Go Back   Les Paul Forums > The Les Paul > The Custom Shop > Luthier's Corner
Like Tree4Likes
  • 1 Post By R'nien
  • 1 Post By Freddy G
  • 1 Post By TKOjams
  • 1 Post By Riku
Unread 05-31-2012, 12:00 AM   #1 (permalink)
What do you think of this yellow?
I just put on lemon yellow instead of bright yellow and I'm not sure what I think of it. It might be that its still a little wet. Too late now to change it. Is it a winner? Or dud?
[IMG][/IMG]
[IMG][/IMG]
MRJ likes this.
R'nien is offline   Reply With Quote
Unread 05-31-2012, 01:29 AM   #2 (permalink)
szlash280z's Avatar
Re: What do you think of this yellow?
I like it
szlash280z is offline   Reply With Quote
Unread 05-31-2012, 01:57 AM   #3 (permalink)
djrussell's Avatar
Yeah I like it as well.
'13 Maiden DC Special [Build] | Maiden Telecaster [Build]
'12 AXL Badwater 1216 Jr | Aria STG-003 [Project] | Maiden Tele Rocket 88 [Build]
'11 Hagstrom Viking II | Maiden Junior [Build] | Gladiator GG-165 DC Junior
'09 Gibson Les Paul Junior [BJA Signature] | Hagstrom Swede
'08 Hagstrom D15CE
'07 Gibson Melody Maker | Fender Telecaster | Hagstrom F-300
'00 Fernandes FGZ-1C
'99 Fender Stratocaster
'95 Fernandes Stratocaster
djrussell is online now   Reply With Quote
Unread 05-31-2012, 02:05 AM   #4 (permalink)
It's looks real good if you ask me
wombat is offline   Reply With Quote
Unread 05-31-2012, 03:31 AM   #5 (permalink)
free2rock's Avatar
Win, based on the pictures. But the question is, how hard a critique are you on yourself?
free2rock is offline   Reply With Quote
Unread 05-31-2012, 05:21 AM   #6 (permalink)
Backstage's Avatar
It might be the pictures but for my liking the yellow is a bit too cold - just lemon . To me there has to be more warm yellow tones.
Backstage is offline   Reply With Quote
Unread 05-31-2012, 05:22 AM   #7 (permalink)
Archtop 13's Avatar
It should age nicely
http://www.bluebellyguitars.com
FACEBOOK Link
http://www.facebook.com/pages/Blue-B...66137280086032
Archtop 13 is online now   Reply With Quote
Unread 05-31-2012, 07:24 AM   #8 (permalink)
Abeunt studia in mores
MRJ5's Avatar
It is always difficult to tell a color from a picture because my monitor may be showing a different shade than another.
If you are concerned with the brightness, use a tinted amber clearcoat to give it a better richness.
Since it is too late to change what you have done without starting over, spray some test samples wit the same color on scrap and experiment from there.
I think it will be great but I don't see what your mind's eye sees.
MRJ5 is online now   Reply With Quote
Unread 05-31-2012, 07:57 AM   #9 (permalink)
Freddy G's Avatar
In my experience a bright yellow to start with is the way to go. It will mellow naturally , if you spray a burst or added subtle toners then it just increases in depth and warmth. You can't go the other way however, if you start out with a yellow that's too dark or mellow you can't brighten it and every subsequent coat will make it even darker as will natural ambering of the lacquer from UV.
pinefd likes this.
blah blah blah, blah blah blah blah blah.
BLAH?! Blah BLAH BLAH???!! A.Lifeson
Freddy G is offline   Reply With Quote
Unread 05-31-2012, 08:42 AM   #10 (permalink)
I like it but I'm just worried about it not being light enough from the start. I'll keep you posted. Thanks for the input.
Unread 05-31-2012, 09:17 AM   #11 (permalink)
Freddy G's Avatar
Oh I see...I thought you were worried about it being too bright. In that case if you're worried about it being too mellow in the end, dont shoot any amber coats over it.
For the record, I think it looks great!
