#3 (permalink) |
this is my build
hey guys!
after one year of gathering informations (especially this forum, its awesome), i got the courage to build a les paul. i have no experience with woodmaking, but i'll give it a shot. here's the wood (sapelly mahagony+flamed maple): ![]() improvised hide glue pot: ![]() gluing the parts with hide glue: ![]() ![]() making template: ![]() ![]() body and top planed to thicknes: ![]() ![]() almost a one piece neck: ![]() todays work: ![]() ![]() ![]() to be continued... |
#4 (permalink) |
![]() Join Date: Dec 2007
Re: this is my build
Nice work. I know exactly what you will be going through over the next weeks.
Almost a one piece neck? Three pieces is normal as the ears of the headstock are glued on to make that famous shape. Is that what you meant or a three piece like the Norlin era Les Pauls of the 70s?
It was fun while it lasted. |
#5 (permalink) |
someone may be able to correct me on this, but if that is the Stewmac plan for a '59 les paul, doesn't it saw that it's not drawn to scale. that one should use the measurements from it only. So cutting out a template based on the drawing alone may not be the right size?
~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~* ~*~*~ Happiness is.....finding two olives in your martini when you're hungry |
#7 (permalink) | |
Disciple-of-RobotOverlord
![]() Join Date: Apr 2008
i know my LP is smaller than the plan drawing but others say its the same size as theres. but the real concern isnt shape its placement of bridge tail pups
2005 Ibanez H.R. Giger Iceman VHT Deliverance 60
#8 (permalink) |
Technical drawings should never be used as templates! At least not until you can confirm every measurement as being 1:1. But even then some of the shapes can be a bit off. But yea, as long as your crucial measurements are correct (neck pocket, bridge/pickup placement), it should work.
#9 (permalink) |
I was the one who used the Stew Mac plan as a template. I've been measuring the plans and so far they are dead on. I think Stew Mac put the disclaimer on the plan simply to absolve themselves if an error happens to be found.
#10 (permalink) |
@treddingjr: i actually didn't know that there even are the "wings" glued to the headstock on factory les pauls?? i asumed that one piece necks is actually a one piece neck.
i would truly have a one piece neck, accept from that little bit.plans are not from stew mac, i found them on internet back to the build heating surfaces and gluing the top: ![]() ![]() half sanded top: ![]() ![]() top: ![]() ... |
#11 (permalink) |
Nice work so far, I really want to do this someday as well. If you succeed, like I guess you will, maybe I'll get the courage to start planning it. I'm really interested in watching how you'll do the top carve.
And you're from Slovenia? My girlfriend is from there, I was just on a 5-week vacation in Ljubljana and Laško. What a fantastic country! |
#12 (permalink) |
Look at my thread
http://www.mylespaul.com/forums/luth...l-replica.html You will see pictures of what I mean. I used a 3in by 3in mahogany blank for the neck. There's enough wood for two necks in a piece like that but it's not quite wide enough and using a 4x4 would really be a waste of wood so the wings are glued on and then shaped. You can see it on the backs of every headstock in Beauty of the Burst. Quote:
#13 (permalink) | |
Keep us posted.
Sometimes it is better to remain silent and be thought a fool, than to open your mouth and remove all doubt... |
#14 (permalink) | |
#15 (permalink) |
i'm back again
yes, iam from slovenia, and youre right its a nice country. plans: http://www.zzjz-kkz.hr/ostalo/DWF%20format.rar belly contours (copied from user EDDYM) and binding chanel: ![]() ![]() ... routing fingerboard angle: ![]() i made stupid mistake at the begining and set the router too deep, but i think it will be ok, becouse there will be a pickup cavity ![]() ... after a little bit of chisel work and then a "mouse" sander: ![]() argh, how will i repair these?!? after routing a pickup cavity, there will be still about a centimeter left on both edges, that i'll have to sand with surface. i hope it wont be vevry visable ![]() ... |
#17 (permalink) |
Speaking with absolutely no experience at all, couldn't you cut a matching piece of left-over top wood, glue it into the error area and sand to flush?
#20 (permalink) |
thanks
about the tools: i have only a borrowed router, i bought one ball-bearing router bit (25 eur), made myself an oak working bench(50 eur), and some time ago i wanted to be a modeller (which didnt last long), so i have an electric "dekupiere sage" (i dont know the english term - a saw for modellers)(around 40eur ), and a sanding bit for the drill press(4 eur)(drill press is my fathers, who is a toolmaker), and a "mouse" sander (40 eur).skills: i made two model airplanes before (which didnt fly too good), thats it. three things i've learned at the begining: -take your time -sharpen your pencil good - mistakes will accour constantly bye |
#22 (permalink) |
![]() Join Date: Feb 2008
Not bad buddy! Keep on rollin!
60% of the time...it works every time....Gun Control = Using Both Hands!! ![]() Everyone Please Pray for Sgt Jeffery Crones and the rest of the boys in iraq! Get some boys! Chris "The Gunhand" Of the MLP Pirates Crew 1986 Les Paul Jr (Cherry red Singlecut ) 1994 MIJ fender Telecaster 52 reissue 1984 JCM 800 1x12 50 watt combo Behringer 4x12 cab (Bugera speakers) |
#26 (permalink) |
Wow thats turning out great!
#27 (permalink) |
its been a really long time since the last post, some work has been done, but no time for posting.
so: glued binding and color sample ![]() ![]() ![]() parts arrived from stewmac ![]() inlays cut out ![]() fret slots sawn: inlay slots rough routed with dremel, continued with chisel: fretboard sanding block: fretboard sanded to 600 grit: ![]() i'm impressed with that keyboard reflectionfrets inserted: ![]() ... |
#30 (permalink) | |
How did the homemade gadget work for the binding? I was going to buy the one from Stew-Mac, since I'm only doing one guitar (for now) I could make a similar tool.
| my LP build | pvt | Luthier's Corner | 81 | 02-24-2009 10:18 AM |
| Want to build a cab.. | MapleLeaf97 | The Squawk Box | 15 | 01-14-2009 10:50 AM |
| Build your own LP kit | shal1234 | Luthier's Corner | 25 | 01-12-2009 08:30 AM |
| Wah build | lexluthier | Pedals | 8 | 08-29-2008 08:47 AM |
| Build your own Amp | FLICKOFLASH | The Squawk Box | 10 | 04-02-2008 07:41 PM |
