re: Router bit for Pickup leg routes
I believe it's 3/8th. I had to special order mine. Legs were a pain in the ass. My current build I plan on using bushings and hopefully my plunge router. Forstner bits help.
Kevin
"Never, ever, ever sell your gear...unless it's left handed and to me."
The difference between me and a luthier is I know how to build something that looks like a guitar and has six strings. I have no idea how to build a good guitar.
1959 LP Replica Build #1
The Modern '59, PRS, and LP Builds #2, 3, & 4
Flying V Build #5
kfowler8 is offline   Reply With Quote
Unread 07-05-2012, 10:23 PM   #3 (permalink)
Abeunt studia in mores
MRJ5's Avatar
thanks,
Keith R
Most of the questions will be answered within the sticky here: MLP Bartlett Build
Your specific question is answered in the post here:MLP Bartlett Build
MRJ5 is offline   Reply With Quote
Unread 07-06-2012, 02:00 PM   #4 (permalink)
Thanks for the responses...bit is on order!!
Unread 07-06-2012, 02:48 PM   #5 (permalink)
Knarbens's Avatar
What types of bushings are you talking about?
09-2008 Orville Les Paul Standard
06-2012 finished first guitar build
12-2012 my 2nd guitar build(s) ...
Knarbens is offline   Reply With Quote
Unread 07-06-2012, 02:50 PM   #6 (permalink)
nicudeemus1's Avatar
I think he means the bushings that you can fix to the underside of the router so it will follow the template without bearings.
nicudeemus1 is offline   Reply With Quote
Unread 07-06-2012, 06:48 PM   #7 (permalink)
kfowler8's Avatar
Yes,I think they're more flexible than bearings.
Kevin
Flying V Build #5