Unread 05-31-2012, 09:22 AM   #12 (permalink)
gator payne's Avatar
Yep the first of color tinting any color plus any color will alway equal a deeper, darker or warmer color. the very reason when you do a busts always work from light to dark.
I really like the top body. once clear coated it will be a very nice iced tea color
The bottom body should amber up a bit when clear coated but like MRJ5 said Im basing that on the hue that my monitor is displaying. Looking at the photo it appears to be yellow shifted quite a bit. It looks to me as if the lighting the photo was taken in is probably incondesent lighting which tends to shift light wave reflection towards yellow as where neon tends to shift light wave reflection towards blue. Assuming this I took a copy of the photo and using a graphics editor reduced the yellow shift and the bottom one is very lemon yellow. But like I said when you add clear I suspect this will amber up and or warm up a tad.
The true measure of a craftsman’s soul can only be measured when all he has learned is multiplied by all he has taught.
gator payne is offline   Reply With Quote
Unread 05-31-2012, 09:57 AM   #13 (permalink)
This morning to took a damp rag and wiped off some of the color, or just diluted it. It looks more even now. I'm feeling a little better about it. I'm hoping the finish I put on it will make it pop.
[IMG][/IMG]
Unread 05-31-2012, 10:06 AM   #14 (permalink)
Freddy G's Avatar
[IMG][/IMG]
Oh yes indeed that looks better! What kind of stain did you use?
Unread 05-31-2012, 10:07 AM   #15 (permalink)
This is transtint lemon yellow.
Unread 05-31-2012, 10:12 AM   #16 (permalink)
H.E.L.Shane's Avatar
Honestly... I like the lemon yellow better.. and.. i would hit the bright yellow with a couple amber tinted coats... (and by tinted. I only put a couple drops of amber in a 1/4 of a quart)
______________________________________
Originally Posted by patrickBOOTH View Post
She's kinda hot in that dyke first cousin sort of way.
H.E.L.Shane is offline   Reply With Quote
Unread 06-25-2012, 09:57 PM   #17 (permalink)
Just an update. I wasn't sure about this lemon yellow for a base coat color but as it turns out.... I really like the results. I should be able to get it plugged in by Wednesday evening. So if anyone ever thought of using lemon yellow, here's what you can expect.
[IMG][/IMG]
Unread 06-25-2012, 10:07 PM   #18 (permalink)
TKOjams's Avatar
[IMG][/IMG]
I don't know, you tell me what I think of it.
I friggin' love it!!
Riku likes this.
TKOjams is offline   Reply With Quote
Unread 06-26-2012, 02:47 AM   #19 (permalink)
free2rock's Avatar
You still have this guitar, Ken?
Unread 06-26-2012, 03:34 AM   #20 (permalink)
overt1's Avatar
don't really know which one you're referring to, but they both look great regardless
overt1 is offline   Reply With Quote
Unread 06-26-2012, 06:46 AM   #21 (permalink)
Riku's Avatar
So yeah my offer of AUS$1000 on this still stands, take it or leave it
Gorgeous TKO
And that yellow will look quite nice after a bit of ageing and some darkening with clears. I like it
TKOjams likes this.
My gear is all crappy stuff because I'm too poor to afford name brand stuff. Ah, the life of a music student....
Originally Posted by bruce bennett View Post
its sorta like watching honey boo boo.
you have no idea what shes saying.. but you just can't stop watching.
Riku is offline   Reply With Quote
Unread 06-26-2012, 08:27 AM   #22 (permalink)
TKOjams's Avatar
Yes, she's still hanging around here somewhere.
You interested in it? PM me.
Unread 07-04-2012, 05:16 PM   #23 (permalink)
Here's the final color. I think it turned out great!
[IMG][/IMG]
Unread 07-04-2012, 05:25 PM   #24 (permalink)
....and a video
Brockburst made by Brock - YouTube
Unread 07-05-2012, 06:07 AM   #25 (permalink)
nicudeemus1's Avatar
It did indeed turn out great! Nice one.
nicudeemus1 is offline   Reply With Quote
